always trying to make it lighter and faster
^^former build: http://www.bimmerforums.com/forum/sh...-neglected-M3/
current build: http://forums.pelicanparts.com/porsc...car-build.html
instant grams: doktor_b
Ummmm, not a GIF, and no bewbs.... I think that violates recent reply conventions that have clearly been established.
It is a beaut though, as long as it keeps fuel INSIDE it.
All day I was like this knowing I'd go home and get the first start for the JZ E36 since I was getting the last fitting for the fuel rail.
but then I opened the package and
WRONG SIZE FITTING.
I'll pick up the correct one at a local store tomorrow.
Anyways here's some more Radium p0rn for you guys.
instagram @andyitslit
As far as I'm concerned, that post is all win! Hard to imagine how it could be better. I'm in awe.
And sorry about your fittings..
Really cool build. I have lost steam on my S13 drift project, and your car has me on Craigslist now looking for another E36...
Okay despite Radium telling me that the Siemens would work they appear to be too long for this rail as well. Bummer.
Might give in and buy some ID1000s -
Of COURSE you should get some ID1000s
Why not just space up the rail where it bolts down?
I'm just properly pissed off towards the fuel rail/injector situation. Haven't even had time to work on the car for more than 30 minutes.
I might pop in some E36 injectors tonight to at least get it fired up and hear it roar.
Mine are deka 60s but same thing size wise.
maybe I'll pick these up
http://www.ebay.com/itm/Siemens-Deka...4AAOSwEK9UC1Ri
What do you have against using some spacers for about 60 cents?
[I made up that number, but it's probably not more than about 60 cents off from accurate...]
Well I got the new 80lb shorty injectors and she fired up first try.
https://flic.kr/p/SDoL9B - Video link
No IC and no vacuum lines whatsoever.
Yes
DUDE, SWEEET!!
Almost as sweet as this:
That isn't Scarlett!
I feel bad about it too, but about this dude's 1JZ sounding like it does I feel like..
(he seems to love this chick... I do see redeeming qualities in her. )
I just had to watch that startup vid a couple more times. Did youthrow cams in that sucker, or is it just loping like that because the MAF isn't connected? Sounds soooo sweet.
No Cams on it yet maybe soon
Let's see possible reasons it sounds lopey
- No vacuum lines hooked up anywhere
- MAP sensor in AEM looking for stock sensor vs the AEM 1 bar I'm using (remind me to upgrade this pfft 1bar what was I thinking)
- No coolant ecu sensor plugged
- No Intake Air Temp sensor plugged
- Idle air control is deleted
Thinking out the intercooler mounting and piping currently, have I mentioned how much I wish I could weld?
Noticed my stock metal bumper is all sorts of cut from a previous owner. Might be going with a bash bar right away.
Wish you were closer, I love to weld. Actually I wish I was closer to you, it's like 28 degrees F here today. Heavy on the "F!"
So with that hacked up front end are you going to do some work on that front end body?
