Page 4 of 5 FirstFirst 12345 LastLast
Results 76 to 100 of 114
Thread: T56 Magnum Conversion
  1. #76
    Oct 2016
    Eagle, WI
    2008 BMW 335i Convertibl
    Great work!
    I love watching these swaps. I did all this for my RX7 swap. I had gotten my T56 Magnum Tranzilla from Rockland Standard Gear. That thing was bullet proof and shifted like butter. Sometimes the 2-3 shift can feel notchy on them but not this one.
    Have you considered going to an Ford 8.8 diff swap? Is the BMW diff as strong or stronger?
    I'm new to the BMW family. Sold the RX7 and bought my E93. (always wanted a convertible)
    This thread makes me think I might need to have a new project.
    Look! Before our very eyes, the future is becoming the past.
  2. #77
    Jul 2012
    Tucson
    1994 BMW e36 conv.
    Any updates?
  3. #78
    Aug 2017
    Savannah, GA
    E36 M3 Turbo, 2015 GTI,
    This is the most expensive porn thread I have ever read...
    Ken
    95' Dakar M3
    (GT35) 500whp+ and no clue what I'm doing....
    Steedspeed Twin-scroll Manifold, Wiseco 8.8:1 CR, K1 Rods, Supertech Valvetrain, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) Twin-Scroll 1.06 AR, Schrick Cams, TRM Tuning, 6 Speed Transmission, UUC Twin Disc Clutch, HFS-6 W/M injection, Zeitronix, Coilovers, Chassis Stuffs.
  4. #79
    Oct 2005
    Northern California
    95 M3, 15 Golf TDI wagon
    I've been building a barn for the past 9 weeks trying to get it done before winter hits. I hope to get back to this soon.
    -WTB: OEM Class 2 LTW GT wing with risers- Mazak
  5. #80
    Oct 2005
    Northern California
    So I got some time to work on the differential. I think I got it set up okay?
    What do you guys think of the pattern?
    Then I cut down the bolts for the 1350 adapter. and indicated it so it has minimal runout compared to the stock flange. The stock flange has .0005" runout and my driveshaft adapter has .0007" runout.
    Then I painted it so nothing will rust.
    Hopefully someone can chime in on the diff pattern? I noticed with the polished gears they seem to show the pattern differently. I have started putting the whole diff back together, so I think I will run it as is unless someone says I'll break it if I do.
  6. #81
    Apr 2006
    Minnesota eh?
    86 325es
    I think the pattern looks as good as its likely to get. I had the same issue with my REM polished ford 9" gears. It was just about impossible to read a decent pattern.
  7. #82
    Oct 2005
    Northern California
    Yeah I think the polish is the problem. I emailed DiffsOnline about it and he said that the gears seem to be super shiny. Thing is I used the same REM polisher as he does. Maybe they left mine in the machine too long? I dunno.
    I guess if the diff whines I'll know that something is up? Fingers crossed it'll be okay.
    I only have two more side shims I can go up to shift the carrier over so no matter what I am within .005" of being perfect.
    Here is what they pattern looked like with a .002" skinnier shim. You can see it sort of looks like a V going out towards the outside of the ring gear, which is showing too shallow of a depth.
    You can see here the drivers side carrier shim is the 3rd from the thickest ZF makes for getting the pattern and backlash correct.
  8. #83
    Oct 2005
    Northern California
    Finally had some time to work on this project. Got the rear subframe and differential in.
    So I have a question.....for those of you that have converted to this diff how did you hook up the speed sensor? My car's plug and the speed sensor plug are different.
    Got the new e-brakes assembled for use with the Massive Brakes BBK:
    Installed the newly plated rear hubs, wheel studs, and the DSS axles:
    So I am doing these custom rear 14" discs and I ran into a small problem. Lee from Massive gave me a drawing for these bushings to fit the larger rotors. His drawing is a bit off. I need to take off about .110" of my bushing so the brake pads line up on the rotor better.
    Rear big brakes installed:
    And finally the new wheels installed on the car:
    Transmission final install with clutch is next then I can order a driveshaft.
  9. #84
    Jun 2004
    The D, MI
    97 M3, 98 328i, 13 Cruze
    I think I swapped the e36 speed sensor in to the 210.
  10. #85
    Vancouver, B.C., Canada
    '97 M3
    More details on the wheels and brakes please.
  11. #86
    H-Town/Los Angeles USA
    bmw e36 328i 4dr saloon
    Looks awesome! Nice work
    1996 328i (m52B28US) OBD1 euro ZF 5spd. 3.23LSD conversion / Chem. PnP Head/ DINAN stg.2 CHIP/ VAC race valves/ S52 cams/ A/C delete/ fan delete/ Washer Fluid resv delete/ ARP head studs/ Cometic 140MLS / VAC Solid Engine/trans Mounts/ CAI / 2.5"Borla race exahaust/ NGK R spark plugs, M50 Mani, S50 Oil Res, Riot Racing HFTB, SAMCO Hoses, JBR FW, X-Brace, Mtech Front Bumper, RE RSMs, stoptech SS lines, Bilstein sports, H&R Race Springs, S52 Reinforcement plates, Kosei K1 w/ bridgestone RE960as, Brembo/stoptech slotted rotors, M3 Trailing arms, M3 Calipers, M3 Axles, ACS strut brace, weight reduction.
    http://mbuild.blogspot.com/
  12. #87
    Oct 2005
    Northern California
    Quote Originally Posted by chikinhed View Post
    I went with a kit from Lee at Massive Brakes. Its basically you custom build whatever you want.
    The rear kit that you see is his 332mm kit with a Wilwood Superlite 4 piston caliper. I made a spacer bushing to space out the caliper to accept the 14" rotor. The 14"/355mm rotor is the largest that Wilwood specs for this caliper, so I am not doing anything crazy or out of the norm. Also, Lee has the only kit that I know of that will maintain the factory rear e-brake drum, which I like since this is a street car.
    https://www.wilwood.com/Calipers/Cal...no=120-13232-N
    The front kit I bought is a 14.25"/362mm rotor with the Wilwood Aero 6 caliper. The front is a 6 piston. You can get the Aero 6 in a 4 piston if you wanted. Also you can get the front caliper extra wide with .80" thick front pads, but Lee says that's more for endurance racing so I did not spend the extra money on it. My front pads are .67" thick.
    https://www.wilwood.com/calipers/Cal...no=120-13294-N
    Both sets of calipers are Nickle plated because they will withstand the heat better and not discolor like powder coating. You can save some money and go with anodized as well.
    The other caliper upgrade I didn't do was the Thermlock stainless pistons. They are supposed to keep heat transfer into the fluid from happening. The calipers I bought do have stainless steel pistons though, which should help because the heat properties of stainless.
    Let me know if you have any more questions.!
  13. #88
    Norristown PA
    mostly bmw
    Wow... lovely build.
    95 turbo 330ti. 01 maxpsi m3 e85. 01 m5. 01 m coupe. 03 AIM 996t e85. 06 x3 w/Meyers plow and winter daily. Prussian Motors is hiring!! prussianmotors.com/jobs
    Current e39t LS Turbo swap: https://www.bimmerforums.com/forum/s...LS-e39-Touring
  14. #89
    Oct 2005
    Northern California
    Quote Originally Posted by bubela View Post
    Thanks man! Takes me a while because I work too much, but it'll get there one day.
  15. #90
    Texas Hill Country
    '98 Turbo M3, '17 M3
    Looking good Paul! On the connector, can you take your stock sensor out and use in in the larger differential? I don't remember what I did, but I'm guessing what I just asked or cut the wires off and spliced them. What wheels are those?
  16. #91
    Oct 2005
    Northern California
    Ill mess with the speed sensor here soon. Thanks for the advice guys!
    These wheels are my new temporary wheels until I do something to put wider tires under this car...the e46 M3 grafted fenders like you were talking about or some widebody. Not sure what to do. I am not in love with any particular widening method at this point. I used to like the Esquiss kit, but it doesn't fit very wide tires.
    The wheels are Apex SM-10 18x8.5 et35.
  17. #92
    Oct 2005
    Northern California
    Got a little more time on the car. I need to get the car on a lift to finish the transmission install now that the rear end is back on.
    Removed the front spindle to nickel plate them, but with a 23 year old car they still looked brand new.
    Replaced the front hubs since they were off and installed the Hard Motorsport backing plates for BBK cooling.
    Front big brakes installed:
    I'm still not the biggest fan of the wheels. Maybe I'll like them better once it is set on the ground.
    I am thinking of jumping on that group buy for the JRZ RS Pro double adjustables. Does anyone have an opinion on those vs the MCS 2 way?
  18. #93
    Oct 2005
    Northern California
    The car is finally under the knife again.
    Transmission has been permanently installed......for now......I hope.
    Quick Time bell housing went back for a larger starter cup/cover. When they fixed it they powder coated it and made it look nice and new.
    Clutch installed and I checked the runout on the red aluminum pressure plate. It was .0004" so all good there. Well in spec.
    Tilton throwout bearing installed. Still need to figure out how to plumb it. Anyone know how to convert from the BMW flare to the Tilton style flare? I was thinking of getting this to adjust pedal position??? Maybe Perry can chime in.
    https://www.summitracing.com/parts/r...BoCj-EQAvD_BwE
    Driveshaft is complete. It is 38" long 3" DOM plus the 1350 yokes. I used a nice Sonnax transmission yoke. And my custom yoke. The driveline shop says it will be good for 1500hp easy. They have done several drag cars with this tubing. I'll trust them. A chromoly driveshaft would have been double the price.
    The driveshaft is very close to the drivers side e-brake line. Not touching but close. To give a little more clearance I removed the rear washer I put on the subframe and left the front one since the large diff conversion kind of points the diff up towards the gas tank. This seems like it will fix any touching. Also this makes the diff more level in the car.
    I didn't know about the reverse lockout solenoid on the T56 Magnum transmission so I ordered this control module and all of the wiring to go with it. This looks at the speed sensor in the transmission and activates the lockout solenoid under 5mph. That should be here next week.
    https://shiftsst.com/tremec-6-speed-...ol-module.html
    I am still figuring out the e46 control arms in the rear of the e36. Looks like I just need longer swaybar endlinks and it should be good.
    My really big rear brakes are showing a small issue with the length of the rear lines. I may order custom length brake lines later.
    I like the new Apex wheels. They look nicer once the car is on the ground. Car is super dirty though...
  19. #94
    Jul 2002
    Long Island, NY
    98 Turbo M3, 04 E53 X5
    Looks good!
    How much $ do you have into it as far as parts? and what tq will the clutch hold?
    98 Fern Green M3/2 - Precision 6870/AR Designs Twin Scroll/RK/E85
    2017 Toyota Tundra Crewmaxx - Family Whip
    2011 Pierce 75' Quint - Fire Apparatus West Islip FD
  20. #95
    Jul 2005
    PEI, Canada
    2001 330i
    It's nice that Quicktime took care of you.
    To date, I have not received a single reply to my emails to them.
    Nice product, horrible customer service. (I even provided the measurements for how to fix it!)
  21. #96
    Apr 2006
    Minnesota eh?
    86 325es
    For the hydraulics you need to get an adapter to screw into the master cylinder to adapt to a -03 an line. I believe you need a male 10mm bubble flare to male -03 an. Then just figure out the length and order a premade -03 braided brake hose from all star. The end that goes to the master will need a 90 degree end.
    You will also need a remote bleed kit or you will never reach the fitting. It’s just a bleed fitting that you put on the end of a 12” or so brake hose. Summit has them for a few bucks.
  22. #97
    Oct 2005
    Northern California
    Quote Originally Posted by NY98M3 View Post
    Looks good!
    $3000 for the transmission
    $800 for the clutch
    $850 for the bell housing
    $400 for the adjustable throwout bearing
    $500 for the driveshaft
    $400 for the flywheel
    $200 for odds and ends, wiring, module, fluid....
    I think the clutch is rated for 1010flt-lbs
    Quote Originally Posted by PEI330Ci View Post
    They have been good to me. I was one of the first to buy the product. I have several emails to them and they called me when I reported what you found. You have already fixed yours so I am not sure what you would want them to do at this point. I have had an opposite experience. So far they have had great customer service. Answering phones on the weekend. Sending me extra parts. Fixing the bell for me a year after I purchased it. I am sorry you have had a bad experience. Maybe try giving them a call.
    Can you help me out with some Summit links to what I may need?
    The Tilton throwout bearing has two lines coming off of it out of the transmission. Not sure if I need a remote bleeder??
    Can I just adapt from the hard line in the transmission tunnel to the Tilton? Is there a point to redo all the plumbing all the way back to the master cylinder?
    I could upload more pictures if that would help.
    Thanks!
  23. #98
    Jul 2005
    PEI, Canada
    2001 330i
    Quote Originally Posted by 3literheater View Post
    I think the product will be a good buy for everyone going forward.
    You're car looks great! I hope you get to enjoy it for a long time.
  24. #99
    Oct 2005
    Northern California
    Thank you! I work so much progress is very slow. I have piles of engine components for a motor I haven't assembled yet haha. One day it will be cool...
  25. #100
    Apr 2006
    Minnesota eh?
    86 325es
    Can you take a picture of what’s attached to the release bearing and the end of the clutch hardline?
  1. New T56 Magnum
    By Schitzo in forum Engine Conversions
    Last Post: 11-08-2014, 06:34 PM
  2. T56 Magnum into an E46 (M3 or 330ci)
    By betaflame in forum Engine Conversions
    Last Post: 02-01-2012, 04:40 AM
  3. LS1/T56 conversion in a 325is
    By M3 Muscle in forum Track Car Builds
    Last Post: 05-28-2011, 10:12 PM
  4. LS1 / T56 into e30 conversion parts for sale
    By Derek 350i in forum 1983 - 1991 (E30)
    Last Post: 12-07-2006, 06:29 PM
  5. LS1 / T56 into E30 conversion parts listed on ebay.
    By Derek 350i in forum BMW Parts For Sale
    Last Post: 05-30-2006, 11:44 PM
