Results 1 to 11 of 11
Thread: Valve Stem Seals
    Nov 2016
    New York
    645ci
    Valve Stem Seals
    Hi all, I bought my 2005 645 pretty recently and am now experiencing what I had known was coming all along. I have the blue/white smoke issue as well as a coolant and oil leaks from many different locations. I figured I would tackle the head gaskets, valve cover gaskets, timing cover gaskets and while i'm in there the valve stem seals. Are there any good diy's that outline how to do the Valve stem seals?
    Thanks!
    May 2016
    Scotland
    BMW E63 645Ci
    There is DIY on youtube how to remove seals using AGA TOOLS. I think it's easest way.
    Wysłane z iPhone za pomocą Tapatalk
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Jun 2017
    Irvine
    2006 BMW 645CI
    You are going to need to rent or buy the specialty tools. Renting is about $400, purchasing is way more
    Mar 2012
    Chico, CA
    2005 645Ci convertible
    Is there a way the heads can be removed with the engine in the car?
    How big of a job is this? Approx. number of man-hours?
    Thx
    2006 645c
    May 2016
    NJ
    03' BMW 540 M sport 6 sp
    Hello, I'm located in New Jersey and perform valve stem seals replacement on the N62 engines. I'm a 25yr BMW Master Tech and use the specially designed AGA tool kit. $2500.00 is the cost, ....new valve stem seals, valve cover gaskets, front cover gaskets. Usually takes 3-4 days. You can contact me here: roadracer490@comcast.net
    Nov 2017
    Birmingham,AL
    2005 645ci
    Does anyone know where you can rent the tool kit that All German Motors sells, think its the N62 valve steam seal kit...
    May 2017
    Albany ny
    2006 750li
    Quote Originally Posted by bama645ci View Post
    Go on facebook type in bmw aga tool. Hes a great guy and charges about 275 for a week. Dont quote me on the price. But hes very reliable and can give a few pointers. And now he sells a lot of the parts youll need for the job. Very good price
    Dec 2017
    Oregon
    2006 BMW 650i Coupe E63
    Why is it that there are no aftermarket VSS that will hold up better than OEM? As long as you are going to replace them, it would be nice to use a better quality product. Kind of like putting a faulty heart valve into a patient when you know it's going to fail.
    That's a great question.
    Dec 2017
    Oregon
    Quote Originally Posted by White94RX View Post
    Well, I have now heard that newer seals from BMW do not fail, and the original OEM versions were a 'bad batch'.
    You'd think BMW would cover this under Customer Goodwill, but I guess they figure if they last 100K miles, they're not THAT bad...
    And of course if they covered the Seals but not the Labor, it wouldn't really matter I guess...
  1. Valve stem seals...
    By hdriven in forum 1975 - 1983 (E21)
    Last Post: 05-28-2008, 04:03 PM
  2. Seeking advice on valve stem seals...
    By Fred in Houston in forum 1988 - 1996 (E34)
    Last Post: 09-26-2007, 09:09 PM
  3. How do you remove the valve stem seals?!
    By Pink Floyd in forum 1983 - 1991 (E30)
    Last Post: 10-10-2006, 11:43 AM
  4. Valve stem seals
    By mattd860 in forum 1983 - 1991 (E30)
    Last Post: 03-16-2006, 11:47 AM
  5. Oil consumption \ Valve stem seals
    By DeeM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 10-17-2004, 10:45 PM
