Bimmerforums Upgrade Garage The Tire Rack
Results 1 to 3 of 3
Thread: 44mm offset on a 2002 325Ci?
    Dec 2016
    Canada
    2002 325Ci Cabrio
    Hello I've got a 2002 325Ci with ET47(47mm offset) wheels and 225/45rz17 tires.
    I'm looking to buy a used set of 16" 205/55R16 tires/wheels....but the offset is IS44...which I guess is the same as ET44. I believe the car it came from was a 2010 128 model...but not sure.
    my manual shows that 205/55r16 are ok...but it doesnt show the ET.
    I read somewhere that e46's will accept anywhere from 35-47mm. Is that true?
    So, will that 3mm make a difference? Will they fit?
    Dec 2016
    Canada
    2002 325Ci Cabrio
    Actually the used set being sold are off a 2010 323i.
    They should fit on my 2002 325Ci, right?
    The offset difference is 3mm but that should be OK, right?
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    It should fit as long and rim width isn't too far off. If you are looking to pick up OE rims from 128 you should be fine. Be aware that 128i wheels may have run flat tires that will ride very harsh on your e46.
  1. White Vs Black on a 2002 325ci ???
    By Motorx1000 in forum 1999 - 2006 (E46)
    Last Post: 12-19-2007, 12:28 AM
  2. How to run self-diagnostic on a 2002 325CI (Stick Shift)
    By treasureshell in forum 1999 - 2006 (E46)
    Last Post: 11-15-2007, 03:46 PM
  3. OBDII port location on a 2002 325ci (e46)
    By OBS0LETE in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-06-2006, 09:56 PM
  4. M3 Rims on 2002 325ci??
    By RZR SHRP in forum 1999 - 2006 (E46)
    Last Post: 01-05-2006, 03:52 PM
  5. Questions on buying a used 2002 325Ci Convertible.
    By honster in forum 1999 - 2006 (E46)
    Last Post: 01-03-2005, 07:11 PM
