Mine cracked. All I did was cut some aluminum sheet, about 0.187" thick, and welded it to the bottom. Made some cut outs for a socket to tighten the nuts and it's been totally solid since.
When is the new engine going in?
98 Fern Green M3/2 - Precision 6870/AR Designs Twin Scroll/RK/E85
2017 Toyota Tundra Crewmaxx - Family Whip
2011 Pierce 75' Quint - Fire Apparatus West Islip FD
So after 11 weeks, the machine shop was holding onto my parts and made 0 progress on anything. Finally pulled everything out of there. They basically wasted 11 weeks of waiting, calling, stopping there, hearing "your parts are up next" etc.
Reached out to Mike R and he said he'll take care of it and the turnaround would be quick. Dropped the parts off just waiting for him to call to say its done
Looking into changing up some gauges. Is anyone using this 4 in 1 gauge from Innovate Motorsports?
http://www.innovatemotorsports.com/products/ecf1.php
Damnnnnnnn
Are you data logging ? Maybe look at Zeitronix kit to log as well.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Sorry to hear, hope you get well fast and no scars left.
How did it happen, car related oh wait you are a firefighter IIRC, right?
Old set up: 520RWHP & 500RWTQ @ 20PSI 1/4 mile as of 7/26/15 12.5 @ 125MPH - 19PSI
New set up: Steedspeed Twinscroll, Wiseco Pistons 8.8:1 CR, K1 Rods, Blueprinted and Balanced, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) TwinScrol 1.06 exhaust housing, Nick G custom tuning, 6 Speed Transmission, UUC Twin Disc Clutch, UUC EVO III, UUC DSSR 109mm, EVO 6 Speed Driveshaft, HFS-6 W/M injection, Zeitronix data logger, 3" SS full exhaust, Rallyroad strut bar, X brace, Race coilovers.
Don't let that hold ya back. I pulled my s50 a few years back with a full arm cast two weeks after I shattered 4 bones in my wrist in a bike wreck.
Addiction isn't an easy "task"
but some of us have to do it.
Rub some dirt on it and get back out there, we need progress pics
328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
9.20 at 150 on 22psi
I sliced my tendon open on my index finger had to get stitches/splinted for 4 months...
Next day I got home from the hospital I did a diff swap lol.
Wishing you a speedy recovery Anthony!
I cut the tip of my thumb to the bone with my bandsaw while I was building my turbo manifold. I was on vacation from work and wanted to get it done so I super glued the outside shut and kept going.
Me right now
I thought you only got off on control arms?
By the way, thanks for the main studs Anthony, I did get them in the mail.
1996 332IS
Built 3.2
