Page 4 of 6 FirstFirst 123456 LastLast
Results 76 to 100 of 130
Thread: Z3 coupe L33 twin 6262
  1. #76
    Nov 2015
    kelowna
    Z3 Coupe 3.0
  2. #77
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    Unfortunately I had no way of making the 3” down pipes work with the bottom feed manifolds. These top feed ones are not as nice looking but they alow for better down pipe and waste routing.
  3. #78
    Indianapolis
    F30 328d X-Drive
    going to be tight on the plug wires??
  4. #79
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    Quote Originally Posted by Venom13132 View Post
    I was checking as i went. They will clear everything. But I will probably need those little heat socks for them. The manifolds will also be wrapped
  5. #80
    Indianapolis
    F30 328d X-Drive
    Quote Originally Posted by fallguy View Post
    yeah definitely would do both. I did that on my 95 RX-7 LS1 when I upgraded the headers. Its worth the peace of mind and not very expensive.
    I am finishing a LS1 swap in to a friends RX-7 right now. Its definitely fun playing with engine swapped cars.
  6. #81
    Los Angeles, CA
    #Project333Ti & Z3 Coupe
    Nice progress! Sucks that Precision and I think most other turbo companies don't offer mirror image turbos like the Nelson Racing Engines do.
  7. #82
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by e30polak View Post
    The newest garretts have that option
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  8. #83
    NY
    skateboard
    Many fancies here. Carry on.
  9. #84
    Indianapolis
    F30 328d X-Drive
    how's the build coming along? I saw you were helping with the V10 Roadster build I am following on here. I am going back to the FD world of LS power as soon as my M sells.
    1995 Mazda RX-7 Feed Widebody LS3 6-speed (Toy, project)
    2010 Cadillac Escalade Luxury (Daily, Pulls my 18' car hauler)
    2014 BMW 328d XDrive (Wife's Daily)
    Have owned 4 other BWM's I no longer have.
  10. #85
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    Sorry huge delays. Lol.
    Moved the turbos again... just no room to get 3” down pipes past the frame rails and manifolds.
  11. #86
    Aug 2014
    Ontario
    1999 325i, 1996 RSTi Cou
    Big hype!
  12. #87
    Indianapolis
    F30 328d X-Drive
    great to see this is still coming along! I just put my LS1 RX-7 away for the winter. going to strip it down for paint, no money for turbos this winter.
  13. #88
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    8EE6B04E-9D71-4D45-BD7A-DB693DB21656.jpgF0328998-6145-4CEF-994C-A5F2871DA6E2.jpgC0224E55-609A-4F1B-831B-6807FC01D514.jpg2494C224-FB27-4620-9FF5-3AEFA23AB70E.jpg
    been working on the plumbing. Unfortunately had to go under the cross member worth the 3” exhaust. Just couldn’t find another way. It it bottoms out I will try something else. But the low points are inline with the wheels. So speed bumps will not be a problem. Just something sticking up a few inches in the middle of the road could be bad.
    the exhaust is dual 3” into a single 4” with a vibrant oval muffler.
  14. #89
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    cut and flipped bits around on the ABS pump mount to move it over about an inch.
  15. #90
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    Picking at the fuel system now, cut the bottom of the hanger off to fit this hellcat pump. Then to a 10 micron holley filter that fits in the stock hanger. feed in -8 and -6 return. all earls super stock pushlock.
  16. #91
    Indianapolis
    F30 328d X-Drive
    nice to see you are still making progress on this. Do you think you will be able to fire it up this summer?
  17. #92
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    That’s the goal. Then iron out some bugs over winter. Also Install a boost control solenoid and a flex fuel sensor. Just found a place that actually sells e85/e98 up here in BC Canada.
  18. #93
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    Just finishing up some little things under the hood. Getting a quote from Ron Davis for the radiator.
    buddy CNC’d the 1350 u joint for me.
  19. #94
    Indianapolis
    F30 328d X-Drive
    nice buddy to have!
    What are you doing about heater hoses? Looks pretty tight in there coming off the water pump (from what i can see)
  20. #95
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    Gates and dayco make these ones with a moulded 90 and 3-4’ of hose. But unfortunately I will have some splices. Probably less than the factory BMW engine with its half plastic half rubber cooling system
  21. #96
    Indianapolis
    F30 328d X-Drive
    yeah i have those hoses in my car but I dont have turbo stuff haha.
  22. #97
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    took this out today. Eyed up this winters project of getting a 8.8 back there...
    but this time around I just took it out so I can run the -8 and -6 fuel lines
  23. #98
    Washington
    BMW 525i
    Just got caught up on your thread, great progress and fun build.
    2002 BMW 525i - 6.6L LS Turbo Swap
    Follow me on Instagram at @LantzFab
    Link to LantzFab.com
    Link to my Facebook page
    Link to my build page
  24. #99
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    Quote Originally Posted by Lantz View Post
    Thanks. Still have a few expensive parts to buy but after that it’s just the stuff that nickel and dimes you.
    Just putting the tank back in. -8 feed and -6 return. With the walbro 525 hellcat pump
    67735697-D3BE-408A-9A4D-1AF67219F683.jpg45B4A9E6-1BC8-4394-8149-ED40085F3FE7.jpg81F4F319-22DD-4466-9B9A-3FC1EAA2FD20.jpgC39E957C-561D-4380-A8C9-99ACEB2A892B.jpg
  25. #100
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    I didn’t want to use anything less than a 1350 u joint. Unfortunately the z3 is tight in that area. So angle grinder... hammer and welder sorted it out.
    0C4504F6-D513-41A7-8DB0-E46B8933AC97.jpg95ADE1F7-D136-46AA-92B7-477F97EDB562.jpg3BA144D6-A01A-448A-B9D4-DF82E7D00E32.jpg075AB35E-5BB1-4252-BA86-14C391451F25.jpg
  1. Turbo Z3 M Coupe vs Twin Turbo Gallardo [vid]
    By drdre0728 in forum Kill Stories
    Last Post: 11-27-2013, 11:06 AM
  2. Z3 E36/7 FS BMW NOAH Z3 Coupe Car Cover
    By Wojtek79 in forum Z3,Z4,Z8 Classifieds
    Last Post: 11-01-2009, 01:21 PM
  3. Z3 E36/7 OEM 3 series modified to fit a z3 coupe for sale.
    By wheelieh in forum Z3,Z4,Z8 Classifieds
    Last Post: 03-16-2009, 12:20 PM
  4. Z3 E36/7 WTB: Stock airbox for my 2000 Z3 coupe
    By Tackleberry in forum Z3,Z4,Z8 Classifieds
    Last Post: 03-11-2009, 08:47 PM
  5. Z3 E36/7 FS-Z3 Coupe Original ACS Rear Wing
    By Ian 2.0 in forum Z3,Z4,Z8 Classifieds
    Last Post: 03-04-2009, 02:43 AM
