Results 1 to 2 of 2
Thread: Extreme coolant pressure
    Dec 2015
    Brighton, MI
    2005 645ci
    2005 e64 coolant hose to radiator blew off like a volcano!! Had just replaced the water pump due to suspected failure (typical high pitched squealing). At the same time did the thermostat, idler pulley, belt, radiator cap and of course coolant. Bled the system with vacuum system specially for our German cars . However I was not getting heat in the cabin. I assumed the system just hadn't built enough pressure yet. I plugged in the computer- the engine temp showed 230f radiator temp and 130f at radiator outlet. These temps after about 15-20 min of run time at about 55f ambient temp. Don't really know where to start at this point. Any suggestions? Thanks for your time in advance.
    Dec 2012
    Pittsburgh,Pa.
    2008 BMW M6 Convertible
    The place to start is where you just left off. Either the water pump or thermostat is bad or installed improperly or your coolant hose clamps need replaced. Go back over entire system and recheck everything, either defective parts or something wasn't done correctly.
  1. Need to rent: Coolant pressure tester (or kit), $25 for two days, Orange County / LA
    By LavaBurns in forum California sponsored by Avus Autosport
    Last Post: 10-03-2006, 10:06 PM
  2. Coolant pressure test in the MAR
    By ///2K in forum Middle Atlantic - US
    Last Post: 09-11-2006, 12:56 PM
  3. Where can i find a Coolant Pressure Tester ?
    By Zubehor in forum 1992 - 1999 M3 (E36)
    Last Post: 01-09-2006, 02:10 AM
  4. Coolant pressure tester in WI
    By murdoc158 in forum Great Lakes - US
    Last Post: 01-08-2006, 07:46 PM
  5. Excessive Coolant Pressure/Prestone warning
    By scottycs in forum 1992 - 1999 M3 (E36)
    Last Post: 04-01-2005, 10:37 AM
