Page 2 of 6 FirstFirst 123456 LastLast
Results 26 to 50 of 130
Thread: Z3 coupe L33 twin 6262
  1. #26
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    Quote Originally Posted by Venom13132 View Post
    great to see some progress! I am about to do a pretty basic LS swap to a friends 93 RX-7 for some extra cash to fund my swap in the M. Any idea on when you are going to start installing parts into the Coupe?
    Probaly in the next month or two I will have the motor sitting in the coupe.
  2. #27
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    Setting the the top ring to 0.025" and the second to 0.027"
  3. #28
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    Motor is installed, That was easy lol.
    Just fitted up the rings and rods to the pistons.
  4. #29
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    Slowly assembling the short block. Should be pulling the 3.0 in the next few weeks.
  5. #30
    Manchester, N.H.
    96 332IS 6466 turbo
    Well this build would make most people go broke, pull a second out, or sell organs. Love it. Probably best build on the boards. Well done. Take your time.
    Sent from my E6782 using Tapatalk
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  6. #31
    Apr 2009
    Pittsburgh
    99 M3 LS1, '11 WRX
    Looking good, best of luck with the build man. Let me know if you have any issues with the mounts. There's another guy building a Z car with the same mounts right now, not sure if he's a member here or not but his instagram handle is @neonbucket. I think he had to trim a couple of the bosses off of the transmission housing as well as a bit of the tunnel insulation to get everything to seat fully but that's pretty standard stuff.
  7. #32
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    Thanks guys, yeah the build is a little over kill. but just slowly collecting the parts so it has not been a big hit. My other car is a 2007 3dr yaris.. so no car payments or anything so i dont mind spending some money on this project.
    I'm running the T56 magnum, not too sure how much fire wall massaging i will need to do. but i,m ok with that... gotta make it fit.
  8. #33
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    Pistons and rods installed. Will be assembling the heads next.
  9. #34
    Mar 2012
    Renton, Wa
    98 m3
    Looking really good.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  10. #35
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    243 heads with stainless exhaust valves, dual valve springs and titanium retainers.
  11. #36
    Indianapolis
    F30 328d X-Drive
    very nice! Do you have a guide you are using for the wiring? I have done an RX-7 and I remember it being pretty minimal in the grand scheme of things.
  12. #37
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    I have not really looked into wiring yet. For the LS im just going with a harness from AEM for the infinity.
  13. #38
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    just bolting things together, should have the motor done within a week
  14. #39
    Nov 2015
    kelowna
    Z3 Coupe 3.0
  15. #40
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    Love engine shots!
  16. #41
    Surrey, BC
    Canada
    amazing.
  17. #42
    SW Florida
    99-01 M Cpe & Rdts, X5M
    Quote Originally Posted by fallguy View Post
    Transmission looks familiar, is it the Magnum?
  18. #43
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    Yes it is a T56 magnum (don’t know why they call it a T56 it’s really more like a T6060)
    Are you installing one in a BMW?
  19. #44
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    Well. Not the best garage.... but it’s going to have to do the trick
  20. #45
    Mar 2012
    Renton, Wa
    98 m3
    Seems like you have everything you need in there!
    1989 535i - sold
  21. #46
    Nov 2015
    kelowna
    Z3 Coupe 3.0
  22. #47
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    Well its all mounted, everything fit extremely well. one issue, i seemed to have missed the part where the z# shifter hole is way further back than the E36
    the shifter pretty much lines up where the airbag computer is
  23. #48
    Indianapolis
    F30 328d X-Drive
    nice progress!
  24. #49
    Mar 2012
    Renton, Wa
    98 m3
    That thing is way back there
    1989 535i - sold
  25. #50
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    Chucks mounts work perfect on the Z3, everything clears perfect. One thing i did not account for and not too much i could of done about it is the T56 Magnum shifter is 4" forward compared to the Fbody T56.... the hole is 8" off from being centered with the most reward T56 Magnum shifter position. Nothing another 500$ cant fix. https://www.sikky.com/product/t56-ma...elocation-kit/
  1. Turbo Z3 M Coupe vs Twin Turbo Gallardo [vid]
    By drdre0728 in forum Kill Stories
    Last Post: 11-27-2013, 11:06 AM
  2. Z3 E36/7 FS BMW NOAH Z3 Coupe Car Cover
    By Wojtek79 in forum Z3,Z4,Z8 Classifieds
    Last Post: 11-01-2009, 01:21 PM
  3. Z3 E36/7 OEM 3 series modified to fit a z3 coupe for sale.
    By wheelieh in forum Z3,Z4,Z8 Classifieds
    Last Post: 03-16-2009, 12:20 PM
  4. Z3 E36/7 WTB: Stock airbox for my 2000 Z3 coupe
    By Tackleberry in forum Z3,Z4,Z8 Classifieds
    Last Post: 03-11-2009, 08:47 PM
  5. Z3 E36/7 FS-Z3 Coupe Original ACS Rear Wing
    By Ian 2.0 in forum Z3,Z4,Z8 Classifieds
    Last Post: 03-04-2009, 02:43 AM
