Install a weak spring on the intake and exhaust valve, assemble with a used head gaskets and measure the piston to valve clearance by depressing the valve until it contacts the piston at all the different crank angles from 30° BTDC to 30° ATDC every 5°. Then you will know.
www.facebook.com/Undr8dEmpireLlc Instagram: @UNDR8D_EMPIRE
Scarlet V2 - #Project333Ti - http://www.bimmerforums.com/forum/sh...(-Project333Ti)
98 Fern Green M3/2 - Precision 6870/AR Designs Twin Scroll/RK/E85
2017 Toyota Tundra Crewmaxx - Family Whip
2011 Pierce 75' Quint - Fire Apparatus West Islip FD
The limiter may reduce the area under the curve.
The cp pistons were 10.5:1
The new wiseco pistons are 9:1 correct? Valve to piston clearance the least you can do is 13mm on intake and 12.5mm on exhaust
Dumb question, where does the shim go? Anyone have a picture of a shim (installed or not)?
Infiniti G35S Turbo BMW M3/4/5 Ninja ZX6R 636
Penn State University '08...better than your school since 1855
Sigma Lambda Beta International Fraternity Incorporated
UTI Class of '10, BMW "STEPchild"
Acurazine.com Mod Squad
heres the info I got from VAC about the shim and what it does:
it limits the vanos movement so yes it does reduce the torque down low. the vanos retards or advances the timing as needed before 4000 RPM once it hits that RPM the vanos shuts down.
It does limit the piston to valve clearance by limiting the amount of vanos travel.
progress is slow but at least its moving.
Started assembly last night, file fit the Total Seal gapless top rings, Top rings were set at .026 and the 2nd rings were set at .024
With Total Seal rings, the gaps can be opened up more depending on the fuel and boost level.
Tonight is checking the clearances for the mains
Ive been thinking about the piston the valve clearance...Even with soft springs, how are the hydraulic lifters being "pumped up" while the motor is not running? Is there some sore of simulation that can be done?
Have you seen this: https://sourceforge.net/projects/vanossimulator/
You don't need a lifter or cams in there to measure piston to valve clearance, just measure at the valve tip from closed to when it hits the piston at every 5° of crankshaft rotation starting at 30°BTDC to 30°ATDC. When you degree your cams, with lifters and cams installed, you will find out what the lift profile is and can see at what point the valves are closest and by how much.
If you are using a different head to measure piston to valve clearance you should probably compare the head thicknesses and keep in mind that if a valve job has been done on that head the valves my sit into the head a bit more.
The lifters have a spring inside them that keeps them extended, so your test springs just need to be lighter than the lifter springs. The test springs should be just enough to hold the valves up. If you have some spare junk lifters you can also put some glue on the lifter plunger so they can't move.
Does the spare head have the same size valves? That will also contribute an added variable to not using the same head. You should really just check the clearance with the head you intend to use with a used headgasket of the same kind. If it's s cut ring maybe leave the rings out.
