will 235/4/17 on 17x8.5 ET30 fit non-M e36 stock (convertible so rear sits little lower). will slight fender rolling be enough?
https://www.aspiremotoring.com/produ...qQEaAtcZ8P8HAQ
Hello - check out this article on wheel fitment and spacing; it's a great guide to see what works on your car. Best of luck!
Wheel Fitment and Spacing
-Dmitry
888.280.7799 | 6am - 5pm PST
Thank you Dmitry, very helpful table on that website. But I can't seem to locate what is the overall distance between mounting pad and the fender on non-M e36?
so...... assuming e36 factory clearance on 7.5"x17 wheel with ET41 offset to the fender is just 2". This implies wheel width: 7.5" * 2.5 * 10 = 190mm plus fender gap: 2" x 2.5 x 10 = 50mm minus the 40mm offset = 200mm total space to play with
so for 8.5" wheel with ET30 =>>> 8.5 * 2.5 * 10 = 215mm minus 30 offset = 185mm so I have enough space? to the bigger wheel fits in that fender just fine?!! assumming that the tire doesn't out much wider than 8.5"?
is my logic correct? I am assuming this is not an issue on the front fender since the wheel wells are much bigger than rear?
You can also run more negative camber and roll the fender lips. I would think that is much better than running stretched tires on the 8.5" wheels. The best tire size is 225/40R18.
If I can help let me know.
