Can I please request a VIN option code list for this vehicle - this is apparently a security model, but built in South Africa - I am not sure if security models were ever built in SA. One of the VIN searches that I have done, show details for an E30, this plate is however fitted to an E23.
Use the top number, that at least shows as a 732.
https://www.bmwdecoder.com/decode/8093807
--Jay3->Sic gorgiamus allos subjectatos nunc
84 €735i manual, 88 528e/i
Motronic 1 and 1.3 wiring
Transmission & Diff gearing sheet
Thanks, seems the SA model details were not kept in detail compared to other countries, will try BMW SA directly and see if more info available.
Have you check the reference sensors on your bell housing?
The sensors fail, and the iron nugget on the flywheel can fall or rust off.
You can bypass your OBC by snipping and crossing two wires.
Sent from my XT1650 using Tapatalk
Vehicle information
VIN long WBAAA710809600766
Type code AA71
Type 323I (EUR)
Dev. series E30 ()
Line 3
Body type LIM
Steering LL
Door count 2
Engine M20
Cubical capacity 2.30
Power 0
Transmision HECK
Gearbox MECH
Colour LAPISBLAU (173)
Upholstery ANTHRAZIT (0150)
5400
Prod. date 1985-02-08
Order options
No. Description
215 POWER STEERING,DEPENDING ON ENGINE SPEED
226 SPORTS SUSPENSION SETTINGS
311 ELEKTRISCHER BEIFAHRERSPIEGEL
350 WAERMESCHUTZGLAS GRUEN, RUNDUM
400 SLIDING SUNROOF MANUAL
662 BMW Bav. CR Digital
680 MANUAL AERIAL
690 CASSETTE HOLDER
915 nur Boden konserviert
www.8coupe.com / Turkey Inventory
