Page 6 of 6 FirstFirst 123456
Results 126 to 150 of 150
Thread: Capelo's Green Monster Turbo Build Thread
  1. #126
    Boston, MA
    E36 M3 Turbo
    Quote Originally Posted by JPE36M3 View Post
    awesome progress, boost away worry free... did you use a stock replacement main bearings and caps instead of the ARP brand bearing stuff? this is nice, so instead of bothering them AND butters, does this mean I get to bother you when I slap this m52 block together this summer with an s52 crank? LOL. im not planning on really sending my stock s52 that hard right away anyways.
    Absolutely ask away. I used the OE Kolb main bearings and same for rod bearings. The main caps are being reused. I got OE because honestly the old main bearings I took out with 190k looked almost perfect. Don't see a reason to upgrade. The rod bearings did have some wear but that was to be expected.
    Sent from my SM-G930P using Tapatalk
    97 Turbo 3.2L M3 - Cutring / ARP - RSI Top Mount - Gt4088r - ID1300 - Tial WG - 22RPD Tuned - 93 Octane - 3.5" Stainless
  2. #127
    Bellingham, WA
    1999 E39 540i 6spd Mspec
    Wow... another amazing thread... thnx so much for all your hard work. What an incredible resources these things are to shade trees like me.
    SpeedFreak!
    aka: Jeremy Harper-Petros
    Long-time BMW Enthusiast
    Owner, Xtreme Xposure
    and Xtreme Aerial FnPS
    http://www.HookedOnSpeed.co
  3. #128
    Louisville, KY
    turbo m3
    I'm sure that I missed it, but what made you build a new block?
  4. #129
    Boston, MA
    E36 M3 Turbo
    Quote Originally Posted by SpeedFreak! View Post
    I'm still learning as I go, just posting my progress
  5. #130
    Boston, MA
    E36 M3 Turbo
    Quote Originally Posted by BadBoostedBmwM3 View Post
    I cracked the cylinder 5 piston due to rings overheating and butting. Broke the ringland and all. Figured I have to remove it all to repair might as well do a full build and not worry about it with the power id like to make. This is still the original S52 block and crank but freshly decked and bored to 87mm.
  6. #131
    Boston, MA
    E36 M3 Turbo
    More progress this week.
    Rings gapped to .019 top and .022 2nd. Piston & Rod combo installed.. what a pain in the ass. The C clip holding the wrist pins into the piston is a real pain to install without gouging the whole piston. But I finally got it all done and everything is lubed and moving freely.
    Rings installed in the proper orientation for first start as per JE spec sheet and lubed everything with conventional oil to help the first start.
    New Kolb standard rod bearings installed.
    Rod bearing clearance plastigauged and within spec.
    Customized the pan baffle to clear the ARP mains.
    And the rotating assembly is now rotational ftw!
    I put a bunch more accessories on after staring at all these shiny new things. This is as close to a new engine as I'll likely ever get lol. Still waiting on head dowel pins and a new crank pulley bolt. Going to locktite and weld on the oil pump nut again but I realized I didn't put the damn dowel pins on for the pump. So gotta redo that.
    Other than that it's business as usual and this Ho can breath fire!
  7. #132
    Boston, MA
    E36 M3 Turbo
    Got the engine in the car and running this weekend. Runs smooth and no smoke or anything but making a loud ticking noise. Even after 30min of run time :/
    Lifters were silent before pulled and I had them sitting in oil during this rebuild. So I'm ruling those out. Seems a little lower but not completely into the bottom end area. The noise seems more centered in the piston area. I can hear it pretty loud in the trans tunnel but could just be echoing.
    Pulled plugs after running it and they all look good, piston tops look clean.
    Borrowing a boroscope and looking more into it tonight.
    I reeeeally hope it's something simple
  8. #133
    Jul 2002
    Long Island, NY
    98 Turbo M3, 04 E53 X5
    Keep running it. Have you changed the oil yet? As long as your tune is ok, don't baby the car, the rings need to seat.
    98 Fern Green M3/2 - Precision 6870/AR Designs Twin Scroll/RK/E85
    2017 Toyota Tundra Crewmaxx - Family Whip
    2011 Pierce 75' Quint - Fire Apparatus West Islip FD
  9. #134
    Boston, MA
    E36 M3 Turbo
    Quote Originally Posted by NY98M3 View Post
    The engine has literally 30 minutes of run time. The driveshaft and exhaust is still out for other work I need to do so I can't drive it just yet. I suppose it wouldn't hurt to change the oil already though
  10. #135
    Jul 2002
    Long Island, NY
    Oil is cheap, drop the oil and run fresh oil. Bobby at Total Seal rings told me to run it hard and not to baby it so I did. The rings get seated right away this way. Youll know when they are seated, youll have less smoke and the motor will sound healthier.
    Ive run this procedure in all 4 of the motors Ive built, no issues
    http://www.mototuneusa.com/break_in_secrets.htm
  11. #136
    Boston, MA
    E36 M3 Turbo
    Got a video of the first start. After reading all of that break-in procedure I'm not sure I want to start it anymore if thats the case. But what do you think of the noise?
  12. #137
    Boston, MA
    E36 M3 Turbo
    Viewing cylinders shows pistons clean not damaged. Walls look good no scoring. Watching some similar videos on YouTube found one guy with a stretched cam cap stud causing a very similar noise. Any ideas or other things to check for before I pull the pan?
  13. #138
    Boston, MA
    E36 M3 Turbo
    So retorquing the cam caps made no difference. But I went and took ny98m3's advice and changed the oil then just got it together to put some miles on it. Followed motomans write-up for the most part.
    After the first wot pull the noise almost completely vanished. So I put another 20 miles or so on it of hard accel and decel and it's running great. I still hear a slight ticking at idle and low speeds and I think it's piston slap. Going to let it cool down tonight and hopefully it's quieter than it was on the cold start tomorrow.
    I'm willing to live with it and hopefully some more mileage and abuse will let it find it's home so I can sleep a little better lol
    Otherwise it runs smooth as butter. Holding 15psi so far without a hitch. It's rainy here tonight so I only did a dozen or so 3rd and 4th pulls and it didn't even hiccup.
  14. #139
    Vancouver, B.C., Canada
    '97 M3
    Piston slap is worse when the engine is cold as the pistons expand and get tighter in the bore with heat.
  15. #140
    Boston, MA
    E36 M3 Turbo
    Quote Originally Posted by chikinhed View Post
    The good news is the noise dropped almost entirely after the first pull even after full warm up. I'm going to put a ton of miles on it and hope it gets a little better once the rings seat officially.
    Guess there's no other fix for this unfortunately. But I'm glad I didn't royally mess up lol
  16. #141
    Boston, MA
    E36 M3 Turbo
    Cars been running great lately. Put a ton of miles on it and the engine is nearly silent getting better and better.
    Ripped apart the Supercharged car I purchased and found the thing actually has a huge list of goodies that the seller didnt even mention or wasnt aware of.
    Upon disassembly for the headgasket job I found it also has a Dinan Throttle body and Schrick cams! I plan on just fixing this SC car and now I'm debating swapping at least the cams into my turbo car here. I pulled some numbers off of them and they don't show up on any searches. How do I tell what duration Schricks these are?
    These numbers don't show up in any Google searches but maybe someone can match to theirs?
  17. #142
    Dec 2016
    North New Jersey
    1989 325is, 1995 M3
    Car looks great man. Have you got any power numbers yet?
  18. #143
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Did the supercharged car come from a guy in western Mass? I sold my old schricks and 3.64 3 clutch lsd in 2010 to a guy with a supercharged M3 in western Mass. Think it was a 95 but never saw the car.
  19. #144
    Boston, MA
    E36 M3 Turbo
    I got the supercharged car from bumf#ck CT. The PO owned it for at least 10 years and most of the kit was on it for about that long. It's a 99 and I just found out it already had an old mls .140 on it with ARPs. Going to replace with cutring & spacer kit and get it going soon.
    My green car @ 14psi I'd put around the 500whp mark. I ran a 12.5 @125mph last year at NE Dragway
  20. #145
    Jun 2005
    New England
  21. #146
    Under a roof
    507whp 318i
    Great build. What are your power goals? 87mm bore makes me nervous haha
    Also m52 and s52 is same exact block correct? Asking for boring purposes.....
  22. #147
    Boston, MA
    E36 M3 Turbo
    Quote Originally Posted by bavdrftr318 View Post
    I originally wanted 700whp but now I should be safe for a bit more. Don't really have a set number in mind. Yes the m52 and s52 are identical block castings besides bore
  23. #148
    Mar 2012
    Renton, Wa
    98 m3
    Can we all stop worrying about 87mm.
    0.3mm less wall thickness isn’t going to change much.
    The only real force is on the high side of the skirt. There is almost zero force on the thin area between the cylinders.
    The cutring gaskets have zero issues sealing the cylinders till at-least 37psi; probably more I just haven’t tried higher yet.
    At 700-800whp I’ll take the 0.2l over 0.3mm wall EVERY day of the week.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  24. #149
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    87mm or youre a puss.
  25. #150
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by rajicase View Post
    1989 535i - sold
  1. Daytona Violet E36 - Turbo Build Thread.
    By a32guy in forum Forced Induction
    Last Post: 05-22-2014, 04:57 PM
  2. Tchao's E30 Turbo Build thread
    By Tchao in forum Forced Induction
    Last Post: 11-01-2008, 01:42 AM
  3. M50B25 tu 2.8l turbo build thread. (e36 4/dr.)
    By northeaste36 in forum Forced Induction
    Last Post: 09-08-2007, 11:21 AM
  4. turbo build thread
    By euroNOOB in forum Hawaii & Other Islands
    Last Post: 08-12-2007, 08:33 AM
  5. My S38B36 Turbo Build Thread
    By MPD47 in forum Forced Induction
    Last Post: 01-15-2007, 12:59 PM
