Im planning a new build for the next year, containing a boosted m54b30 engine.
Right now im kinda unsure which body i should take for this build, E36 Coupe or E46 Coupe.
Both cars would consist of a low mileage body, a completely rebuild suspension setup, some reinforcements
and a brake upgrade.
Goal is to build a funny, high performance street build - not a daily driver, but comfortable enough to go for a longer trip
bot cars would be equipped with 18" Wheels, a Bilstein B16 Coilover or something similar
and whole new OEM M3 bushings
i already made up my mind about the pros and cons of the both cars -
the E36 being more "puristic", a little lighter but also older and not as stiff as the E46
it would be nice to hear from people who have expierence with maybe both cars
Seeing as the E36 never came with an M54 it already seems the E46 is the obvious choice
E36 just because the parts are less expensive generally
E36 if the block is not aluminum, that way you could bore it if you needed to.
