Vollosso lives his life 1/4 mile at a time.
My 2017 FI goals:
-get the 6465 and S52 up and running and put 5k miles on it.
-dont kill my self in those 5k miles, and try to not break stuff.
-get to a dyno
-get to the drag strip for a few gentle runs down the 1/4 just to see. Dont break stuff (Drag strip is 15mins from my house)
-pour concrete floor in my garage and install a lift. Ive had access to a lift when ever i needed ever since ive had a license. Crawling around on the ground on a dirt floor, car on blocks, humping rear control arms caveman style.... im getting too old for that.
-get myself a Truck, before prices go up
I really don't have goals per say, it's more like decisions..
1. Remove the current stock M30 and replace with built one sitting on the engine stand..?
2. Or continue on with the stock engine and try for 8sec..?
Happy New Year..!!
My manifolds powering 8sec and over 1000rwp cars
Home of the highest HP stock M30 in the world 550rwhp/622rwtq
1/4 mile---> 9.81 @138 C4 Auto
10.08 in car vid --->https://youtu.be/OiinFhUomjg
Dyno vid... http://www.youtube.com/watch?v=C7aM7..._order&list=UL
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Too offensive?
Ironic?
OnTopic
I had to replace the failed UNwelded WG pipes,
so while they were out I bumped the twin WG's from 14.5# to 17 lbs (gauge is showing 19psi solid)
2017 car goals
Take the 98 M3 into the 9's..
Drive my 97 M3.
Have fun.
Only one Chiclet ?
Ehh I don't know, kinda bought a huge turbo, have e85, built motor, big cams and id1700s... kinda just snowballing.
Wanna see how far i can push a 6870.. may switch back to something smaller later, maybe a 9180.. but we will see how the response is with the new manifold.
1989 535i - sold
1999 M3 Tiag/Dove - sold
We just need to learn who this Milk man is........... I'll put it in song for those who would like to hear my interpretation.
https://youtu.be/pPdFrW076R0
1996 332IS
Built 3.2
2017 Goals
1. Finally drive my baby again and take it for long cruises and late night fun times into Boston on weekends to play with Porsches and GTRs and ferarris in the tunnels
2. Get it dialed in on the current setup once complete and get it on a dyno to see what I can put down spraying meth as well.
3. Redo the rear end with all the akg bushings I ordered and the reinforcement plates.
4. Install CAE shifter and have a fucking blast with that.
5. Pull out cage and get it powder-coated white and redo my interior to make it as clean and oem looking as possible with a bunch of new alcantara pieces to match my wheel.
6. Bust as much ass, in as many locations that I can on and off tracks
7. To finish off 2017 I would like to get body work done on the car. fix some rust, widen the rear 1/4 panels a bit and repaint the car.
A TIG welder should come with the purchase of a turbo IMHO
I had the forward section shortened by cutting out the tube and had a thicker wall tube installed. The driveshaft held up pretty good except for the Guibo lugs twisted and cracked. I found it before failure luckily.
I love this Lincoln Square Wave 200 tig. For $1400, its gold.
Miller 180 diversion would be nice as well. But more $$.
1996 332IS
Built 3.2
TheJuggernaut has been a very bad influence, hoping to pick up a TIG this year and start learning, especially now that I got some shop space I can set up a proper work bench/welding area
I'll post up pictures of the new Steed and 9180 install in the Steed install thread for sure (unlike some other Steed/9180 people, ahem). I may put some stuff in the 'Saturday's FI Solutions' thread if I do something crafty.
I know I'm being optimistic for my 2017 list but set the goals high, right?
1995 M3 - Forged 9.8:1 2JZ, S366, MS3x, E85, LQ9s, 420g/PMC Motorsport kit, 4 clutch 3.15 LSD Large Case 757whp/710wtq
2011 X5 Xdrive35d- Blk on Cinnamon, Towing Pkg, Heat Pkg., etc..the tow rig/DD!
2017 Goals:
1. Get the GTX3582R build done, and make 500whp in it. stock block, 93 + meth, cutring/ARP/spacer, spa t3, tial 44/50 combo
2. Purchase and install AKG shifter
3. Sell current home in Jan-Feb, purchase new home by March
4. Re organize/fill new garage with tools
5. Buy decent coilovers (currently on 30k miles Koni Yellows/HR springs)
1995 M3 coupe GTX3582R powered
2011 M3 sedan ZCP
Increase the price of 210 S diffs hahaha
World record holder for a m52 stock bottom end.
9.41@153 c4 auto 28" et streets, e34 3.64 gearset 900+hp
E36 chassis irs world record holder 8.49@162
Th400, e85, 7685, m50 intake 26.6 lbs of boost
Cold as ice lol
