Hello,
TL;DR: Resistors I can use which don't get scorching hot?
A couple days ago I bought a few Sylvenia 6418 "Cool White" LED bulbs to replace the bulbs in my trunk. I was so pleased by now White the actual light output was that I decided I wanted to use them as my plate light bulbs. I bought two more bulbs and two sylvenia 12v 6ohm resistors tonight. Installed one bulb and one resistor to see how I liked the look.
Wow, the resistor gets Hot! Which I knew going in; but Feeling(being burnt) is Believing. Even with proper mounting of the resistors on metal, I would be too paranoid driving around with these back there generating so much heat. Especially on a multi-hour long drive.
I have tried running LED bulbs without resistors in the past and experienced "Flashing" so I know I need them. Am I out of options? I hate how yellow and ugly OEM bulbs look.
Don't buy the shitty bulbs, I used to have the same problem and did the same thing.
I have in both of my cars actual bulb/housing replacements and they are 10000 times better than any bulb. Most now come with resistors built in, or external ones that cool much better.
Spend the extra money $40-60 on good ones you won't have problems, I have had mine in for 2+ years in FL heat with no issues.
not the exact one, but you get the point.
something like this http://bmw.iamgary.com/wp-content/up...1/IMG_0925.jpg
IG @Bsaintmedia | Cammed LS6 Swapped E36 M3 "The GMW M3"
The reason I bought the Sylvania bulbs is because the light output is a Perfect White. Not even the slightest hue of Blue! And the amount of light output is only about 5% more than the standard ones. If I went any brighter I Would be Ticketed. So unless someone can point to a specific Brand and Model of setup in your recommended style, which meets my requirements - I can't bring myself to gamble the money.
And since my main concern is about the Heat being released by Resistors, I won't make the gamble on a set with external resistors. I could end up in the same place I am now.
did you even read what I wrote...? I said nothing about them being blue.
These look factory... the ones I have are bright white and you would be ticketed for a flickering led before one that is too bright.
but do what you want, good luck
