Whoa! You're going high end with that "cheap" POS chassis. Not cheap when Mike's done I guess.
I've gotten nice stuff from as close as the Columbus area. They think they have bad weather down there, but it seems to be enough better than ours that their cars rust a lot less.
Got the car back with a welded diff, revshift bushings and subframe reinforcements and had some 4th of July fun
Diff started leaking a couple days ago. Got under it and the cover bolts were barely hand tight. re torqued them and topped off the fluid. They were torqued properly before. Anyone ever have that happen to them back out on their own before?
IG: allen_union
Took some photos of the new wheels. I like the fitment and are probably going to rock these as daily wheels.
Also test fitted the advans...
BMW e46 by Allen Best, on Flickr
Theyre just a little too wide in the rear and def too wide on the front. Ill run them whenever I am able to get the hard motorsport flares.
Future things to do with this car is just preventative maintenance MAF, PCV hoses, water pump and t-stat. Then I will hit up some local drift events and get to learning. I dont want to have to worry about this car failing at a track. I want to get to a track and be able to concentrate on my driving skills.
IG: allen_union
Welp just fried the clutch in "mexico/canada" practicing donuts and figure 8s. With 240k miles it was on its way out especially with my spirited driving so im not suprised. Anyone have a suggestion for clutch upgrade on a stock setup? Probably going to be down and out for a while. Since I will be under there replacing a bunch of shit I plan on doing ebay headers and a full exhaust so I can here the car instead of everyone else along with a bunch of other little maintenance things.
IG: allen_union
I've had very good luck with gripforce clutches in my cars.
I actually used a stock e46 clutch. It's holding great, as it should, being a brand new clutch. Reused my flywheel, since it had no play, and everything's perfectly smooth. My next clutch will be a stage one or two though, I see where a stiffer grabbier clutch would be nicer, but the stock one really does the job fine. Other than headers+exhuast, are you doing any power mods? Any FI plans?
Yeah I thought about going stock again but why not for a little bit more $$ just go to stage 1 or 2 as I know Im going to be beating the piss out of the clutch. I dont plan on going FI just because I highly doubt this engine will be able to handle it at the time that my skills catch up to my car and I feel I need more power. If that makes sense. Headers, exhaust, maybe CAI if when I do more research on it I feel it is worth it, maybe some sort of ebay tune to move the rev limiter up and delete the rear O2 sensor and take full advantage of intake and exhaust. Then if the car is still surviving after that and I run out of things to do with it I might do the m54 intake manifold and throttle body.
IG: allen_union
Anyone ever see anything like this before from the trailing arm buckets? I got these custom buckets from a guy on IG because they are more adjustable than the stock ones. but I guess I have to go back to the stock ones.
There a good place that has strong replacement trailing arm buckets?
IG: allen_union
I'm more concerned about that rust.
