Page 2 of 12 FirstFirst 1234567891011 ... LastLast
Results 26 to 50 of 285
Thread: Project Lit Banana Drift Car E36
  1. #26
    fairfax,va, usa
    2 E30s and a maxima
    You're basically right. When you're on throttle, you have to mash the brakes really hard to get them to do anything. Then if you hit vac, BAM, locked wheels. So just don't lift!
  2. #27
    Oct 2012
    Las Vegas, NV
    E36 M3, jzxE28
    Well I got the flu or something thanks to someone from work so I didn't get to do much. Picked up the remaining sensors needed for the engine.
    Just something I wanted to point out on the cam sensors is that they have this rubber seal that eventually goes bad. Oil then travels through the sensor into the connector pins and causes a bad reading. This made the E28 run crappy for a long time until I found it. I only need 1 cam sensor technically since I'm using AEM but I grabbed two to have a spare and since the block off plates are pretty much the same cost. (which is dumb for a lil plate)
    instagram @andyitslit
  3. #28
    Oct 2012
    Las Vegas, NV
    E36 M3, jzxE28
    Alright I was able to test fit the manifold. It slips in just barely next to the booster, definitely something I recommend having on before installing the motor for anyone who's going to do the swap.
    I also jacked up the transmission to see how much further back it sits and the room I'd have for fuel lines to the rail.
    Guestimate measurements since I'm still too sick to get under the car is about 2" further back.
    Also does anyone have any good ideas on where to mount a fuel pressure regulator? Firewall seems like the best place if I can make a plate for the blower motor hole.
  4. #29
    Oct 2012
    Las Vegas, NV
    E36 M3, jzxE28
    Another small update. I bought more parts. YAY PARTS PARTS PARTS PARTS.
    Aeromotive FPR. 30-70psi should do just fine.
    Oil Cooler and some fittings. Hoses were on backorder from summit (lol????) so I'm still waiting on those.
    Then I went ahead and replaced cam seals and got the engine timed, alternator on also.
    I ran into an issue. The bolt for the serpentine tensioner stripped.
    Went and ordered a 2JZ one on eBay.
    I'm still unsure of where to mount the FPR. My initial idea was to make a plate for this firewall hole out of ABS (stealing the idea from Mike) but I'd have to ditch the windshield wipers.
    Regardless pretty much on the home stretch and provided there aren't many more hiccups I should be firing the beast up in the following weeks.
  5. #30
    fairfax,va, usa
    2 E30s and a maxima
    Quote Originally Posted by Press22 View Post
    Famous last words
    GL brother!
  6. #31
    Jan 2014
    San Antonio
    98 328is
    stupid question possibly. i understand that the driveline was pushed back with the mounts. Why is this? This would be an almost drop in affair if the mounts put the motor where it would be with the adapter. i was thinking of doing this in my 328 if i ever blew it up, but i dont have the budget or the know how and welder to make new mounts and new driveshafts and stuff like that.
  7. #32
    Oct 2012
    Las Vegas, NV
    E36 M3, jzxE28
    Quote Originally Posted by RandomHero27 View Post
    I wouldn't recommend a JZ swap if your budget is small. I can't weld, I pay someone for all that :P
    Put on these compression fittings for fuel line, they're a pain. I tightened them a little more after the picture but if they leak I'll probably just ditch the whole hardlines and use steel braided all the way from the tank.
    I also put in the AKG shifter and started making supra noises with my mouth.
    It needs a selector rod about half the length of the stock selector rod.
  8. #33
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    I used those compression fittings for all my fuel lines, they're still working great
  9. #34
    Oct 2012
    Las Vegas, NV
    E36 M3, jzxE28
    Quote Originally Posted by Novablue454 View Post
    How tight are you able to get the joints? I know it's normal for AN not to touch but these have quite a gap.
    Oil Cooler Sandwich Plate in from Earls with a driftmotion adapter. Will probably use some 90° fittings over these 45°. and that hose right above is for the stock water-cooled oil cooler, which I ordered a plug for... guess that never arrived...
  10. #35
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    they look pretty much like yours. The first one I overtightened and it actually ripped the end off the tube I was putting it on, and it still had a gap like that. I powered my fuel pump with a power probe and tested the system for leaks before I tried to start the car, and I would recommend doing that on yours as well. I found I didn't tighten the fitting in to my pressure gauge well enough and it was leaking right on to my header.
  11. #36
    Aug 2014
    Ontario
    1999 325i, 1996 RSTi Cou
    Hey man great build so far! Sparking an interest in this swap after reading through yours.
    With the Wiring Specialties harness, how difficult would you say the wiring process is?
  12. #37
    Oct 2012
    Las Vegas, NV
    E36 M3, jzxE28
    Quote Originally Posted by rstaylor25 View Post
    Incredibly easy. They make it plug and play, everything is labeled. Even making your own harness isn't too difficult. Since I know where everything goes on a JZ it'll take me about 5 minutes. It's something I want to do already but want to get it on video for the youtube account.
    Edit: I'm a bit of a wiring nerd though. Dunno why it scares so many people off.
  13. #38
    fairfax,va, usa
    2 E30s and a maxima
    Because the average guy doesn't know what the point of relays are; Or the difference/relationship between volts and amps. All it takes is some probing without fuses, connecting wires together you think go together for your first engine bay fire or wire meltdown.
  14. #39
    Oct 2012
    Las Vegas, NV
    E36 M3, jzxE28
    Quote Originally Posted by protomor View Post
    True. More people should just take the time to learn it though. I know some guys who could tear down and rebuild a engine but will struggle to wire a electric fan.
  15. #40
    fairfax,va, usa
    2 E30s and a maxima
    Engines come with a manual. Making your own wiring harness does not. There's a fine line between mechanic and a true tuner.
    Rabble rabble rabble. Back in MY day...
  16. #41
    DeWitt, Michigan
    '97 540i/6, '97 328i
    Quoted for pure awesomeness!
  17. #42
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    isn't a wiring harness manual called a diagram?
  18. #43
    fairfax,va, usa
    2 E30s and a maxima
    Lol well yea. But there's servicing a factory harness, and wiring in your own stuff.
  19. #44
    Oct 2012
    Las Vegas, NV
    E36 M3, jzxE28
    Building it is easy.
    sourcing all the materials is the headache.
    In other news, still have not received my AN hoses from SummitRacing. lol
  20. #45
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    cool build.
    don't forget to check out Speedway Motors for parts. they are the company i shop against Summit.
    and then there's Amazon.
    those are my parts holy trinity. i usually build the same order in all 3 and then cherry pick to get the best total pricing.
    always trying to make it lighter and faster
    ^^former build: http://www.bimmerforums.com/forum/sh...-neglected-M3/
    current build: http://forums.pelicanparts.com/porsc...car-build.html
    instant grams: doktor_b
  21. #46
    Oct 2012
    Las Vegas, NV
    E36 M3, jzxE28
    Quote Originally Posted by doktor b View Post
    cool build.
    Thanks! I'll checkout speedway motors. I usually just do summit since most of their stuff is in Reno, NV and I'm in Vegas so it's 1 day shipping.
    But who's to expect they'd be backordered on AN 6 and AN 10 lines. :P
    Got the Hard Motorsport Dash vent cover plate thingy majiggy today. I was gonna make it but they had a half off sale so what the hell right?
    (currently crying over not having a radio in the racecar though... no more sweet tunes on grid )
  22. #47
    May 2014
    Noblesville, IN
    98 328i, 79 911SC
    and i like Summit because they have a warehouse ~5 hours away in Ohio. one day shipping. MOF, the bits i ordered today for my oil pressure sending unit relocation will be here tomorrow. gotta love Summit. Speedway is a little slower, but no slouch. Amazon is great if you have Prime....but no Prime, no joy.
    i saw HardMotorsport was blowing out those dash/vent plate deals. i almost pulled the trigger, but i have an OE radio delete plate to mount the gauges in and i'm keeping heat. it can be cold/wet here any time of year and i don't want to fight to keep my windows clear. (not that i can reach them when harnessed in)
  23. #48
    BALTIMORE
    the idea of not being able to jam out to new new music on track makes me sad
    Popular engine swap weights & stock engine weights
    M42 + trans - 427lbs
    302 + t5 trans - 475lbs
    m20b27 + g260 - 497lbs
    m52b25 vanos + g250 - 544lbs
    351w + t5 trans - 572.5lbs
    LS,
    aluminum block + t56 - 609lbs
    LS, iron block + t56 - 719lbs, EST.
    http://www.bimmerforums.com/forum/sh...60-m42-1jz-2jz
  24. #49
    Oct 2012
    Las Vegas, NV
    E36 M3, jzxE28
    Quote Originally Posted by jalopi View Post
    I'm not giving up. trying to think up a workaround to this. all I really need is a on/off switch and volume, I always leave a mp3 connected. maybe some sort of hidden radio
    Edit: Mount this on my future rollcage lmfao
  25. #50
    Jun 2005
    Lincoln, NE
    E34, E36, E36/7
    cool build.
    speedway is just across town from me. Came in handy when sourcing fittings for my E34 let me tell ya
    13 Grand Cherokee Limited V8 - Daily Driver - Wife
    97 Z3 2.8 Roadster
    95 325i Sedan - Project #ebayE36
    90 BMW 535i/5 - i should probably work on this again...
  1. E36 NY: 1992 e36 325is gutted drift car
    By joeemartuccii in forum 3 series & Z Series
    Last Post: 10-15-2013, 03:23 PM
  2. E36 Parting E36 DRIFT car
    By 6gen91 in forum Race Cars & Track Parts
    Last Post: 07-19-2013, 10:06 PM
  3. E36 BMW E36 5.0l twinturbo Drift Car
    By ESTPerformance in forum Race Cars & Track Parts
    Last Post: 07-18-2013, 01:02 PM
  4. E36 WTB: E36 Project/Drift Car/Gutted? (CALI)
    By thejman808 in forum 3 series & Z Series
    Last Post: 04-06-2013, 05:21 AM
  5. New drift car! e36 325
    By alanbmoore in forum Drifting
    Last Post: 03-08-2011, 06:44 AM
