Bimmerforums Upgrade Garage The Tire Rack
Results 1 to 3 of 3
Thread: Clearing calipers
    Dec 2016
    vero beach, FL
    1997 328ic
    Clearing calipers
    Is there a way to calculate if the wheel will clear brake calipers for sure without any spacers? This is on nonM3 e36 for 17" wheel ET 25 or ET 30? Is there a way to approximate that? At which offsets that this become a problem?
    m50 mani / AA c38-81 stage 2 / 12psi / AEM progressive w/m kit / stg3 SB endurance clutch + SS / 3.38 LSD / cdv + asc delete / stromung catback + cat delete / ebay coilovers + GC RSMs / square CSL wheels / ski-pass 8" sub
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    At lower than stock 41mm if risk a chance of running into issues. Anything higher (lower the number) than 41 starts to push the wheel outwards of the hub.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I thought it was the other way around. ET40 is towards the center of the car and ET20 is towards the outside, for example. Plenty have run E39 17 inch ET20 wheels on M3 with calipers bigger than non M and no issues with calipers. The issue is with rubbing the rear outer fender with anything bigger than 225/45 tires. You can't run 245/40 with 17 inch ET20 rear wheels.
  1. Minimum wheel size/offset to clear calipers?
    By MrMuddle in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 04-10-2014, 12:38 PM
  2. Any 15 inch wheel clear M3 caliper with spacer
    By hotshu in forum 1992 - 1999 M3 (E36)
    Last Post: 11-23-2006, 01:53 AM
  3. 17 x 8.5" DS II's don't clear ST40 Caliper!
    By Ollie in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 06-05-2006, 07:45 PM
  4. Will OEM 18s clear Brembo caliper upgrade with Euro rotors?
    By SilverState in forum 2001 - 2006 M3 (E46)
    Last Post: 03-14-2006, 11:47 PM
  5. 16" E36 wheels clear M3 brake calipers?
    Last Post: 12-13-2004, 10:37 AM
