Hey Everyone, I recently bought a 2008 335i and I'm looking to start modding. So far all I've done is maintenance to make sure the car is ready for the increased power. I'm having my spark plugs done next week and a walnut blast the week after. After that, I want to add power. I am NOT looking to go FBO. I just want to tune it and forget it. I'm not interested in running meth or E85 or upgrading the turbos. With that in mind, what would be the best option for me when it comes to tuning? A JB4 or MHD? Which provides more power? Which is more reliable/safe? If you think I should get both, please explain the benefits of running both. I'm a newbie so I don't really know how all this works. Thank you
How much of an increase in power are you looking for?
-Dmitry
888.280.7799 | 6am - 5pm PST
Check online, there is lots of info on Dyno numbers for all mods and stock. Here is one just from Burger Motorsports JB4
http://www.burgertuning.com/images/jb4_dyno/dyno1.jpg
With just a tune expect around 315 (stock is 270ish).
I am assuming you want to be able to easily go back to stock and not get crazy with mods but you should get what you want with just adding an intercooler so you can go with stage 2. Get one w/ oem hookups like the Mishimoto so install is quick and easily reversible.
Cheapest way to get to 330whp IMO.
All great advice guys - I've also heard really good things about the Cobb tune in general.
-Dmitry
I've been trying to figure this out for myself for a while now.
Some say JB4 w/BMS backflash, others say the MHD DME flash+maps alone, some say the JB4 alone is enough. It's very confusing.
I can't answer your question. But I can give you some insight.
1) JB4 is NOT hard to hook up, but you do have to follow a lot of directions pretty carefully. Again, not hard, just a little nerve racking if you don't do things like this on your own (normally)
2) the MHD Flasher is EASIER, but even more nerve racking because if you have a hiccup, your car is dead till you get it right.
3) the JB4 alone will run you $400. It gives you some cool stuff besides power. The backflash will cost between $125-$200(?) depending on if you already own an android device (MHD method w/BMS license) or if you go with the BT cable method (VERY expensive cable, but no license fee).
4) the MHD tune will cost less overall, even if you have to buy a cheap android tablet. You just have to buy their maps packages, which are priced fairly. May be your best route, considering your goals.
5) I THINK that if you want to eventually do meth, you'll want/need the JB4, but I could very well be wrong.
Keep in mind...I'm a noob as well...keep reading and asking questions -- do not go by what I've told you, please.
// Radar //
2010 E60 535i N54 {sleeper}
M-Sport, Alpine White w/Natural Brown Leather
Coilovers, APEX Race Wheels
Trebila-tuned motor, xHP Stage3 tranny tune,
FBO+Meth FUN!!!
Yeah agreed on jb4. It's a matter of what options and other possible mods you want. It's the first step, after that you'll spend more on others, like down pipe, boost pipe, etc... I like my jb4 for the gauges on it I can monitor. I have the Bluetooth option and love it. It's not too bad installing, there are videos that are excellent, I did myself and I don't do electrical. But this was pretty straight forward. Know that if you go with down pipes you'll get doing more bypass wiring to eliminate codes either way. I'd suggest planning all you plan to do and in the long run and determine what you need that way. There are guys here whom likely have that exact set up and can give you their $.02
Sent from my iPad using Tapatalk
FBO+Meth FUN!!!
Jb4 will automatically hide downpipe code, no need for any additional wires
Cant go wrong with either one.
Power is adjustable on both so it same power gains
Both are very reliable and safe
Running both is not beneficial unless your car is heavily tuned and running E85
We offer 14 days money back guarantee on the JB4 , give it a try
Order Link
https://www.x-ph.com/burger-tuning-n...ormance-tuner/
The JB4 will automatically clear the codes using menu option 1-3, which prevents a check engine light (see the list of steering wheel commands at the link below). However, the downstream O2 sensors still tell the computer there is an issue, and the JB4 is just suppressing the check engine light on the dash.
http://www.n54tech.com/forums/showthread.php?t=10605
all I want to do is a tune and downpipes and maybe an FMIC if my car isn't running well. And truth be told, I'm only really interested in DPs and FMIC because people say they're healthier for the car and help keep the turbos running strong longer. But besides that, I have no interest at all in going FBO or running E85, meth, etc. so with that in mind, which would be the best, safest, more reliable tune? JB4 or MHD?
I looked at Cobb, JB4, and MHD and went MHD just because it's so easy to use off the android app, and it's so inexpensive at $217 for everything (already run a good LG android phone). I bought the tunes, the monitoring/logging, and code reading, and haven't had a problem with them yet after repeated use. The initial tune, in my case going from stock to Stage 1, took ~40min, but any changes thereafter, including the checkbox options like linear throttle mapping, etc, or changing to Stage 1 + FMIC, took just over 2min each. You can display gauges, pull codes, flash tune parameters, all much cheaper than any other tune out there. JB4 has the steering wheel controls which I thought was cool, but I'm a tune and forget guy, so MHD it was.
The MHD cost was a large determining factor for me, since I knew a higher mileage car like mine would likely need more work post-tune.
How right I was, as I had to walnut blast, change coils and plugs, install new injectors, and change the tranny fluid to get things running the way I wanted them to. Now it runs great and I have no fears pushing on the go-pedal.
I’m looking to purchase one of these two in the near future. I’m looking to make around 450-500whp for my N54 which one would be the best for me?
Making that power level safely would require larger turbos, extensive supporting mods, and supplemental fueling. You would likely want to run a JB4 with backend flash. The JB4 can control your supplemental fueling and offer several safety features, but you should still run a backend flash.
Keep in mind that 450-500whp is really pushing the limits, and things will get VERY expensive.
Is anywhere around 400hp too much for mhd?
MHD stage 1+ with just an intercooler puts down about 360rwhp. Stage 2 with all supporting mods puts down 390ish rwhp. Crank horsepower will be 18-20 percent higher than rear-wheel horsepower.
Ok and for mhd you can buy other maps from companies like emp right?
Exactly, you can use the MHD flash license to flash maps from other tuners.
