Results 1 to 9 of 9
Thread: NCS coding VIN is faulty
    Torrance
    1995 BMW 325is
    I am trying to code out the adaptive headlight error.
    I follow the instruction in here
    http://www.e90post.com/forums/showthread.php?t=773380
    It load the car profile fine at first.
    It allows me to select
    CAS, FRM, and (? LMA?)?
    I selected CAS, removed $524 , changed job to FA_WRITE.
    I then changed ECU to NFRM. FRM wasn't on the list.
    After I finished, I still see the adaptive headlight error.
    I read somewhere that FRM needed to be programmed too.
    So I start the process from the beginning when it asked me
    to select between CAS, FRM, and (? LMA?)?. I picked FRM, then it started to give me the VIN is faulty error. Even if I restart again with loading CAS, it still give me that error.
    how do I fix the "VIN is faulty" error? It was working before.
    how do I finish program out the adaptive headlight feature from the VO to get rid of the warning message?
    Dec 2012
    North Carolina
    2009 335i M-Sport Coupe
    That error can be caused by a bad cable, or out of date DATEN files, or mismatched files. I tried to code a replacement headlight module, and repeatedly had errors. I started with a fresh install of the entire software suite, and that fixed it. It coded up perfectly. Are you running a virtual machine? Ensure that the usb cable is patched through.
    Torrance
    1995 BMW 325is
    This is the error log I got:
    [00:07:20.783] [2005-06-29] [SERIE] 2000 Error LFCDHDIA.CPP (A_PL2FRX.IPS/IPO) CDHapiResultText 1
    [00:07:20.783] [2005-06-29] [SERIE] Fehler in EDIABAS oder in SG-Beschreibungsdatei IFH-0003: Datenuebertragung HOST/Interface gestoert FRM_87
    [00:07:20.783] [2005-06-29] [SERIE] 2000 Error COAPI2.CPP coapiRunCabd 6
    [00:07:20.783] [2005-06-29] [SERIE] Fehler in EDIABAS oder in SG-Beschreibungsdatei FA_READ
    [00:07:20.783] [2005-06-29] [SERIE] 2000 Error COAPI4.CPP coapiReadAuftrag 4
    [00:07:20.783] [2005-06-29] [SERIE] Fehler in EDIABAS oder in SG-Beschreibungsdatei FA_READ: A_PL2FRX
    [00:07:20.863] [2005-06-29] [SERIE] 2000 Error LFCDHDIA.CPP (A_PL2FRX.IPS/IPO) CDHapiResultText 1
    [00:07:20.863] [2005-06-29] [SERIE] Fehler in EDIABAS oder in SG-Beschreibungsdatei IFH-0003: Datenuebertragung HOST/Interface gestoert FRM_87
    [00:07:20.863] [2005-06-29] [SERIE] 2000 Error COAPI2.CPP coapiRunCabd 6
    [00:07:20.863] [2005-06-29] [SERIE] Fehler in EDIABAS oder in SG-Beschreibungsdatei FA_READ
    [00:07:20.863] [2005-06-29] [SERIE] 2000 Error COAPI4.CPP coapiReadAuftrag 4
    [00:07:20.863] [2005-06-29] [SERIE] Fehler in EDIABAS oder in SG-Beschreibungsdatei FA_READ: A_PL2FRX
    [00:07:21.063] [2005-06-29] [SERIE] 2000 Error LFCDHDIA.CPP (A_E65CAS.IPS/IPO) CDHapiResultText 1
    [00:07:21.063] [2005-06-29] [SERIE] Fehler in EDIABAS oder in SG-Beschreibungsdatei IFH-0003: Datenuebertragung HOST/Interface gestoert CAS
    [00:07:21.073] [2005-06-29] [SERIE] 2000 Error COAPI2.CPP coapiRunCabd 6
    [00:07:21.073] [2005-06-29] [SERIE] Fehler in EDIABAS oder in SG-Beschreibungsdatei FA_READ
    [00:07:21.073] [2005-06-29] [SERIE] 2000 Error COAPI4.CPP coapiReadAuftrag 4
    [00:07:21.073] [2005-06-29] [SERIE] Fehler in EDIABAS oder in SG-Beschreibungsdatei FA_READ: A_E65CAS
    [00:07:21.073] [2005-06-29] [SERIE] 1000 Warning COAPI.CPP coapiReadFgNr 9
    [00:07:21.073] [2005-06-29] [SERIE] Fehler CAS
    ================================================== ==============================(2)
    [00:07:21.123] [2005-06-29] [SERIE] 2000 Error LFCDHDIA.CPP (A_E65CAS.IPS/IPO) CDHapiResultText 1
    [00:07:21.123] [2005-06-29] [SERIE] Fehler in EDIABAS oder in SG-Beschreibungsdatei IFH-0003: Datenuebertragung HOST/Interface gestoert CAS
    [00:07:21.133] [2005-06-29] [SERIE] 2000 Error COAPI2.CPP coapiRunCabd 6
    [00:07:21.133] [2005-06-29] [SERIE] Fehler in EDIABAS oder in SG-Beschreibungsdatei FGNR_LESEN
    [00:07:21.133] [2005-06-29] [SERIE] 2000 Error COAPI.CPP coapiReadFgNr 12
    [00:07:21.133] [2005-06-29] [SERIE] Fehler in EDIABAS oder in SG-Beschreibungsdatei FGNR_LESEN: A_E65CAS
    Canada
    750 F01, 850i, LR3 HSE
    Yeah, you need to update your daten file folders for E89XX. Also ensure that you have a clear .man file in the work folder.
    Mark.
    Torrance
    1995 BMW 325is
    I removed and reinstall NCS expert, and the "VIN is faulty" error does not show up anymore.
    I followed the instruction to code out the adaptive headlight error.
    I removed $524 from CAS, NFRM.
    Why the warning message is still there?
    Do I need to code FRM too?
    Why no FRM in this step?
    but FRM in beginning.
    How do I do the following?:
    "Adaptive Headlight Error
    Module: NFRM
    Code Line: CHECK_SMC_ERROR
    Removes the adaptive headlight error check"
    and which of the following application do I use? Is there a step by step tutorial?
    app
    just go into the fswpsw.man file and delete everything from it. then save the empty file and then code the frm with that file. it will reset the module and no more error
    app
    "set this to nicht_aktiv on your frm/nfrm module
    ALC_FAHRZEUG"
    and which application do I use? Is there a step by step tutorial?
    app
    Torrance
    1995 BMW 325is
    Do I need to run SG_CODIEREN on NFRM ?
    how about CAS?
    on which step?
    Jun 2016
    Poolesville, Maryland
    335xi
    Some people recommend that you VO code BOTH CAS and NFRM, others recommend that you VO code only one.
    When you "reset" a module, it will read the VO coding from either CAS or NFRM (which one for sure???) so I would assume that you want to do both modules.
    Resetting a module configures the module to the standard settings that are required, giving the hardware listed in the VO.
    Jul 2017
    houston
    528i
    hello i really need your help i am getting a vin faulty, i use windows 8.1, inpa works fine but ncs expert giving me "vin Faulty" or email me raggg12@gmail.com
    Jan 2020
    Manchester
    E93
    Did you solve the vin faulty error??
  1. NCS Expert help - 'Central coding key is faulty' ideas?
    By Sobek in forum Diagnostic Software
    Last Post: 07-22-2016, 09:45 AM
  2. NCS Expert Vin is faulty 64 bit
    By Papote in forum Diagnostic Software
    Last Post: 03-29-2015, 05:50 PM
  3. Need to change VO. Central Coding Key is Faulty
    By Ziuck in forum Diagnostic Software
    Last Post: 05-27-2013, 09:04 PM
  4. NCS Expert... VIN Is Faulty!!!!!!!
    By garen45 in forum Diagnostic Software
    Last Post: 05-19-2013, 08:58 PM
  5. NCS Expert - "CHASSIS is faulty"
    By ryankokesh in forum Diagnostic Software
    Last Post: 12-30-2010, 02:35 AM
