Its time again for our F/I goals for the next year. The Trump era 2017.
Here is a link to last years thread, where you can view those that met their goals, those that bit off more than they can chew and those deadbeat boosters that sat on their ass (my category )
http://www.bimmerforums.com/forum/sh...l-achievements
So, new year, new goals.
My start will be much simpler as last year, I think I bit off more than I can chew, as well as sat on my ass.
Butters 2017 goals.
0. Drive Phil's car in the spring when traction is abundant, see what this EFR hype is all about. Cab we really have a 1000 HP turbo hit like a 35r ? Seems like the old wise one, Pbonsalb has figured out the recipe to make a cake, and munch on it.
1. I'd like to have a piece of paper that shows 700whp on 93+meth. Shouldn't be a problem if I get off my ass and hit a dyno.
2. I'd like to more than 50% of my runs in the 10 second club
Putting a stick car on drag radials that weighs 3600#'s is tougher to pilot into the 10's than I thought. But, Ive done it so no excuse.
3. Most importantly make the car great again. I want to enjoy the car more.
4. Learn this megasquirt business, understand it, conquer it.
So, let'r rip peoples.
Also, don't get popped for DWI tonight and ruin your driving for 2017.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
1. Clean out garage so I can finally got my project in there and still be able to park my other cars in the garage
2. Sell one of the two projects I have since I just don't have time for one let alone 2
3. Finish a build.....
1. Install new go fast parts ;
-s366sxe on current s52.
-450lph pump & 80# injectors
-comp twin disc clutch
-install meth kit or convert to e85 (tbd)
2. Make 600whp
3. Make a pass at a actual drag strip
4. Don't break anything major
5. Get finished with school. This time next year I should be graduating. Not car related, but shit..
Get a 9 sec slip on pump gas and put another 5k+ miles on the car.
95 M3, 5.3 LS, PTE 7675CEA, TH400/Gear Vendors OD
10.4@136 Pump gas at 3530lbs.
Build thread
http://www.bimmerforums.com/forum/sh...LS-Turbo-build
BFC F/I 2016 Goals and personal achievements
New project. 1995 s50 m3. Spa t3 gtx35 60lb injectors Rk tune. Cutring and spacer stock bottom end. 500whp.
Carry stock bottom end s50 to 11s
Get the new steedspeed build bottom end and aim for 650 whp
https://r.tapatalk.com/shareLink?url...e_pid=29011109
I did this only not with a stock bottom end. A quick 35psi spike made sure pistons n rods needed to be upgraded. Got 11.8 on 1/4
This year
210mm diff
1 dss
Bigger turbo n manifold. Get to low 11s or high 10 sec pass
2017 goals:
1. Rebuild the M30B35 for turbo
2. Turbo the M30B35
3. 500whp peak on a borg warner s362sxe with only ARP headstuds and an .140MLS on 92/93 pump gas without meth or E85 and have dyno sheet to prove it.
4. Go to BMW meet i.e. Bimmerfest or similar
5. Paint the 535i U94/2 Fire Orange
6. Sub 12 second 1/4 mile at 3,450lbs
7. Sell the AC Schnitzer e34 frame or use it somehow
1. Drive it on the new trans/rear end setup.
1a. Get a 16" track wheel setup.
2. Make 700+whp on e85
3. Make a 11.50 or faster pass before getting kicked out/breaking an axle (have never made a pass in this car)
4. Trap 135+ before getting kicked out/breaking an axle
5. Enjoy the car as much or more than last year since I'll have ac again.
1995 M3 - Forged 9.8:1 2JZ, S366, MS3x, E85, LQ9s, 420g/PMC Motorsport kit, 4 clutch 3.15 LSD Large Case 757whp/710wtq
2011 X5 Xdrive35d- Blk on Cinnamon, Towing Pkg, Heat Pkg., etc..the tow rig/DD!
-Final Install the new turbo setup, 276 cams and fuel system
-make a 4 digit dyno pull
-break something in texas in march on the half mile
-fit a ford 8.8 in the back with 3.00-ish gears.
-stuff a s85 in an e30
-build a twin 7163 monster
1989 535i - sold
1999 M3 Tiag/Dove - sold
1. Get my gt40r s52 setup installed and running
2. Also learn this megasquirter business
3. Try not to break anything
4. Break Everything
5. Drive The Sh!t out of it etc.
6. 600whp paper would be cool on pump
7. Purchase home while building racecar simultaneously lol ( Have my cake and eat it too )
97 Turbo 3.2L M3 - Cutring / ARP - RSI Top Mount - Gt4088r - ID1300 - Tial WG - 22RPD Tuned - 93 Octane - 3.5" Stainless
I bought a new house during my build...a 3 year build lol.
I really can't be adding this years goals to 2020 BFC FI goals lol
1. Finish/install motor with cut ring, new bearings, ATI damper and dry sump
2. AN cooling system with custom rad support and a C&R rad
3. AN power steering
4. Hood
5. Drive it around MoSport with jam
1. Move in my newly purchased home.
2. Set up my new garage.
3. Pull motor, throw in some rods and pistons.
4. Install bigger turbine housing on the gt3582r.
5. Maybe go with e85 since it will be available nearby.
6. Paint car different color. Tired of black.
1. Get my car running again so I can drive/enjoy it (been sitting for 3yrs).
2. Help Butters learn the Megasquirt tooning.
3. Fab up a turbo mani for my M42.
1. Go real fast
2. Sell the car and buy a chevy 2
3. Go full retard with chevy 2
4. Blow more dudes at truck stops
328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
9.20 at 150 on 22psi
1. Get motor back in and tuned
2. Looking for 950whp/775wtq
3. Enjoy the car more than last year
4. Whoop some ass at Mpact
5. Whoop some ass at Slipstream
98 Fern Green M3/2 - Precision 6870/AR Designs Twin Scroll/RK/E85
2017 Toyota Tundra Crewmaxx - Family Whip
2011 Pierce 75' Quint - Fire Apparatus West Islip FD
1996 332IS
Built 3.2
Yea dude, you gotta get ur price up
Chikinhed's 2017 Goals:
1) Get the car up on stands
2) Tear out diff and subframe, inspect for damage, change oil seals in diff, install subframe with new poly bushings.
3) Remove DSS drive shaft and install stock reinforced drive shaft to make the car more enjoyable to drive.
4) Replace worn UUC feramic twin disc.
5) Remove the Steed 1.0 and GTX35R and install a Steed 2.0 and EFR 9180 and associated piping.
6) Install aluminum doors and carbon fiber hood and have car painted.
7) Make aluminum honeycomb sub box.
8.) Hook up the ethanol sensor to the OBC now that the code has been written for it.
9) Install water cooling for the front brakes.
10) Do more track days this year!
I have a Family list that takes priority, but below is my list for Car stuff:
- New race trailer for 330i
- Install a lift in the shop
- Tig Welder (Buy one and learn to use it)
- Convert 330i to Manual Transmission
- Install Steed Speed TS manifold, and new Turbo
- Tune the 330i on the dyno
- Get rid of the damn gas smell inside the car while driving
- Run 11s at the drag strip
You have the most ambitious power goals so far on the list, why is that?
How do you plan to reinforce the stock drive shaft?
