Page 54 of 70 FirstFirst ... 429444546474849505152535455565758596061626364 ... LastLast
Results 1,326 to 1,350 of 1742
Thread: 2017 what did you do to your e38 today?
  1. #1326
    Aug 2015
    Oconomowoc, Wisconsin
    01 750il, E38/9 Parts
    Quote Originally Posted by danieljames View Post
    Decided to run 35mm bolts and these heat-treated washers. I super glued them together to get the right positioning and she bolted straight up. The clearances were really good.
    Sent from my VK810 4G using Tapatalk
    Out if curiosity, why are you running an M60 in it?
    Sent from my Nexus 6P using Tapatalk
    --- 750il Maintenance/Restoration Thread --- E38/9 Parts Cars --- YouTube Channel ---
  2. #1327
    Feb 2012
    NSW, Australia
    2010 BMW F10 528i
    My drivers side mirror got knocked by a passing car (I assume) while I was at work one day so I swapped the mirror that I got off my parts car on today. All went well. I decided to use this opportunity to change the door lock actuator at the same time considering the door panel was off. Well that didn't go to plan at all. My remote wasn't unlocking or locking the door previously. Now, the door won't even open using the inside handle, and I can't lock the door using the key or remote! Such a shit job too, but I had to put it all back together so I could drive back home (was working on it outside near the shed that I lease). I'm going to have to pull it all back apart and see what's going on.
    I also swapped the ABS module over and it got rid of the brake and ABS warning lights, but the traction control light is still there all of the time. Any ideas?
  3. #1328
    IL
    2000 740i sport
    Quote Originally Posted by Jimmy E34 View Post
    Needs steering angle calibration...
  4. #1329
    CT
    E38
    Quote Originally Posted by purplecty View Post
    What about for those of us who tried four modules, calibrated the steering angle, and still have the DSC light? The code is precharge pump, so they're saying it's probably the actual pump itself. Is that feasible?
    E38 M Sport 6 Speed MANUAL
  5. #1330
    IL
    2000 740i sport
    Quote Originally Posted by shanecarmaster1 View Post
    Have you jumped the pump with 12v to see if it turns on?
  6. #1331
    Jan 2017
    North Carolina coast
    2001 740iL Prod 4/2000
    It can certainly be the precharge pump. If the lights remain off when starting until you hit about 25 mph, then check the pump for operation.
    Mine was not working when purchased, same scenario.
    Tim's excellent guide:
    http://www.meeknet.co.uk/e38/ABS/Index.htm
  7. #1332
    CT
    E38
    Quote Originally Posted by oldroller View Post
    I haven't tried jumping it yet. DSC and all the ABS lights used to stay off until about 25 mph. Now with the new module, the ABS lights stay off all the time, but, the DSC light is lit from startup no matter the speed.
  8. #1333
    IL
    2000 740i sport
    What is the error stored in the dsc module now?
  9. #1334
    Aug 2013
    Finland
    1999 540i M-sport
    Put back on my rims and lowered the car after inspection.. but seems like I lowered it a bit too much.. barely passing over my bump to get home, have to raise the front 2cm.
    Отправлено с моего SM-G935F через Tapatalk
    -E34 M60B40 + Tremec TKO 600 (sold)
    and sadly no old BMW anymore, only high powered Seat Leon Cupra 4Drive as a daily driver.
  10. #1335
    Feb 2012
    NSW, Australia
    2010 BMW F10 528i
    I've replaced my precharge pump already, but I don't think there was a problem with my old one in the first place. Both turned on when I connected them to 12v so I think I'll give the steering angle sensor calibration a go and go from there I guess.
  11. #1336
    Apr 2017
    Hampton va
    95 740i, 89 735i,
    Quote Originally Posted by nike32 View Post
    ?????????? ? ????? SM-G935F ????? Tapatalk
    What kind of emblems are those?
  12. #1337
    Aug 2013
    Finland
    1999 540i M-sport
    Quote Originally Posted by ibumpers View Post
    They are custom made.
    Logo itself is a Russian, Smotra car group,
    You can find it by googling smotra logo.
  13. #1338
    Apr 2017
    Hampton va
    95 740i, 89 735i,
    Sick
  14. #1339
    May 2012
    1991 850i
    Owner of smotra in jail already for quite some time
  15. #1340
    Aug 2013
    Finland
    1999 540i M-sport
    Quote Originally Posted by pavrom View Post
    Yeap and probably will be there for a long time, thats what you get when trying to dig under police.
  16. #1341
    Aug 2013
    Finland
    1999 540i M-sport
    Drove with my best friend and my son and took some photos.
  17. #1342
    Nov 2003
    Lake Forest, IL
    01 740i,E93 M3,E30 325is
    Got a few things done today.
    First I had a broken right mirror, when it folded it would keep spinning, the gear was shot so the motor would keep spinning. Also even when it was locked open it was loose and would shake when I drove. I found an aftermarket one on Ebay, I thought I would try it out, it worked perfectly and an exact fit. Its fold, heated and electrochromatic.
    http://www.ebay.com/itm/S-TEC-OEM-Si...72.m2749.l2649
    Anyway here is the old one, and then the new one in place, I just switched the glass and cover over.
    Next I had the yellowing of the tail lights like I am sure many others on here have. I stupidly didnt take a before picture, but here is one for reference of someone else's car, mine basically looked the same, maybe a little worse.
    I bought this product its has multiple steps including a UV coating at the end to prevent the sun from damaging it further. I may try this on my headlight and foglight glass next it works really well.
    Here are the results, I am very happy with them, better then I expected.
    Last but not least while I had the door panel off I put on the Chromeline speaker covers that have been sitting in my garage. I still have to do the other doors
  18. #1343
    Sep 2014
    Chicago, Il / Denver, Co
    '01 DINAN7 '03 M5
    Very nice result with the taillights, they sure look like new
    Instagram.com/nordmanmg
    Your current situation is not your final destination
  19. #1344
    Nov 2003
    Lake Forest, IL
    Thanks! it takes a while but I was surprised at how it came out.
  20. #1345
    Aug 2013
    Finland
    1999 540i M-sport
    Quote Originally Posted by Staszek View Post
    If you have prefacelift, wont help on headlights and fog lights as they are made from glass.
    This will only work for plastic.
  21. #1346
    Nov 2003
    Lake Forest, IL
    I have a facelift which the headlights are plastic. I do need to check the fogs though I cant remember.
  22. #1347
    Sep 2014
    '01 DINAN7 '03 M5
    Picked up OE M5 mirrors in matching imola red for my 7
    and replacement AMP for my M5
  23. #1348
    Aug 2015
    Just putting this out there, if there's anyone in the Milwaukee/Madison/Chicago area with an Orient e38 that wants to do a facelift upgrade, hmu
  24. #1349
    IL
    2000 740i sport
    Order Bilstein B4 rears yesterday from FCP and were at my door today... Talk about speedy service...
  25. #1350
    Nov 2003
    Lake Forest, IL
    Ohhh let me know what you think of them. I am about to order them for my car as well as a suspension refresh, I need to get that done this fall.
  1. 2016 what did you do to your e38 today?
    By 1badturboe38 in forum 1995 - 2001 (E38)
    Last Post: 01-01-2017, 07:03 PM
  2. 2015 What did you do to your E38 today?
    By Mayorchuck in forum 1995 - 2001 (E38)
    Last Post: 01-06-2016, 03:36 PM
  3. 2014 What did you do to your E38 today?
    Last Post: 01-01-2015, 03:13 PM
  4. What did you do to your E38 today???
    By kooljess in forum 1995 - 2001 (E38)
    Last Post: 01-30-2014, 12:28 AM
  5. What did you do to your E36 today?
    By Eurodriver in forum 1991 - 1999 (E36)
    Last Post: 01-09-2008, 08:54 PM
