Unfortunately I had no way of making the 3” down pipes work with the bottom feed manifolds. These top feed ones are not as nice looking but they alow for better down pipe and waste routing.
going to be tight on the plug wires??
Nice progress! Sucks that Precision and I think most other turbo companies don't offer mirror image turbos like the Nelson Racing Engines do.
www.facebook.com/Undr8dEmpireLlc Instagram: @UNDR8D_EMPIRE
Scarlet V2 - #Project333Ti - http://www.bimmerforums.com/forum/sh...(-Project333Ti)
1989 535i - sold
1999 M3 Tiag/Dove - sold
Many fancies here. Carry on.
how's the build coming along? I saw you were helping with the V10 Roadster build I am following on here. I am going back to the FD world of LS power as soon as my M sells.
1995 Mazda RX-7 Feed Widebody LS3 6-speed (Toy, project)
2010 Cadillac Escalade Luxury (Daily, Pulls my 18' car hauler)
2014 BMW 328d XDrive (Wife's Daily)
Have owned 4 other BWM's I no longer have.
Sorry huge delays. Lol.
Moved the turbos again... just no room to get 3” down pipes past the frame rails and manifolds.
Big hype!
great to see this is still coming along! I just put my LS1 RX-7 away for the winter. going to strip it down for paint, no money for turbos this winter.
8EE6B04E-9D71-4D45-BD7A-DB693DB21656.jpgF0328998-6145-4CEF-994C-A5F2871DA6E2.jpgC0224E55-609A-4F1B-831B-6807FC01D514.jpg2494C224-FB27-4620-9FF5-3AEFA23AB70E.jpg
been working on the plumbing. Unfortunately had to go under the cross member worth the 3” exhaust. Just couldn’t find another way. It it bottoms out I will try something else. But the low points are inline with the wheels. So speed bumps will not be a problem. Just something sticking up a few inches in the middle of the road could be bad.
the exhaust is dual 3” into a single 4” with a vibrant oval muffler.
cut and flipped bits around on the ABS pump mount to move it over about an inch.
Picking at the fuel system now, cut the bottom of the hanger off to fit this hellcat pump. Then to a 10 micron holley filter that fits in the stock hanger. feed in -8 and -6 return. all earls super stock pushlock.
nice to see you are still making progress on this. Do you think you will be able to fire it up this summer?
Just finishing up some little things under the hood. Getting a quote from Ron Davis for the radiator.
buddy CNC’d the 1350 u joint for me.
nice buddy to have!
What are you doing about heater hoses? Looks pretty tight in there coming off the water pump (from what i can see)
Gates and dayco make these ones with a moulded 90 and 3-4’ of hose. But unfortunately I will have some splices. Probably less than the factory BMW engine with its half plastic half rubber cooling system
yeah i have those hoses in my car but I dont have turbo stuff haha.
took this out today. Eyed up this winters project of getting a 8.8 back there...
but this time around I just took it out so I can run the -8 and -6 fuel lines
Just got caught up on your thread, great progress and fun build.
2002 BMW 525i - 6.6L LS Turbo Swap
Follow me on Instagram at @LantzFab
Link to LantzFab.com
Link to my Facebook page
Link to my build page
Thanks. Still have a few expensive parts to buy but after that it’s just the stuff that nickel and dimes you.
Just putting the tank back in. -8 feed and -6 return. With the walbro 525 hellcat pump
67735697-D3BE-408A-9A4D-1AF67219F683.jpg45B4A9E6-1BC8-4394-8149-ED40085F3FE7.jpg81F4F319-22DD-4466-9B9A-3FC1EAA2FD20.jpgC39E957C-561D-4380-A8C9-99ACEB2A892B.jpg
I didn’t want to use anything less than a 1350 u joint. Unfortunately the z3 is tight in that area. So angle grinder... hammer and welder sorted it out.
0C4504F6-D513-41A7-8DB0-E46B8933AC97.jpg95ADE1F7-D136-46AA-92B7-477F97EDB562.jpg3BA144D6-A01A-448A-B9D4-DF82E7D00E32.jpg075AB35E-5BB1-4252-BA86-14C391451F25.jpg
