Page 1 of 8 12345678 LastLast
Results 1 to 25 of 197
Thread: NY98M3's 2017 Build Thread - M52/S52, 6870, AR Designs, E85
    Jul 2002
    Long Island, NY
    98 Turbo M3, 04 E53 X5
    Thumbs up NY98M3's 2017 Build Thread - M52/S52, 6870, AR Designs, E85
    2017 is the year to shine, going with some changes because....well....why not, it winter. Kicked some ass last year at Pocono. While we kept up with the big boys, the car gets zero looks until it goes over 160mph in the 60mph to 1600ft.
    Plans:
    Built 2.9~3.0
    Wiseco 84.5mm pistons, 8.5:1, coated skirts
    HD wrist pins
    Total Seal Gapless top rings
    Pauter Xtreme duty rods
    S52 crankshaft
    ARP2000 10mm headstuds
    Schrick 276/270 cams
    Supertech valvetrain
    VAC/ATI damper
    Converted OBDI valve cover
    E85 everything
    Precision 6870 twin scroll 1.0 A/R
    AR Designs V1 manifold
    Twin Tial MVS 38mm (open dump)
    3.5" exhaust with cutout
    Treadstone 1245 intercooler
    Tial 50mm BOV
    E46 M3 6 speed trans
    Clutchmasters 850 twin disk with lightweight steel FW, race clutches
    Hydraulic TOB
    UUC Euro Evo3 short shifter
    Shortened DSS driveshaft
    Block is being machined, entire rotating mass is being balanced, just waiting on them to call and say it's done. I have a severe problem collecting M52B28 blocks, I'm up to 4 now lol.
    For the meantime, I used a spare block to measure up the new driveshaft specs.
    Clutchmasters 850 with lightweight steel flywheel
    New fancy valve cover so I can stop melting my plastic OBDII cover.
    6 speed getting delivered
    Slipstream Roll Racing 2016 @ Pocono
    98 Fern Green M3/2 - Precision 6870/AR Designs Twin Scroll/RK/E85
    2017 Toyota Tundra Crewmaxx - Family Whip
    2011 Pierce 75' Quint - Fire Apparatus West Islip FD
    New Westminster, B.C.
    1994 840ci,'97 M3
    this is almost the same as my build down to the valve cover. i got to get cracking and swap over to e85 and get one of those s369sxes and go for broke
    NY/FL
    '08 G35S, '98 M3/4/5
    That VC is gorgeous for sure! Every time I think you've gone to the top level, you do something new lol. Can't wait to see yet another pristine build brother.
    Infiniti G35S Turbo BMW M3/4/5 Ninja ZX6R 636
    Penn State University '08...better than your school since 1855
    Sigma Lambda Beta International Fraternity Incorporated
    UTI Class of '10, BMW "STEPchild"
    Acurazine.com Mod Squad
    May 2015
    Methuen, MA
    1999 BMW M3 Coupe
    Where did you get that valve cover? It looks awesome.
    Nov 2005
    Falls Church, Virginia
    98' M3/4/5
    Quote Originally Posted by E36Mylo View Post
    Looks like a powdercoated S50 magnesium one.
    1995 M3 S52 turbo (Sold, like an idiot) -----------------------------------1998 M3/4/5 (Hopefully turbo soon, Nope sold this too)..................................E92 335i(God, I miss the E36's)
    May 2015
    Methuen, MA
    1999 BMW M3 Coupe
    Quote Originally Posted by bmuum3 View Post
    Interesting. After some quick research it looks like i'd just have to switch to the s50 coil packs and this would just bolt on?
    Sep 2008
    Toronto, ON
    6465 328ti
    Yes
    May 2015
    Methuen, MA
    1999 BMW M3 Coupe
    Quote Originally Posted by e30kid89 View Post
    Yes
    sorry to the OP for sort of thread jacking. Thanks a lot guys for the replies and info. I'll be looking into getting one powder coated white with the colored logo!
    Joliet, IL
    Out of Service
    Be careful just swapping to s50 cover. The grounding system on that cover is not nearly as good as the s52 cover. If you make the switch definitely ground the coil packs to a chassis ground
    Sent from my SM-T707V using Tapatalk
    May 2015
    Methuen, MA
    1999 BMW M3 Coupe
    Quote Originally Posted by cragg56 View Post
    thanks for the heads up!
    Jul 2002
    Long Island, NY
    Having some 2nd thoughts about using the Lightweight steel flywheel.
    Clutchmasters states on their site the weight of the FX850 with the steel flywheel is 22 lbs total. I weighed it myself and saw that it the total package weighs 30.4 lbs. I think that might be way overweight. They have recognized the info on their site is wrong and are willing to swap the lightweight steel flywheel for the aluminum.
    What do you guys think?
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Isnt that still 10 lbs lighter than stock?
    Jul 2002
    Long Island, NY
    I dont know what the stock FW and clutch weighs, I weighed the UUC twin disk I had and it weighed in at 25.5 lbs
    Vancouver, B.C., Canada
    '97 M3
    I can't stand heavy clutch/flywheels. I swap them out on all my cars.
    Mar 2008
    West Covina, CA
    97 M3/4/5, 98 M3/2/5
    Isn't the gear rattle pretty bad on the 420G with a lightweight flywheel?
    Jul 2002
    Long Island, NY
    Quote Originally Posted by chikinhed View Post
    What do you consider heavy?
    From what I found online, the stock DMFW weighs 26 lbs and the clutch is 15 lbs making it a fatty at ~40 lbs. With the Clutchmaster FX850 with lightweight steel FW its ~30 lbs. The UUC twin disk comes in at 25.5 lbs.
    '97 M3
    Stock DMFW is heavy but quiet. I've had gear rattle for almost ten years now. I'm use to it.
    Aug 2016
    Chicago, IL
    BMW 328i Turbo
    What are your power goals and how much boost will you top out at? Sorry, I know it's OT, just curious!
    1997 BMW 328i Avus Blue - S52B32 Motor - VAC 140 MLS HG - ARP Head Studs - Supertech Inconel/SS Valves w/ 80# Springs - Standalone Megasquirt 3 - CX Racing Turbo Kit - E85 - Wally 485 Fuel Pump - 80# Injectors - 6 Puck Sprung Clutch - Lightweight Flywheel - Stewart Pump - Mishimoto Z3M Radiator & Expansion Tank & Electric Fan - H&R Cup Kit
    Support my hobby by supporting my business! (myeasytek.com) - Follow me on Insta: @realjtbabin
    15PSI @3700 RPM - 488 WHP, 481 WTQ @ 4600 RPM
    Oct 2005
    Northern California
    95 M3, 15 Golf TDI wagon
    Im sure this will be another awesome build. Looking forward to the results.
    -WTB: OEM Class 2 LTW GT wing with risers- Mazak
    Jul 2002
    Long Island, NY
    Quote Originally Posted by jbabin87 View Post
    Power goals are a reliable 950whp/800wtq. 32-35lbs of boost.
    Quote Originally Posted by 3literheater View Post
    Thanks, closely following yours as well. What does your new clutch package weigh? I see you're using a lightweight steel FW as well.
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Damn I cant wait to see this incarnation of the Green Machine.
    Dallas, TX
    98' M3/4/6T
    What's your estimated timeline to completion?
    Jul 2002
    Long Island, NY
    Quote Originally Posted by 1SLWM3 View Post
    Should be April, machine shop is taking forever.
    Dallas, TX
    98' M3/4/6T
    That's basically spring-ish. Looking forward to seeing the results.
    Hagerstown, Md
    1995 M3 Drag C4 Auto
    You want heavy...
  1. Replies: 795
    Last Post: 09-19-2020, 04:00 AM
  2. build thread O ring, BB pt7675 cea, E85
    By das Boot in forum Forced Induction
    Last Post: 05-01-2011, 02:54 PM
  3. my build thread, e30 m52 gt4088
    By someguy2800 in forum Forced Induction
    Last Post: 12-22-2009, 02:08 AM
  4. Replies: 44
    Last Post: 11-08-2009, 03:05 PM
  5. Replies: 8
    Last Post: 07-16-2009, 01:51 PM
