Hi,
I made a rookie mistake of replacing the license plate lights while the ignition was on. As a result I blew the fuse because the other plate light turned off suddenly and none othe plate lights will turn on now. Can someone please help me with identifying the right fuse for it? The icons on the fuse map is hard to read or at least I dont know how.
Thanks.
I know behind the glove department houses a fuse box. There is a fuse box diagram with only icons and numbers displaying the fuse location, no description of the fuse numbers. I will be glad to attach a copy of the fuse box diagram if you send me a private IM with your email address.
