Results 1 to 6 of 6
Thread: Part number of stupid grommet where bowden cable meets interior door handle
    Aug 2016
    Los Angeles, CA
    yes
    What is the part number of the grommet that sits in the inner front door release mechanism, right where the cable attaches, on an E34 ('91 USDM M5 in my case)? My grommet exploded when I removed the door card (see below).
    The grommet is a probably supposed to be a cloudy white color when new.
    Can't find it on realoem anywhere.
    Hamburg, NY USA
    e23, e32, e34, e39
    52208238999 (clear)
    COULD be this one. I say could because my e32 had two types. One was just a little off and didn't hold the hook in properly. I THINK the other color is black though.
    Another part number for front grommet (same diagram number on Realoem) 51211937233 (no pic)
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    here you can see a pic and where they are installed http://www.realoem.com/bmw/enUS/part...999&series=E34
    Had the same problem on my E32, the grommets broke and fell out of place, door lock did not work anymore. On the E32 there are 2 different sizes, check with your VIN
    Jan 2005
    Japan
    per door 2 x black 51211937233 ,still available, although ECS says NLA, because they sell them in packs of 25 or 50 pieces now, in other online shops you can order any number.
    and 6 x clear ones 52208238999
    NYC & Long Island & So FL
    '93 740il '84 633Csi
    While this is an old thread, I have to prepare to open my door panels as my driver's door won't respond to the key to unlock. I checked Pelican Parts and the white grommets are $2.77@ and the black are $1.00@. Whaddaya gonna do? But it needs to be fixed. Also along with that order, I may as well buy a whole new set of the door clips as I am sure I will break a few.
    Jan 2005
    Japan
    Bought them in bulk as often needed for me and wrenching buddies, have both versions here and just measured them for you
    ................................total length......upper part dia....lower part dia
    black 51211937233.......5.3mm...............9.8mm....... .........6.9mm
    white 52208238999.......6.3mm...............9.6mm....... .........7.0mm
    Once we only had the white ones here on stock and also used them in the places where actually the black ones go, also worked.
  1. Part Number of BMW CD43 Business CD for E36
    By Daryl Morse in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 05-28-2006, 04:24 PM
  2. Part number of the ltw flag
    By Nadroj in forum 1992 - 1999 M3 (E36)
    Last Post: 05-25-2006, 11:32 AM
  3. anyboby know the part number of....
    By TraviE46 in forum 1999 - 2006 (E46)
    Last Post: 11-15-2005, 12:47 AM
  4. Part number for this grommet
    By shiipseki in forum 1991 - 1999 (E36)
    Last Post: 09-28-2005, 12:14 PM
  5. what is the part number of my cd changer?--11/94 build date
    By comptechgsr in forum 1991 - 1999 (E36)
    Last Post: 06-16-2004, 02:31 PM
