lol, I quit updating my spreadsheet 3 months ago after it was 25% over budget
Whoah accountant; do you have to submit a purchase request form for anything over $500? just messing
Need a second set of books lol; see it only cost "this" much baby.
Helps me plan an outline. I start with a initial sheet and start adding to it. Eventually I'm usually flying by seat of pants but it's expected. Would be easier to plan if the build was OEM style . So for now an outline and color in the box helps compartmentalize. I could have OCD, but beer helps.
88 M3
91 318is
91 318i
83 320is
08 X3 3.0si
Trust me its not easy
1. PMP (project master plan)first for approval
2. RFP- request for proposal : i had to submit issued for construction specs and drawings accompanied by estimates
3. Submittals for each component
4. Anything above 300 needs to be directly approved by wife.
So far project is coming along
I am still waiting for my turbo.
Yesterday i got my ebay IC piping. Intercooler is coming tomorrow. Next Saturday i will pick up my flywheel.
I will have to fit the engine in the bay to figure the IC position and plumbing. Make all necessary brackets and pull the engine again and paint the bay.
Your car is really coming together , looks awesome. Our cars are very similar were both running turbo m10s ,megasquirt, safari beige, and aren't you on coilovers too? I really need to step it up now ! After seeing that manifold, i want one it looks sweet and flows like a mother i bet.
Those tubular a arms are awesome, you must have made those. I like your center console also , im going to make something a bit different. I pulled the heater out off mine and put seat warmers in the recaros.
Intacooola
Ebay special 18x12x3 2.5" in/out
There was some progress lately.
I put the motor back in to figure out intercooler piping, radiator brackets and wiring.
I also test fitted Volvo calipers.
I will need to slot em a little to fit properly.
And the last thing i finally got my flywheel back.
I still need to order arp clutch cover bolts.
5/16-18 x 2.00" will fit perfectly with 0.120" washer.
Borg Warner supposed to ship the turbo to AGP today. We will see they were pushing the ship date for almost a month now. If everything goes well i should have the turbo early next week.
I also started wiring harness and i found that i have wrong type of size 12 terminals for my amphenol bulkhead connector.
Things left to do.
Brakes
Eurometric bushings
Wiring harness
TO bearing setup
Engine bay paint
IC piping
Exhaust
And probably another bazillion of small things.
Engine side of my Amphenol bulkhead connector. Today i will finish the ecu side
So i got rid of the stock temp gauge and replaced it with Wideband.
I also tapped stock water/coolant neck to accept 3/8-18 npt to accept gm clt and autometer temp sensor.
My turbo finally shipped. Its arriving this Friday.
Plan for this week is to finish wiring. Figure out the TO bearing and add boost control to
Megasquirt
Looking very good. I particularly like the cluster/temp gauge work you did.
Thank you sir.
I continued with the wiring today.
I installed the bulkhead and started working on the wiring harness. I thought that i have red and yellow 18ga wire but i could not find any. But most of the wires are sorted and laid out correctly. Just need to pull couple additional wires for the ignition, injectors,pwm idle and boost control power.
I am also looking for triple fuse blocks.
nice harness work! be sure to shield that braiding when melting the heatshrink. that stuff will melt as fast as saran wrap if it gets hot.
Yesterday i modified fuel rail to accept -6AN fittings.
I also got some goodies from arp.
Clutch cover bolts.
Finally!!!
S252sxe with t3 .63 hot side
Next to k24
Injector harness.
Started some intercooler plumbing.
Since i am going with my favorite diving boards i had to figure out how to route the ic pipes.
So this is what i came up with.
Disregard ugly red coupling i will swap it later. This is the only 90 degree reduction coupling i had lying around.
Bumper shock brackets had to be relocated for the ic tubes to clear.
So the front valence will not fit with 2.5" pipe going under us bumper shock.
So i employed an angle grinder and a cutoff wheel. I cut area marked in the picture below.
Than i boxed it up.
Always FUN TO DRIVE - Build Thread & Tech info - 79 320/6 track car build thread -- Videos of track car -Adam in car Auto-x video - Start-up video - 4/2011 Adam's TOP BMW time San Diego BMWCCA - 4-5-15 Dyno break-in run new M20B25 - Exhaust Thread - Link
More wiring.
Tps, crank trigger, clt, temp gauge and oil dummy light.
I still have to wire the fusebox end, idle valve and boost solenoid and coils.
I will need to make the ls coil bracket to make a clean installation.
Also i found that the e36 318 radiator will not fit even with the slim fan.
I am going to run civic half width 2 core which will also leave some space for the oil cooler.
Water pump to fan clearance or lack of it.
Some sheetmetal work to fit the intercooler.
Ordered some goodies today.
Heatshield, civic radiator and 1.5" ss pipe for the dump.
Also made a prototype ls coil bracket.
