Results 1 to 21 of 21
Thread: Considering a wheel and tire upgrade for my e36 track car
    San Jose, CA
    97 M3 Coupe
    Hoping you guys could help educate me on wheels and tires. I've done a lot of reading on the web/forums, and just looking to get more opinions.
    I'm currently running BBS CH 17x8.5 ET38 wheels with Michelin PSS 245/40/17 tires. I may be needing to replacing the tires very soon so this may be a nice time to implement an upgrade. I don't have any real complaints with my setup... but it would be nice to upgrade if it's worth it.
    The BBS CH rims weigh 22.25 lbs. I've been looking into APEX ARC-8s and it would be really nice to get the 17x9.5 ET35 wheels (16.95 lbs). However, it may be easier to fit the 17x9 ET30 wheels up front. Whatever I do I'd really like to stick with a square setup. I'm thinking of 255/40/17.
    My questions are:
    • Is it worth it to upgrade the wheels? That would be ~5 lbs of unsprung weight per wheel. Conversely, would it be better to save my money for the "driver mod"?
    • What should I expect by upgrading the tire width from 245 to 255? Anyone out there with personal experience increasing width by this small amount?
    Thanks in advance for your input.
    Pelican Parts's Avatar
    Pelican Parts is offline Senior Member Supporting Vendor
    Aug 2013
    Harbor City, CA
    '02 E39 Touring
    Really nice looking M3 man - that's kind of a toss up for me. Eliminating 20 pounds is def something, esp for a track car. I don't know what types of upgrades you've done, but I'm one of those guys that's huge on suspension - if I can add another bar or brace and gain something, I'm all for it. So, if there are any that you're missing, I'd buy/upgrade those instead of the rims. If you're happy with the suspension and overall quality of the car, then start tweaking additional weight. Just my 2 cents...let us know what you end up deciding upon. Happy holidays!
    -Dmitry
    888.280.7799 | 6am - 5pm PST
    MINIz guy's Avatar
    MINIz guy is offline #buttstuff2k14 BMW CCA Member
    Bear, DE
    rolls coal
    I don't think there is a huge advantage in your case to save ~5 per wheel. You aren't doing time trials or W2W, plus your BBS' are strong and in a good size.
    Why not just move to a different tire with more grip? Jumping up from the PSS to something at the 200TW mark will make the biggest difference. You have all the choices in the world for 2017 (Bridgestone, BFG, Dunlop, Hankook, Maxxis, Nexen, Federal, probably more I forgot about). You can go to a 255 on a 8.5" wheel too, it will be slightly pinched so the feel may be more squishy depending on what tire you get.
    Aug 2012
    Central, MD
    1995 M3
    255's (especially in more track oriented compounds) can easily, will likely, need a fender roll in the rear (depending on rim size & ET, suspension, spring rate, etc).
    Jul 2010
    Bay Area, CA
    1997 E36 M3
    I'm running the 17x9.5 et35 ARC8 and I have no rubbing issues upfront (running -4° camber for track days) only issue is a rub in the rear so you'll have to seriously roll or grind your inner fenders. Running 245/40/17 RE71R.
    1997 Techno Violet M3 Coupe - TCK - AKG - Apex
    Nov 2005
    MA
    Cayman S, Golf GSW, E30
    Your wheels are fine. I'd slap some NT01s on there and enjoy a decent grip upgrade for track.
    Aug 2002
    CT
    E36 S52
    How much track experience do you have, and what run group are you in?
    You definitely don't need to run anything wider than a 17x8.5" and probably your next best tire choice (after running the PSS) would be to move to something like Dunlop ZII Star Specs, Hankook RS3 (or the new RS4), Bridgestone RE-71R, or BFG Rivals. 255 tire is width is not necessary and you should run at least a 9" wheel with that size. If you REALLY want to you could get the APEX wheels in 17x9" and put a 245 tire on them. I ran some pretty fast laps in a race prepared Z3 2.5 on 17x9 APEX wheels with 245 Dunlop ZII SS...on par with many cars running R-compounds.
    San Jose, CA
    97 M3 Coupe
    Hey everyone, thanks for all the input. I really appreciate getting your opinions on this.
    Quote Originally Posted by Pelican Parts View Post
    -Dmitry
    My suspension is in top-shape, so I don't see any need there. I have been considering getting rid of my more street-oriented KW V1 coilovers for something more track oriented though.
    Quote Originally Posted by Pharaohe36 View Post
    Your feedback mirrors all the other things I've read on the web. Not only do you say that you are rubbing, but it also looks like you may be a little higher off the ground than I am. Hard to tell since you are making a turn away from the camera in your picture. What's your ride height like?
    Quote Originally Posted by MINIz guy View Post
    Quote Originally Posted by TXBDan View Post
    Quote Originally Posted by irollt5r View Post
    I'm starting to lean towards your advice, and starting to consider only making a tire change. I have ~15 track event days of experience and I'm running in high intermediate. Not sure if I want to make the plunge to R-compound tires... is there a good in-between? Irollt5r - is that why you suggested the tires you did (as a gradual step up from the Michelin PSS I'm used to)?
    MINIz guy's Avatar
    Bear, DE
    rolls coal
    The Maxxis VR1 and Dunlip Z2* are good street tires for the track. 200TW but they wear like rocks and handle heat well for continuous lapping. While the Bridgestone RE-71 and the BFG Rival S are stickier, they won't handle continuous lapping and will fall off towards the end of a 20 minute session.
    Dunlop is coming out with the Z3 and Hankook just announced their RS4. There are no data points on how they are though.
    Aug 2002
    CT
    E36 S52
    Quote Originally Posted by adept View Post
    Exactly! ;-) I always recommend holding off on R-compounds until moving up into the advanced run group.
    And there's a reason that endurance racing series are running ZII Star Specs!
    Also, MINIz guy is correct in his assessment of these 200TW tires. I would say that the original BFG Rival held up better to continuous lapping than the newer, stickier Rival S.
    Jul 2010
    Bay Area, CA
    1997 E36 M3
    This is my current ride height. No issues with rubbing after a grind of the rears fenders.
    Arlington, VA
    1997 BMW M3 NASA GTS2
    Save your money, keep the wheels you have, and do a tire upgrade whenever you wear out the PSS. Use the rest of your not-spent cash to get more track time Even if you are getting into higher run groups and going faster and faster, an 8.5" wheel is plenty wide for the tires you could run on a competitive level. I and many friends have all done very well on 8.5's with a 245 tire in years past. I've even turned competitive street-tire laps in Time Trial on my heavy-as-hell DSII wheels with old RS3's. You aren't at the point where you need to optimize unsprung weight so put the money where it will make a bigger difference.
    Plus, BBS CH are gorgeous wheels.
    I bought a set of ARC-8's recently and got the 17x9", as they're wide enough for any tire I'd run anytime soon, between TT and W2W stuff.
    2011 F-150 FX4 | 1997 BMW M3 #404 GTS2 | 2006 BMW M3 Convertible
    Out Motorsports
    Dec 2005
    utopia
    17 F250 12 Merc C250
    Price out the tires before you go and make changes. Sometimes the difference between a 245 and 255 is 40 or 50 bucks a tire. That could be 200 a set, which will get to be significant as you increase track time and need to replace tires sooner i.e. flat spotted set from over braking etc.
    Chris Leone
    chrisleonemotorsports.com
    roll cages, repairs and racecar fabrication
    1984 318i now 325is
    1994 325is STU racecar
    1988 325is donor
    San Jose, CA
    97 M3 Coupe
    Quote Originally Posted by Brake_L8 View Post
    This was a really concise and convincing argument. Thanks a lot for your input.
    Quote Originally Posted by XXLBIMMER View Post
    You're right... thanks as well. If I keep making those flat-spotting mistakes it could get expensive and cost me 1 or 2 days a year.
    Arlington, VA
    Very welcome! Driver mod is the most effective for a looooong while. I have been competitive all season in 2016 with 8.5" wheels, no aero, the stock 3.23 LSD (when most others either have the automatic E36 M3 3.38 or a Diffsonline "built" 3.64), stock sway bars, etc. I grew a lot this season as a driver and got significantly faster. Having better tires helped a bit, but learning how to push myself and push the car even harder got me a lot farther along. Don't get me wrong, you should run quality parts and tires are one place to not skimp, but replacing the tires on your existing wheels is going to be the most cost-effective given where you are in your track career.
    Out Motorsports
    Dec 2015
    Yakima, Washington
    1998 BMW 328is
    I agree with everyone else, just get a better tire and more seat time. If you do end up replacing your wheels down the line, check out D-force LTW5s, or the apex ARC8. I run the 17x8.5 et40 LTW5 with 245/40r17. I have no issues with them at all. The set only costs about a grand, and you'll definitely feel a difference. They weigh about 16lbs in that size, and you feel that when cornering and accelerating. I really enjoy the turn in feel with my set up.
    Aug 2015
    Bakersfield, CA
    1994 BMW 325i
    Seriously considering this fitment. What are your DD alignment specs?
    Aug 2009
    Metro DC
    79 323i, 94 325is, 13 M3
    duplicate post
    If God meant for man to motor-swap LS engines into track cars, He wouldn't have created Corvettes.
    Aug 2009
    Metro DC
    It's just me, but I like to spend my wheel and tire budget on getting more sets, not on getting my wheel weights down a few pounds or getting my width up a half-inch. For the same reason, I try to use 17s instead of 18s and 18s instead of 19s, it keeps the budget tilted towards more sets.
    For HPDE and club open practice days, I feel like I get more out of having the choice of different tires for the conditions, then I would out of having "compromise" tires in a slightly larger size. Right now for me that means a set of streetable summer high performance tires that I can use in the rain or DD, a set of sticky-but-not-slicks like RE71r or Federal FZ-201, and a set of outright slicks.
    I made the switch to sticky-but-not-slicks at about the point you're at now and it worked out pretty well. I didn't use traction control and I also drove at the track on rainy days, and did skidpad sessions on most every track day.
    I'm not pushing this as a strategy for anybody, but I have enjoyed what I got out of it.
    Buying ARC-8s in popular sizes is something I do sometimes because (1) they look great (2) they are good track wheels and (3) they're easy to resell if I change cars. Other times, I just get the TRMotorsport wheels, which cover (2), but cost about 40-45% less.
    Feb 2016
    NJ
    E36 M3 SEDAN
    Anyone able to get Michelin Pilot Sport Cup 2's to work without rubbing on a lower car with a minor fender roll? I'm currently using RE71Rs in 245 17, and they are according to the spec sheet 9.8" wide. The PSC2s are 10.2" wide. Debating if it will work with the extra width. Just looking at different tire choices out there and exploring.
    Nov 2008
    nnj
    Vipers, e46m
    FWIW, 17" x 9" TRMotorsport MT1-R wheels are 16.3lb.
    And I have a set for sale
  1. Clutch suggestions for my E36 track car
    By greygt3 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 05-10-2012, 09:25 AM
  2. Need help with wheel and tire size for my 97 528i
    By bmw528guy in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 01-28-2011, 11:15 PM
  3. confirm my wheel and tire sizes for my car please
    By theblue in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 03-23-2009, 11:26 AM
  4. confirm my wheel and tire sizes for my car please
    By theblue in forum Convertible Questions
    Last Post: 03-19-2009, 01:25 PM
  5. Whats the ideal wheel and tire setup for my stock zhp coupe?
    By zhp203 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 06-29-2008, 07:37 PM
