Results 1 to 9 of 9
Thread: INPA Error IFH-0009 NO RESPONSE FROM CONTROLUNIT.....
    Jul 2016
    Columbia, SC
    01 325i, 05 330ci, 07 X3
    I installed the INPA software per instructions. I can get into the software and the battery and ignition lights are black as they are supposed to be. When I go to E83, Body and select Airbag I get this error. The cable is the K+DCAN and the light comes on all the way up to the point where I select Airbag, then goes out with the error above. The ignition is like it's supposed to be. Using Windows 10 64 bit. The COM port is set to 5 and verified in the .ini file. I also have the ISTA software but haven't installed that. Not sure if it's required or not. All I'm trying to do is turn of the passenger occupancy airbag light on the dash after installing a bypass circuit.
    I see a lot of people have this problem but can't seem to find a thread with a fix. Any help would be appreciated.
    Jul 2004
    Houston, TX
    36 Cylinders
    What production month/year is the car?
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Jul 2016
    Columbia, SC
    2007 E83 X3 3.0si
    Got the exact error on E46 2001 325i.
    Jul 2004
    Houston, TX
    36 Cylinders
    It's very important to post the production month and year of your car. Its on the driver's door jamb.
    You need to bridge pins 7&8 of your OBD cable, and try then.
    -Abel
    Jul 2016
    Columbia, SC
    Says AG08/06, so I'm guessing Aug 2006. The cable is supposed to work as is, but I can try that.
    Jul 2004
    Houston, TX
    36 Cylinders
    You definitely need to bridge pins 7&8 for your 2 car models.
    -Abel
    Jul 2016
    Columbia, SC
    No go with pins 7 & 8 being jumped. Different error now. ZAE, BAE, ZAE2.... etc, etc. Waiting on another supposed plug and play cable with software.
    2001 325i
    2005 330ci vert
    2007 X3
    Jul 2016
    Columbia, SC
    I received a new cable and software disc today. Installed the INPA software with cable drivers and received the exact error IFH-0009. I then tried the old cable that I jumped the 7 & 8 pins as suggested and still had a problem. I checked the ODB.ini file and found it was set to com5, so I changed it to com1. I also had to copy it to the Windows directory because it wasn't working from C:\IDAIBAS\BIN. I also put a copy in System32 just to be sure. Everything works after doing that. I do get a pop-up saying language mismatch or something like that, but I can get in a do what I need, though the error is in German.
    2001 325i
    2005 330ci vert
    2007 X3
    Nov 2018
    poland
    525eds
    reviving old thread. IFH0009 is now a problem. Car 525TDS Year 1997 month 11. Can someone advise please.
  1. HELP! IFH 0009 No Response From Control Unit.
    By forzam in forum Diagnostic Software
    Last Post: 09-18-2013, 03:27 PM
  2. INPA error IFH-0009
    By xxxjecxxx in forum Diagnostic Software
    Last Post: 09-11-2013, 06:30 PM
  3. INPA Error IFH 0009
    By 4enjaM87 in forum Diagnostic Software
    Last Post: 05-27-2012, 11:20 AM
  4. diagnosing gear light - DIS error= no response from TCU
    By paulmer in forum 1996 - 2003 (E39)
    Last Post: 04-29-2012, 12:22 AM
  5. tire size question? no response from the tire tread.
    By Coucoui 6 in forum 1992 - 1999 M3 (E36)
    Last Post: 01-12-2006, 01:31 AM
