Results 1 to 6 of 6
Thread: Headlight assembly removal
    Jan 2017
    USA
    528i
    I have a 2012 bmw 528i and I can not seem to get the drivers side headlight assembly out. I removed the four bolts holding the unit but can't seem to remove the unit. Do I have to remove the front bumper also. Please help
    Jan 2017
    USA
    528i
    I am very new to this forum and don't understand the response but I am glad to see a response
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    I will move the thread to the right 5 series forum
    Jan 2017
    USA
    528i
    Quote Originally Posted by shogun View Post
    May 2005
    Houston, TX.
    15 X5, 02 330i, 09 MiniS
    You don't need to take the bumper off, but it sure makes it a lot more simple.
    You'll want to take it loose from the fender, fender liner and across the top center where it meets the hood to give you room to wiggle the headlamp out.
    Tenured Automotive Service Professional - Avid BMW Enthusiast
    Correct. It doesn't have to come off completely, but definitely loosen it and partially remove it from the side you're working on. If you have to remove both headlamps, just go ahead and take the bumper cover off. It's not hard.
  1. Headlight assembly removal/replacement
    By davidaf in forum 2011-2016 (F10)
    Last Post: 08-23-2015, 08:14 PM
  2. Headlight Assembly Removal
    By FB528i in forum 1996 - 2003 (E39)
    Last Post: 11-29-2010, 05:13 AM
  3. 07 335i coupe headlight assembly removal
    By mikus in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 08-27-2010, 06:48 PM
  4. z4 headlight assembly removal
    By Z4toga in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 01-03-2008, 12:49 PM
  5. Headlight assembly removal...
    By fm.illuminatus in forum 1988 - 1996 (E34)
    Last Post: 11-30-2006, 12:53 AM
