Results 1 to 17 of 17
Thread: My 750 is back from paint, let the build begin......
    Dec 2005
    Baltimore, MD
    81 Scirocco-92 750il
    Fresh out the spray gun and hasn't even been wet sanded or buffed yet.
    My biggest problem right now is finding the sunroof brackets that always break. With the sunroof in the car, I had to get between it and the headliner to grind the heads off two of the sunroof tor screws so that I could get it out. Once out I discovered that the nuts that are inset into the sunroof bracket were being allowed to spin because the plastic had broken. The dealer is sending my drawings that are not of the sunroof in my car and I'm kinda stumped right now. Anyone know where these can be had? The car is DC81088.
    Dec 2005
    Baltimore, MD
    So I finally got her back off the lift and ready for the ac to be charged and alignment gotten underway. I'm still fighting the sunroof thing though. The stealership is telling me the numbers on the rails I need aren't valid part #'s, their drawings show different sunroof setups, and I have had no luck on the internets. SHOGUN, master of all that is e32 information, do you have a direction you can point me in? It appears as though both rails and cables are ONE PEICE because they will not separate without being bent/broken. I have to replace them because the nuts were spinning inside them due to cracked plastic. I have two parts cars but I'm sure they do, or will, have the same problem.
    Here's a list of what's been done mechanically.
    BMW reman steering box, many new linkage parts too
    New radiator, thermostat, and AC dryer(she's going back together with r12 if I can help it
    New motor mounts, upper and lower pan gasket, ALL hydraulic lines that are up front
    Installed a used, and unscratched drivers window and fixed the broken lock actuator bracket
    New headlights purchased, currently looking for better front turn signals and bezels
    New front bumper cover and right front fender
    West Coast
    two 3's one 5 three 7's
    Great to see e32 builds/restos like this, rarely happens on the e32 boards so keep up the good work!
    Have you noticed much of a difference from the BMW reman'd steering box?
    Dec 2005
    Baltimore, MD
    Quote Originally Posted by whiteghost1 View Post
    Only been able to drive it one mile so far...haven't put tags back on it yet.
    May 2012
    Boynton Beach, Florida
    1990 735I (E32) M30
    Paint looks beautiful. Look forward to so the finished product. Inside and out. Another E32 being saved. There should be a Holiday...............
    1990 735I (Auto) E32 Feb 1990 to Present
    1996 Z3 Roadster (5 Speed) E36/7 Jan 1999 to Dec 1999
    1983 733I (5 Speed) E23 April 1983 to Feb 1990
    https://www.youtube.com/watch?v=2d4tHoHGaJo
    https://1drv.ms/v/s!Av20xCMMocSsyEpl...h_oOk?e=ekIcAT
    Oct 2014
    Rock Hill, SC
    93 & 94 740iL
    Dang, That looks nice.
    Current Collection:
    1993 740iL - daily driver; 1994 740iL - project #1; 1994 740i - project #2
    1991 Buick Roadmaster Estate Wagon - beast of burden & tool/parts hauler
    May 2012
    1990 735I (E32) M30
    I knew I had seen your car before. I was thinking about you posting pics with the BBS wheels and the center caps off. I went back to the "show your ride" thread and see your pics on page one, just before my post. I always say how my memory is shot, but when it comes to E32's there's a special place up there.
    Dec 2005
    Baltimore, MD
    Quote Originally Posted by CroughtonE32 View Post
    Yeah that was long before I wadded it up. Here's what it looked like after I took the hood off and it sat in the garage for two and half years.....maybe with a burnout or two happening in that time....:-) (click on the little picture underneath)
    May 2012
    1990 735I (E32) M30
    Photobucket worked just fine. Some video. What were you guys trying to do.............burn up the rear tires????
    Dec 2005
    Baltimore, MD
    That was at my annual car gtg, sometimes the asshattery gets a little crazy, I start letting the boys do burnouts then I want to do one too. She needed the exercise and the rear tires were relegated to burnout shoes already. They were only on the car because I knew it would be sitting for a while in storage and didn't want my good ones to get flat spotted.
    Dec 2016
    UK
    Oct '88 E32 750iL (RHD)
    Looking good already. Great to see an E32 having some money spent on it!
    Dec 2005
    Baltimore, MD
    Quote Originally Posted by b9boy View Post
    And some pretty stupid money has been spent here.....
    PLEASE!! If anyone has some advice on finding the right sunroof parts it would be a huge help. Thanks in buckets in advance.
    May 2012
    1990 735I (E32) M30
    I would call Travis at http://www.bmrparts.com/ Give him your Vin and exact manufacture date. Tell him all the parts you need and have one of his guys find an identical car to yours and pull them. Biggest BMW wreck yard on the planet. They usually have just about everything. I bought an intake manifold from them a few years ago. Real easy to deal with. Just a thought.
    Jeff
    Dec 2005
    Baltimore, MD
    Jeff
    Gracious...they want 350 bones for a complete sunroof assembly. Won't sell the pieces I need separately. UGH...
    Oct 2014
    Rock Hill, SC
    93 & 94 740iL
    $350 isn't that bad - that might actually be cheaper than trying to find the parts you need...
    Current Collection:
    May 2012
    1990 735I (E32) M30
    Quote Originally Posted by vwleadfoot View Post
    Did you talk to Travis, and maybe make him an offer instead of asking for a price. Might work. I only ask because when I purchased my manifold from them, it took three times until they got it right. There were three different manifolds on the E32 that I know of. One says 3.2/3.5 on it. Mine just says 3.5. One comes ready for ELM and not old fashion wired gas pedal and cruise control like mine, and one comes without the hose tit that leads to the brake booster. The third one they sent was right on the money. But because they were messing up with my VIN number, the second two came two day air and they never wanted any parts back. Two of the manifolds came with the fuel rail, injectors etc. Just gave everything to my mechanic for his future use, and the third shipment was spot on. Made me feel good about him. Maybe not so good about the guy pulling the parts from the wrecks. Anyway, worth a shot.
    Dec 2005
    Baltimore, MD
    The 350 bones is for a used assembly. I have pulled apart one of my parts car sunroofs and it has the same problem my nice car has, split and broken plastic. Any used assembly is going to have the same problem. Thanks though.
  1. My CAR IS BACK FROM PAINT!!..love the results
    By DTMkarnage in forum 1988 - 1996 (E34)
    Last Post: 12-09-2009, 11:38 AM
  2. My car is back from the paint shop
    By amancuso in forum 1991 - 1999 (E36)
    Last Post: 02-17-2009, 11:02 AM
  3. my baby is away from home for the first time.
    By ///M3 CRAZY in forum Forced Induction
    Last Post: 01-04-2006, 08:37 PM
  4. Car is back from paint
    By WTA123 in forum 2002
    Last Post: 11-13-2005, 11:45 PM
  5. Woohoo! My car is back from AA!
    By mrdoenutz in forum Forced Induction
    Last Post: 05-07-2003, 11:48 AM
