Page 34 of 70 FirstFirst ... 924252627282930313233343536373839404142434459 ... LastLast
Results 826 to 850 of 1742
Thread: 2017 what did you do to your e38 today?
  1. #826
    NYC
    01 740iL & 92 GTI
    Damn MJ Doom... this just got real! MJ Doom been on the quiet tip stacking up his mod list looking foward to the final product, I bet it's going to be killa!
    No BITCHASSEDNESS!!
  2. #827
    Mar 2008
    Thousand Oaks, CA
    2007 Alpina B7
    Quote Originally Posted by MJ DOOM View Post
    Replaced a couple of power steering hoses and the ps reservoir today.
    Air struts came in too today. Found this company called AirBFT that makes a kit for the e38. From research it looks like they're the parent company that supplies airbags for all the Taiwan style bag over coilover setups. (K-Sport, D2, etc).
    Going with Airlift 3P air management.
    wow......Michael Jordan Doom...
    2000 740i Sport
  3. #828
    Chicago, IL
    2001 BMW 740IL
    Thanks fellas, I'll update soon.
    Spaceships & Woodgrain.
  4. #829
    Mar 2004
    Tyler, Tx
    '01 740i Sp, '07 335i
    OK Fabian, after your comment the other day, I said why not? So 150.00 later for two new door trim strips and then relocating the //M emblem to the front trim instead of the clearance light..
    from...
    to this...
    http://i293.photobucket.com/albums/mm71/krallopian/darthSigTest2_zpsn6zkw5id.jpg[/URL][URL="http://www.facebook.com/pages/DFW7-Dallas-Fort-Worth-BMW-7-Series-Club/300942239566"]DFW7 on Facebook/URL]
    "The Last Great e38" 2001 i Sport - Born'd on date 1/01 Cosmos/Grey - 32.8K miles - 2 1/2 " Custom Exhaust, Center “X”over , Modified OEM rear bumper, M5 style trunk spoiler, M6 OEM wheels, M3 Steering wheel with working paddle shift & CF trim, Bi-Xenon upgrade, 13mm Rear sway bar added, SS brake lines and bronze bushings, Cross drilled rotors and painted calipers, Akebono pads, Zionsville aluminum radiator & exp. tank with electric fan, Sprint Booster, BluTooth conversion, MKIV Nav., Custom wood cupholder, DUDMD Tune, Orien V2.5 LED Angel Eyes, Evans waterless. Recently added grey faced //M5 Cluster - all gauges functioning. Changed the grey carpet to black and topped off with GG Bailey front/rear mats[/SIZE]
  5. #830
    IL
    2000 740i sport
    Quote Originally Posted by TxDarth View Post
    from...
    to this...
    Did you put the pics in backwards order? The from this looks better?
  6. #831
    Mar 2004
    Tyler, Tx
    Quote Originally Posted by purplecty View Post
    No unfortunately - the camera pics up everything. After looking at those I got out the GumiFugi stuff and redid both trim pieces. looks better now. For some reason they did look good in the longer strip tho.... You know me can't leave well enough alone. I really do like these and the mod overall but it has now become expensive - $150.00 for the emblems and frames, then another $150.00 for two new trim pieces.
    The whole idea was to get rid of the clearance lights...I had painted them black, from heat and whatever they still looked bad and I really didn't care if they lit up or not, would rather they didn't. They are now taped up and inside the fender so I didn't have to code the error if I just unplugged them.
  7. #832
    Mar 2008
    Thousand Oaks, CA
    2007 Alpina B7
    from...
    to this...
    Looks great mate.....So its a Sticker? What I meant is the M5 E39 driver and passenger door mouldings are same length as E38, not the rear doors obviously. The E39 M5 moulding has an indention for the M5 badge or in you case the ///M badge..
    2000 740i Sport
  8. #833
    Mar 2004
    Tyler, Tx
    Quote Originally Posted by cazal740i View Post
    Not really a sticker = it is a raised plastic plaque that mounts in a frame and then has three clips to hold it in place from the back. The clips are not required tho and they are $3.xx a piece. I just glued it in in both cases from the rear, but it does require a rectangular hole to be cut in the trim piece. I believe they are from an '03 540 with the M sport package. https://www.realoem.com/bmw/enUS/sho...diagId=51_2259
  9. #834
    NYC
    99 IL/13 SXT/04 Audi A4
    Quote Originally Posted by Alpine 7even View Post
    Finished my new headliner setup. Just need to decide on what to do with the roof handles.
    Attachment 597969
    uhh
    where did you get the mirrors that are hanging on the roof I like
    El Cid 1999 IL
    DUDMD Tune/DINAN CAI/19 in Style 95 Rims/Bilstein's Shocks/Eibach Lowering Springs/OEM Folding Mirrors/Custom Cupholder/Custom Wood Sunshade/Sport Steering Wheel/Euro Center Console/Leather Shifter/Rearview Camera /Luke Custom 10 in Sub Box/Cross Drilled Rotors/Rear view Camera/BMW OEM Monitors/BMW E38 Picnic Tables/Vanity Headrests/OEM Roof Rack/Strut Bar/Dinan MAF and Dinan Throttle Body and Dinan tunning /BM53 Radio upgrade /Custom Innovadrive NXG39 modify and Alpine ILX-W650 touch screen radio.
  10. #835
    Alpine 7even's Avatar
    Alpine 7even is offline The King Of E38 Custom BMW CCA Member
    Mar 2011
    Haymarket VA
    e38 iL, F-e38 iL, e23 L7
    Max, theres a big difference on the bottom end with a larger MAF. The NEW Dinan Maf are 3.75" diameter at entrance and 3.5" at exit( tapered). I had it to complete my Dinan bits but I did Not like the performance of it since I was used to my MAF.
    I custom made my 4" diameter MAF. Its 4" at entrance and exit. I kept the Dinan Elbow to my Dinan TB and the results are very noticeable on the positive side.. I since Sold the Dinan MAf with no regrets.
    Dinan for e38 1st came out with a 4 " diameter MAF. They changed it by adding a sleeve inside it ..after complaints of ppl saying they lost their LOW END TORQUE
    Here is the picture of a 4" diameter Dinan MAF 1st design
    you can see how wide it is at beginning and at end....
    Now Dinan at 1st to fix the low end torque had customers return the maf and Dinan added a 1/8 sleeve inside it...Adding a 1/8" sleeve lowers the diameter by 1/4" so now the Dinan MAF is 3.75"'
    Here is the shot of that sleeve inside the dinaN Maf...
    so if you want more out of your DInan 7 get rid of that MAF....Who cares if u lose the name DINAN on the MAF
    Good info! I never noticed that!
    -2000 iL Individual. VF Supercharged at 12psi, Dinan MAF and TB, 6spd 420g swap, Euro under body guards, strong strut, N62 engine cover, Hydro trunk, Full suspension mods, Brembo F+R big brakes, custom headliner/interior, Bi-Xenon headlights, wide screen nav/mk4, Custom splash screen (I make them), coded video module with custom made harness, reverse camera, Intravee II, factory rear screen entertainment console, rear comms armrest, rear blower, seat back tables and writing tablet, all euro options coded on etc.
    -1997 iL. Pioneer 8500nex double din/Avic navigation, swc and dsp still functional. Reverse camera, full suspension upgrades, leather dash, console and door cards, rear blower, Re-upholstered seats, facelift sport contour seats, heated steering wheel, 750 front brakes, custom cup holder replacing the front ash tray, all euro options coded, headliner in black, rear headliner MID console.
  11. #836
    Aug 2013
    Finland
    1999 540i M-sport
    Had a good laugh today.
    Bought some Alpina center caps for my rims and they had this sticker on them.
    Looks like Chinese learned how to print BMW oem stickers and are applying it to anything now xD
    -E34 M60B40 + Tremec TKO 600 (sold)
    and sadly no old BMW anymore, only high powered Seat Leon Cupra 4Drive as a daily driver.
  12. #837
    May 2012
    1991 850i
    Seller must bought it off from dealer in China and shipped it to you at his loss
  13. #838
    Mar 2004
    Tyler, Tx
    Don't you wish that the aftermarket companies made parts for the e38's like they do for the current models. Just got this from an email from Turner's new OEM expansion catalog.....
    KW DDC iPhone-Adjustable Coil Overs
    Adjust front or rear shock damping settings from our iPhone, iPad, or iPod,
    Ride-height adjustable coil overs, lowering up to 35mm,
    Stiffer springs for less bodyroll and better handli
  14. #839
    Aug 2013
    Finland
    1999 540i M-sport
    Ordered from local bmw dealer,
    Transmission pan, oil drain plug and gasket and fill plug and gasket.
    Noticed that it is leaking a bit, from the drain plug, so a good opportunity to change oil again and maybe add some additive last time was max 5000km ago when I changed the oil.
    Отправлено с моего SM-G935F через Tapatalk
  15. #840
    Mar 2008
    Thousand Oaks, CA
    2007 Alpina B7
    I finally got a grip of my quality of my ride down. Got rid of my brake shaking ( due to front tires had bubbles in inside wall), worn tie rods and fresh alignment. Steering got tighter, which i missed. I now installed a strut brace and my balance of ride is incredible. Feels like im driving a new car (208k miles) The balance i now have at 90 mph turns is amazing. Like im smoothly gliding at 50 mph hut im doing 90 on various hwy roads. Yes i drive my 7 fast.
    Just need to color coordinate my engine bay colors soon. Need to install my 30k Silver valve covers on and no more cheesy red valve covers...
    Sent from my SM-N910P using Tapatalk
    2000 740i Sport
  16. #841
    Aug 2013
    Finland
    1999 540i M-sport
    What strut it is?
  17. #842
    Mar 2011
    Haymarket VA
    Quote Originally Posted by nike32 View Post
    What strut it is?
    Looks like the URracing bar. You can find them on ebay pretty cheapish.
    Looks good. I like that you blacked out the maf.
  18. #843
    Mar 2008
    Thousand Oaks, CA
    2007 Alpina B7
    Not sure the brand. I bought it off a guy name Jesse off e38 Empire for $80. I used to have the engine cover all blacked out too till my wife got a hold of it in the garage...Found it in 3 pieces...God knows how she did that? She fussed 2 weeks after I asked the whole fam bam who did it...I have to now color coordinate the engine bay..Either black valve covers or Silver and paint the strut bar too
    2000 740i Sport
  19. #844
    Mar 2008
    Thousand Oaks, CA
    2007 Alpina B7
    31124610094_original.jpg31124610095_original.jpgI used to have this STRONG STRUT but the damn thing moved a lot.. The bar was over rated...It looked good but functionality the Strut bar I have is 10x better as its SOLID and holds the car perfectly...If you jacked up the car on 1 side with the STRONG STRUT the bar would move (slide) at the joints left and right of the brace... I hated that then your alignment would be kinda off...I drove with SS for 4 years... it was PITA to deal with..It slid so much I had to send it to PAUL, who made it the SS for Heli COil the mounts once again due to stripping of the screws...
    2000 740i Sport
  20. #845
    Apr 2017
    Beachtown DE
    2001 740i sport 2014 x3
    Just finished dropping transmission to replace the flywheel, starter and crank sensor. Flywheel was the light weight riveted ( original ). Unfortunately it blew apart in the bell housing broke the starter ring and took out the crank sensor. Big job for a 65 year old in my driveway.
  21. #846
    Bonita Springs, FL
    01 740i, 09 X5, 12 335i
    Annual oil change. 👍
    2001 740i Sport - Anthracite Metallic, Gray Interior, 750 Porn Lights, 750 Seat Backs, Hoen Xenon-match Fogs, Crossed drilled, slotted rotors, LED Interior Swap.
  22. #847
    Mar 2012
    Queensland, Australia
    1995 730iL (M60B30)
    Quote Originally Posted by jwmarc View Post
    Your flywheel blew apart?? How on earth did that happen... yikes. Not sure I've ever heard of that happening before.
  23. #848
    Apr 2017
    Belgium
    1998 BMW E38
    I cleaned my oil sump today. I didn't expect it to be this messy. Does anyone know if this is OK for an M52 engine with 140.000 miles on it?
  24. #849
    Chicago, IL
    2001 BMW 740IL
    Angbody got a non working widescreen Nav monitor?
  25. #850
    Aug 2013
    Finland
    1999 540i M-sport
    Bought engine air filter, as my looked quite dirty.
    Not bad price, considering it is Filtron, and the Hengst for example is 24e.
  1. 2016 what did you do to your e38 today?
    By 1badturboe38 in forum 1995 - 2001 (E38)
    Last Post: 01-01-2017, 07:03 PM
  2. 2015 What did you do to your E38 today?
    By Mayorchuck in forum 1995 - 2001 (E38)
    Last Post: 01-06-2016, 03:36 PM
  3. 2014 What did you do to your E38 today?
    Last Post: 01-01-2015, 03:13 PM
  4. What did you do to your E38 today???
    By kooljess in forum 1995 - 2001 (E38)
    Last Post: 01-30-2014, 12:28 AM
  5. What did you do to your E36 today?
    By Eurodriver in forum 1991 - 1999 (E36)
    Last Post: 01-09-2008, 08:54 PM
