Results 1 to 15 of 15
Thread: Getting PA Soft BMW Scanner 1.4.0 to work on Windows 10 64 bit
    May 2014
    Charlotte, NC
    '99 528iTA Sport
    I've been trying to get this working for a long while now, and I've been needing to reset my oil light for almost as long. I have the BMW Scanner 1.4.0 OBD device along with a pac-man 21 pin adapter for my '99 528i, and I cannot get the drivers installed correctly. Every time I open the program, it shows that the device isn't connected, but the driver are installed. On Device Manager, it still shows the exclamation mark next to the BMW Scanner device as if there is a problem.
    I've tried the FTDI drivers and the drivers that came on the disk, and Windows just tells me it cannot install the drivers, whether it's plugged in to the car or not.
    I have tried the method I read on another thread here about deactivating driver signature verification, and that made no difference. Does anyone know what I can do to get this working? I'd really like to use this software.
    1999 528iT Sport- 2/1999 Alpine White/Sandbeige
    2003 X5 3.0i Stahlgrau/Gray
    2001 330Ci Topazblau/Black
    1984 318i Balticblau/Black
    1995 525i Hellrot/Beige (brother's)
    2007 335i/6 Titansilber/Black (brother's)
    2004 X3 2.5i Titansilber/Gray M54B30 swapped (dad's) (Sold)
    2006 330i Alpine White/Black (Sold)
    ...and some Volvos and other stuff
    Dec 2012
    North Carolina
    2009 335i M-Sport Coupe
    Try the instructions in the 7th post here: http://www.bimmerforums.com/forum/sh...n-Win-7-64-bit
    Windows 10 should be very similar. I had to desolder some shorted pins in my adapter before it would work.
    May 2014
    Charlotte, NC
    '99 528iTA Sport
    Quote Originally Posted by RocketSurgeon View Post
    Yeah, that's what I had done, and it still won't work. I can't figure out why.
    Jul 2004
    Houston, TX
    36 Cylinders
    I've gotten it to work on Win8.1 64-bit, but never tried on Win10. One of the many reasons I don't use Win10.
    I would try old FTDI drivers to get a connection to the FTDI chip. Then read the FTDI chip eeprom with MProg to make sure the new Win10 drivers didn't erase the device ID. The new FTDI drivers tend to do that to certain clone chips. One of the reasons why the white board K+DCAN cables fail so often. Easy to reflash back though.
    I have successfully revived non working white board K+DCAN cables using this method.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Apr 2009
    Vancouver Isl, BC, Canada
    98 Euro M3, 04 M3, 06 M5
    Works fine on my windows 10 32 bit. Make sure your are disabling all firewalls and running everything as administrator.
    Current:
    - 09 335i MSport, FBO.
    - 98 Euro M3, Estoril Blue
    - 04 M3, Carbon Black, 6 Speed Coupe
    - 06 M5, Black on Black, Full Leather.
    - 73 3.0CS, Tagia Green, 5 speed M30b35 converted
    Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i, 2001 M3, 2006 M5 6 speed
    May 2014
    Charlotte, NC
    '99 528iTA Sport
    I'll have to double check all that. I need to see what I can do with it this week.
    Dec 2015
    Deutschland!
    E39 530i Touring, Z3 3.0
    Desolder? The only thing that happened multiple Times with interfaces (BMW Scanner or k+dcan) is that the shortcut between pin 7&8 was missing. Those Selters have no idea what they are selling and in the "Support" they are pretending to have "engineers" to solve the problems. Nur the only thing they recommend is to try Windows XP, 7 or 8 which always Leads to the Same issue. You Will Not be able to access any module besides DME (maybe also DDE) as Long as Pin 7&8 are Not soldered together.
    I know that some newer E Models do Not need (meaning they Must be separated) those pins bridged. But afaik all models which are covered by bmw Scanner 1.4.0 Need this. Any other opinions/experiences?
    The Installation guide you refered to worked for me with all x64 machines Running Windows 7 and above except one machine. No idea what the matter was there.
    May 2014
    Charlotte, NC
    '99 528iTA Sport
    First off sorry about the delay, this stuff just frustrates me so I can't focus on it too long! Anyway...
    I've determined that after uninstalling the device, unplugging the adapter, and plugging the adapter back in, the drivers are not installing at all, even though the BMW Scanner software says that they are installed. I think the software is just seeing that the drivers are on my computer, but I cannot install them on the "BMW Scanner V14x" device. Does anyone know what drivers will be able to install on the BMW scanner adapter on Windows 10? Every time I try to install the drivers it just tells me that they won't work on that device.
    May 2014
    Charlotte, NC
    '99 528iTA Sport
    Got it working! I followed the directions closely from this post and I got connected finally! Thanks guys!
    Oct 2018
    Atlanta, GA, USA
    2002 BMW 325i Wagon
    I purchased a ~$20 BMW scanner 1.4 and ran into driver install issues. Thought that I would pass along what worked for me.
    1. Download the x64 driver for Windows 10 from the following: https://www.ftdichip.com/Drivers/D2XX.htm
    2. Follow this foreign-language youtube tutorial to learn how to install the drivers: https://www.youtube.com/watch?v=bZLhlfDmmog
    3. Plug in the scanner to my computer and then to my laptop and everything worked great after I staterted the .exe file: BMWScan140.exe
    Oct 2012
    San Jose, Ca
    540i/6, 911 C4
    Quote Originally Posted by logan30306 View Post
    This worked for me after downloading BMW Scanner for windows 10.
    Thank you
    Aug 2019
    Walnut Creek
    535i
    i bought this and it comes with the male to female adapter already pinned and i found it here but for those needing help see this video to help setup all your stuff..
    https://www.youtube.com/watch?v=_RdQaNOmH3I
    http://www.one-stop-electronics.com/...&product_id=16
    Package contains:
    INPA / Ediabas K+DCAN USB Interface - 1
    K+DCAN OBD2 female to OBD2 male Adapter for extended backward compatibility - 1
    Please be aware that we do not include software for this Item neither on disc nor by download
    For a General Introduction into diagnostic on BMW vehicles please download / open and read this PDF document carefully:
    General_Introduction.pdf
    For information about driver download and installation please download / open and read this PDF document carefully:
    Installation_Manual.pdf
    For information regarding backward compatibilty for older K-Line equipped vehicles please download / open and read this PDF document carefully:
    APN_Backwards_Compatibility.pdf
    For information regarding connection issues on DCAN equipped vehicles please download / open and read this PDF document carefully:
    APN_Connection_Stability.pdf
    For Driver downloads please go directly to the FTDI Driver Page:
    FTDI VCP Driver Page
    h
    Package contains:
    Oct 2019
    Hilversum, Holland
    E46 Compact 316ti
    this worked for me to, best step by step instruction so far for installing BMWscanner on a 64bit windows 10. just have to figure out an IKE and EWS error, but according to most that's because pin 7 and 8 is not bridged in these devices
    Apr 2003
    Back in Hunt Valley, MD
    96 ACS S3 CLS, 02 540iA
    Yup...just wanted to add that this too worked for me. Was having issues getting the driver to work after following several other threads about loading the driver in BMW Scanner 1.4.0 here and on E46Fanatics. PA Soft was showing the device drivers being installed (green square), but wouldn't see the adapter being plugged in (yellow square). If I looked at it in Device Manager, it showed BMW Scanner 1.4.0 as not having a driver. Followed the above mentioned Youtube driver tutorial (that looks to be in Russian maybe?) and it worked like a charm. Mine is now up and running. Thanks!
    Alvin Caragay
    Mpire Automotive (https://www.facebook.com/MpireAutomotive/)
    '96 AC Schnitzer S3 Sport CLS Replica (https://www.facebook.com/ACSS3SportCLSR)
    '02 E39 540iAT
    Jul 2019
    Canada
    BMW E39 528i 1998
    Hallelujah! This short and sweet video worked!
  1. HELP! how to install the proper driver for PA Soft BMW scanner 1.4.0
    By big mike 84 in forum Diagnostic Software
    Last Post: 12-03-2015, 09:15 PM
  2. Replies: 7
    Last Post: 02-17-2014, 02:03 PM
  3. PA Soft/BMW Scanner 1.36
    By IcemanBHE in forum Diagnostic Software
    Last Post: 09-13-2012, 01:56 AM
  4. PA Soft BMW scanner
    By lawdog8234 in forum 1995 - 2001 (E38)
    Last Post: 02-26-2011, 03:12 AM
  5. Replies: 2
    Last Post: 01-05-2010, 06:42 PM
