Only reason Im looking into it is to get some quicker spool and turbo noises The pic I posted is from a well known car on this forum
DSS has sent back the shortened driveshaft, just need to check fitment.
Should be starting the build in the next 2 weeks!
98 Fern Green M3/2 - Precision 6870/AR Designs Twin Scroll/RK/E85
2017 Toyota Tundra Crewmaxx - Family Whip
2011 Pierce 75' Quint - Fire Apparatus West Islip FD
I would do it just for the noise.
I wouldn't , those things are heavy and our cars are pigs as is.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Old set up: 520RWHP & 500RWTQ @ 20PSI 1/4 mile as of 7/26/15 12.5 @ 125MPH - 19PSI
New set up: Steedspeed Twinscroll, Wiseco Pistons 8.8:1 CR, K1 Rods, Blueprinted and Balanced, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) TwinScrol 1.06 exhaust housing, Nick G custom tuning, 6 Speed Transmission, UUC Twin Disc Clutch, UUC EVO III, UUC DSSR 109mm, EVO 6 Speed Driveshaft, HFS-6 W/M injection, Zeitronix data logger, 3" SS full exhaust, Rallyroad strut bar, X brace, Race coilovers.
Was that 16 rwhp gain with a catless 3.5 inch exhaust?
No, that was over stock exhaust, im looking back for the Dyno comparison so I can pos them and verify the HP gain.
The spool difference was huge
1996 332IS
Built 3.2
That I can agree, the biggest difference over a 3.5 or 4" exhaust would be spool and sound... it does sound sweet when you open it up.
Dang, that is a clean undercarriage.
Do you run AN fuel line all the way from tank to rail?
What is the purpose of the short section of hard line you have between one of the AN lines next to the flex fuel sensor?
You might want to reinforce that transmission crossmember.
I like your quick change diff version of the rear subframe.
How much did you take out of the driveshaft ? This was from a ZF 5 to a 420G ?
1996 332IS
Built 3.2
Is this advised with the 5speed cross member as well?
yes, I gave them the measurements of 53.5" from the back of the 420 to the pinion shaft.
Yes, and if anyone is interested, I have one for sale that been reinforced. PM me if youre interested.
Thanks Perry, and I apologize for the wait on those parts, Im making a trip to get them this weekend.
The lift is great, saves a ton of time. I'm so anal that the car is always on the lift so the tires dont get flat spots lol
I ended up buying it used, they are pretty affordable, its a Mohawk A-7, If you know lifts, you know this is the premo top of the line lift.
Although I never broke a trans brace, I use a reinforced one that Mike R. did for me years ago. I think Rally Road sells a fancy trans brace.
