Results 1 to 15 of 15
Thread: Vehicle Order xml file
    Jan 2013
    Canberra, Australia
    850i, 540i sc, 528iT
    Hi all, does anyone have the ability to obtain or create a vehicle order xml file? I had a major crash while coding a footwell module in an E84 and as a result the car has lost its VO. I can reload it using ISTA/P as long as I can get the correct xml file.
    Craig
    1991 BMW 850i Diamond Schwarz / Silbergrau Hell Nappa
    1998 BMW 540i (Supercharged) Arctic Silver / Schwarz Nappa
    1999 BMW 528i Touring Titan Silver / Schwarz leather
    1995 BMW 328i Cabriolet Schwarz / Silbergrau Hell leather
    Sep 2003
    Birmingham, UK
    BMW 850 and E55 AMG
    I've rebuilt one before with NCS expert, you can add all the bits in when editing the VO, and get the original VO from bmwvin.com
    here's part of a VO trace-
    E87_#0905&LHSW%0475*UF92$1CA$249$2MH$302$321$
    So, in the FA editing bit, put E84_ as the model, and fill the other column with your options codes
    #0905 - time criterion
    &LHSW - interior trim
    %0475 - paint code
    *UF92 - model type (chars 4-8 of the VIN)
    $1CA - OPTIONS CODES...
    $249
    $2MH
    $302
    $321
    etc, finishing with the battery type as -A090 for AGM, 90 Ah for example
    Giftschrank Projekt
    Jul 2004
    Houston, TX
    36 Cylinders
    My source for factory VO files (and probably others) will not be available for a week due to the holidays.
    Last 7 of VIN?
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Jan 2013
    Canberra, Australia
    Thanks for the replies! I will check out BMWvin.com, and the last seven of the vin is VP90883.
    Quote Originally Posted by enda320 View Post
    %0475 - paint code
    $249
    $2MH
    $302
    $321
    Thanks for that. I'm using ISTA/P rather than NCS. I understand I need an xml type file - can I just copy the example you have above, enter my vehicles details and options and create an xml based on that? Do you happen to have a full VO xml file you can send me to edit?
    Craig
    Jul 2004
    Houston, TX
    36 Cylinders
    NCSExpert isn't terribly hard to use and it works alongside ISTA. In this case I think it may be better.
    -Abel
    Apr 2009
    Vancouver Isl, BC, Canada
    98 Euro M3, 04 M3, 06 M5
    Never used ISTA to code, and have never had a need for any XML file. Im sure one could be made if we knew the formatting. Do you have an example one?
    That being said, you can use NCS expert and not have to worry about it.. Its also way faster.
    Current:
    - 09 335i MSport, FBO.
    - 98 Euro M3, Estoril Blue
    - 04 M3, Carbon Black, 6 Speed Coupe
    - 06 M5, Black on Black, Full Leather.
    - 73 3.0CS, Tagia Green, 5 speed M30b35 converted
    Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i, 2001 M3, 2006 M5 6 speed
    Jan 2013
    Canberra, Australia
    Quote Originally Posted by legoman67 View Post
    i don't have one yet, I have asked the local dealer for it though. I do have NCS though so I will give it a shot.
    Craig
    Jul 2004
    Houston, TX
    36 Cylinders
    Here you go.
    Remove '.pdf' from name.
    VP90883.xml.pdf
    Also, to create an '.ssd' file for NCSExpert, copy the following text into a '.txt' file, and save it as "AVP90883.ssd" file (deleting '.txt' from it), and you can load it from NCSExpert. Then perform FA_SCHREIBEN job on the two modules that hold VO. Then SG_Codieren job on whole car. Much faster.
    Code:
    M E89_CODIERSCHL ALL
    A 001 WBAVL32040VP908834 E84_*VL32#0311%0A72&KCSW$1CA$1CB$161$2PA$2S9$2TM$205$230$249$255$258$3AP$386$4AE$4CG$413$420$428$493$502$507$520$522$534$544$548$6FL$6VC$606$644$672$700$8KA$8SL$8SM$8SX$8S3$8TG$8TL$8TN$8V1$810$818$825$845$853$876$880$925-B070|0000000|0000000|0000000
    -Abel
    Jan 2013
    Canberra, Australia
    Thanks 328 Power 04! I cant open the xml/pdf file you attached. I think because the computer thinks its a pdf file, but then cant decode it. It it just the xml file but with pdf added as a file type?
    Sorry if these sound like silly questions, but computers are not my strong suite.
    Craig
    Jul 2004
    Houston, TX
    36 Cylinders
    Yes, correct. it is an xml file, pretending to be a pdf, ONLY so I can attach it.
    You MUST rename it to remove the .pdf extension (be careful, Windows sometimes automatically hides the .pdf extension)
    Or PM me your email, and I can send you that way immediately.
    -Abel
    Apr 2018
    Exeter UK
    2008 118i M-Sport
    This is an old thread I know, but I've recently become a BMW owner and currently at the learning stage of ISTA software and require a VO xml file as requested by ISTA-P. I used the example provided by 328 Power 04 and managed to modify most of it to suit my VIN, but unable to determine where to get the information for checkDigit; location; checksum; buildversion and eWord.
    Can anyone help with this?
    May 2018
    Australia
    BMW
    Hey all - did this work out for you? Reading out the VO with NCS to then extract a file to convert to xml to use in ista/p to inject into a new module.
    I’ve got the VO and details, can’t voew the .xml.pdf example in the above.
    Can anyone advise please?
    Oct 2018
    United Kingdom
    Vw touran
    Hello can somebody help me with a VO xml file for f20. I have thos one but is not recognized by ista-p. Maybe the file is incorect. The vin is: J862599
    Thank you.
    Nov 2018
    Finland
    2004 BMW E46 316i
    Tried to create VO file for my E46 today to get ISTA/P recognized my car but no success.
    Can someone help me with this? Vehicle VIN number: WBAEY31040KS41298
    May 2023
    Wiltshire
    BMW X1 Audi A5
    hi, Been trying to read up about creating a VO and came across this thread. Its cheeky i know but are you still able to create a VO at all. I have a very broken car at the moment FRM went down and now neither istaP, inpa NCS expert or will read the car. Ista P does however ask me for a VO.xml file. Honestly have no real clue how to create one and wondered if your able to help me out at all.
  1. Can't read vehicle order PROGMAN
    By Sandmanyz in forum Diagnostic Software
    Last Post: 07-11-2012, 08:37 PM
  2. Progman: Can't read vehicle order
    By delithdra in forum Diagnostic Software
    Last Post: 07-02-2012, 01:53 PM
  3. Vehicle Order Number XML File
    By scottyD in forum Diagnostic Software
    Last Post: 04-11-2010, 07:18 PM
  4. Vehicle Order Number XML File
    By scottyD in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 02-10-2010, 02:39 PM
  5. 335 vehicle order
    By brian95 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-18-2007, 09:01 PM
