I did the cam cap method to replace my lifters, twice. If done properly, it is not an issue. Just make sure the caps go back in the same spots. A lot faster than compressing the springs which also requires turning the engine to prevent valve damage (which is easy to do). The only other thing you have to do is back out the tensioner for this method.
______________________________
1992 750iL
