Page 3 of 3 FirstFirst 123
Results 51 to 66 of 66
Thread: E30 daily driver LS swap
  1. #51
    Dec 2004
    Milford,CT
    95 M3
    Sold the nitrous after going through a bottle in like half an hour. Too much hassle with refills.
    Picked up an Eaton M122 off a GT500. It already has a 2.4" pulley on it, so combined with the 7.5" crank pulley, it'll be turning around 20k rpm at redline. I suspect it'll run around 17lbs on this little motor. I have a cathedral port lower intake from Magnuson on the way. Going to make an adapter plate for this blower and have an idler pulley mounted to the plate. I'm hoping to get 75% belt wrap on the pulley with the stock fbody accessory drive. Due to no intercooler, I'm going to spray a shitload of water/meth through the rotors.
    Not much of a start, but hope to have everything mocked up on a friends motor within a month so everything is an afternoon bolt on. Total investment thus far between the blower, rails and lower intake is $780. Should be complete, even with injectors and pump for under $1500.
  2. #52
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    how are you going to package this? there can't be that much room under the hood on an e30, is there?
    always trying to make it lighter and faster
    ^^former build: http://www.bimmerforums.com/forum/sh...-neglected-M3/
    current build: http://forums.pelicanparts.com/porsc...car-build.html
    instant grams: doktor_b
  3. #53
    Dec 2004
    Milford,CT
    95 M3
    There's a surprising amount of room. I know of one car with an LSA blower sticking about 2" through the hood and this should be substantially shorter with no intercooler.
  4. #54
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    Quote Originally Posted by jon volk View Post
    dang. if only there were space like that under the hood of an e36.
  5. #55
    357is (e30 w/LS1)
    I always thought a blower on an LSx-E30 (or E36) would be really cool -- especially
    if the hood need a nice, form-fitting hole so an inch or two of the blower
    would project out of the hole .........
    E30-LS1 Swap Guide and Kits, email us at e30ls1@gmail.com !!! or check our website e30ls1.wordpress.com
  6. #56
    Dec 2004
    Milford,CT
    95 M3
    Lower intake came today and ordered some aluminum for the adapter plate. Real nice piece. Way easier than fabbing something from scratch.
    Also got some fresh canvas installed. Should have done that 4 years ago.
  7. #57
    Dec 2013
    Fort Wayne, IN
    Not sure
    This build is rad! Is the M122 a common swap on LS motors now-a-days? (Been outta the game for quite sometime) Will it line up with the pulleys okay or will you do a custom crank pulley? Assuming you're doing a setup similar to that of my old GTP where accessories run on one set of ribs on the crank pulley, then just the supercharger and tensioner/idler run on a different set?
    Sorry, just really curious is all.
  8. #58
    Dec 2004
    Milford,CT
    95 M3
    Im only aware of one other DIY M122 on an LS and it's on a truck accessory drive. Im going to line it up with the stock 6 rib setup and there will be extra blower pulley ribs hanging out the front. If belt slip becomes an issue, Ill be able to just buy an 8 rib f-body drive setup. I dont think itll be an issue though with what I have planned for the idler pulley location.
    If this all works out, I may draw up the adapter flanges to sell. Magnusion made an MP122 kit for vettes and maybe trucks, but they have all been replaced with TVS blowers.
    95 M3, 5.3 LS, PTE 7675CEA, TH400/Gear Vendors OD
    10.4@136 Pump gas at 3530lbs.
    Build thread
    http://www.bimmerforums.com/forum/sh...LS-Turbo-build
  9. #59
    Dec 2004
    Milford,CT
    95 M3
    I mean, I'm basically done, right? Need to use some stubby injectors. I may need to space the blower up 1/2". We'll see after the intake bolt holes are drilled and I actually get some injectors mounted.
    Build thread
  10. #60
    Oct 2008
    West coast
    '00 540 6.0/4L80e/S480
    I'm not sure which car of yours I like better! This is great. Can't wait to see the finished product.
  11. #61
    Sep 2015
    Stow, MA
    1997 328i
    Looks done to me, I'd throw it on.
    Instergrams: @davemakepictar
  12. #62
    Dec 2004
    Milford,CT
    95 M3
    So the car was down for a few days due to a jammed up steering lock so I took the opportunity to mock up stuff. it almost clears the hood but I'm going to need some subframe spacer like used in an M60 swap. That'll get me the clearance I need.
    The Magnuson lower intake is so deep the valley cover needed countersunk flat heads
    Should have the blower "kit" ready to bolt on by next weekend.
    Build thread
  13. #63
    Dec 2004
    Milford,CT
    95 M3
    Last pics mocked up on the motor. Just need to do some fueling stuff and it should be a 1-2 hour bolt on ordeal when I'm ready for final install. I'd rather run a Ford Racing cable throttle body mounted on the blower to clean things up, but fuck if I'm gonna spend $600-700 on a throttle body. The elephant trunk will suffice. I'll probably like it better with some black wrinkle powdercoat. Need to call Gates in the morning and see if they have a green stripe 6 rib 94" belt.
    Build thread
  14. #64
    357is (e30 w/LS1)
    Most automotive serpentine belts are Gates "Micro-V", series K.
    see this list for available sizes:
    http://www.gates.com/oreilly/PDFs/SizeListings.pdf
  15. #65
    Dec 2004
    Milford,CT
    95 M3
    Well, fuck photobucket.
    Build thread
  16. #66
    Dec 2023
    Fort Worth, TX
    86 325e
    motor mounts
    I know this has been a while, but do you happen to have measurements and specs on those motor mounts? Length of tube and angles would be awesome.
    Much happier with this fitment....
    Motor is 1.25" further back than it was before. Just waiting on some 1/4" laser cut mount plates to finish them off. Did t have enough scrap material to make my own today.
  1. Replies: 1
    Last Post: 11-05-2013, 08:47 PM
  2. E30 WTB: E30 daily driver <$1500
    By schaef in forum 3 series & Z Series
    Last Post: 01-12-2011, 11:23 PM
  3. WTB E30 daily driver
    By btone in forum BMW Cars For Sale / Wanted
    Last Post: 05-01-2006, 06:17 PM
  4. e30 daily driver?
    By turbo525 in forum 1983 - 1991 (E30)
    Last Post: 02-22-2005, 11:48 AM
  5. Looking for E30 daily driver
    By jonmacs22 in forum 1983 - 1991 (E30)
    Last Post: 03-22-2004, 03:54 PM
