Page 3 of 10 FirstFirst 12345678910 LastLast
Results 51 to 75 of 247
Thread: Z3M Coupe for trackday use
  1. #51
    Salem, Nh
    01 Z3M Coupe
    Great build, I'm in the process of doing the same on my Z3M coupe.
    Glad to see you're putting a real cage in, I could not help but notice the curves in the main front bars of what was in the car.
    They would have folded easily in a crash.
  2. #52
    Dec 2016
    France Clermont Ferrand
    Z3M Coupe '98 X3 3.0i
    Thank you for all your messages !
    Yes, security and staying alive are the most important things.
    I have two targets :
    Security (as my son is coming with often during trackdays)
    And meet the FFSA(French one) and FIA rules
    I'm Also trying to have an efficient but easy to pilot coupe.
    Thank you for reading !
  3. #53
    Dec 2016
    My vintage car's club friends are working on a Formula 2 replica with V6 Dino Ferrari, very nice, isn't it ?
    More classical coupe sorry :
    5,4 kilos 12 pounds saves with 3 lexan rear windows (trunk one and 2 rear one)
  4. #54
    Nov 2005
    Finland
    Z3 Coupe individual
    Quote Originally Posted by BimmerBreaker View Post
    Is that the Hartge coupe? AFAIK they only produced one "5.0 coupe" (actually used a modified M62 not the M5's S62) and it was silver and completely intact a year or so ago when it was for sale.
    That has been in netherlands for ages and also for sale for ages. That car: http://jalopnik.com/for-51-600-this-...-th-1685182564
    Being that we have at least two S85B50 engined M Coupes, I would say that there is at least 5 other S62 engined coupes easily out there... But I dont think they were made by Hartge but someone individual later.
    Z3 & E36 RamAir systems, send private message for more information.
  5. #55
    Dec 2016
    Today, I worked on the rear axle.
    The weight is 37 kilos 82 pounds with screws and oil.
    The ratio is 4,67 :
    Some paint :
    On of my friend borrowed me this broken part from M3 E36 3liter, I'd like to use it to make a second "ears" for my rear axle. we'll see that point later.
    Better like this
    It was very very hard to mount the rear axle, because the Powerflex push it to the rear and it was so hard to put the 4 srews, some F..... BMW and Powerflex helped me a little !!
    4 and half hours later !
  6. #56
    Dec 2016
    I mounted dashboard and the rear anti-roll bar
    FIA hook
    I started the motor !!! It worked very well even without intake manifold and water.
    warning is working but not turn signals, lights are ok not the high beam some work to do !
  7. #57
    Dec 2016
    Slotted hole for my FIA " hook" I have stil some work to do on it to make it nicer, also special screw dzus for motorcycle (ebay)
    19 mm is ok, I tested with dzus 15 mm long it was too short.
  8. #58
    Dec 2016
    I will try this :
    C'est la panique, plus de feux de route ni de croisement, pas de clignotants, pourquoi ?? Sans doute un mauvais coup de ceux qui ont m'ont fait l'arceau :suspect: :suspect: :suspect:
    You remeber no more stop light, I thought I made a mistake when I worked on the wires...
    My friend found the plug, it was hidden behind the dashboard ! Now it works !
    Another mistake, I'm so embarrased to tell you the truth !
    No mote light and turn signal, once again my friend (which is a BMW "M" specialist) laughed at me.
    Hey Gatouille just push the ignition button on !
    I tried to forget my shame while mounting both water and oil 's radiators
    Wire's light are in place
    Very happy to close this Pandora's box !
    Water cooling expansion tank had to be adapted because the roll cage.
    Many boxes on my table mean very much to do !
    You what ? I'm happy !
  9. #59
    Dec 2016
    How to keep together the front bumper and the bonnet, before it was not easy to use and not reliable.
    Now it's ok !
  10. #60
    Dec 2016
    Some black paint.
    Rear shock
    My tires are ready for 2017 !
    On my Lexan's windows I want the black part all arround it. I ask for a sticker'maker (who own a M3 E36 S50B32 for race!)
    He's got a file for M coupe !
    The file is not enough precise and unfortunately we can't use it, he gave me this to it myself,
  11. #61
    Dec 2016
    Air for brakes, home made with part for....water-closed ! and parts of carbonfiber
  12. #62
    Dec 2016
    This was for door's electrical wires, now it is a little air vent for people inside the car !
    One door
    Everything is ok
  13. #63
    Jul 2005
    Temecula Ca.
    99 M Coupe LS Swap
    I like the vent. Not going to do shit, but funny. When you are cutting out the lexan for the windows, do a couple extra fronts and keep the protection covers on them. You will need to replace fairly often The sourcing and setup to cut is more effort than finding a good place to store extras. The bow in our front glass is enough to support 165MPH. Never been faster so can't tell you if a reinforcement bar is needed above that speed. My gut says no. Its pretty strong.
    Dan "PbFut" Rose
  14. #64
    SF Bay Area, CA
    BMWs: 1; MINIs: 1
    The vent might conceivably do something if there are no front wheel fender liners. But I think you want the fender liners. I postulate that they smooth out the aero under the bumper and around the front wheels. It makes it a little harder to do brake ducting but it's totally doable.
    I like the unicorns.
    '99 Z3 Coupe - Jet Black/Black (1-of-114)
    '99 M Coupe - Estoril Blue/Black (1-of-82)
    '03 540iT - Sterling Gray/Black (1-of-24)
    '16 Z4 sDrive35i - Estoril Blue/Walnut (1-of-8)
  15. #65
    Dec 2016
    Thank you JoshS and PbFut
  16. #66
    Dec 2016
    I decided to change the rod bearing shell, if you look on the Internet for M3 E36 E46 and even later, there are pages and pages
    about it !
    We can either consider that it is a weak point, or as I think of it, to consider that it is the maintenance running
    A special tool would be needed,
    Some S50B32's crankcase has got one drain plug some one them has got 2, mine has got only one, that a shame ! that let more dirty oil inside.
  17. #67
    Dec 2016
    A Wreck, I will keep the body(frame?) because the front is ok and rear left. A very rare bonnet from HARGE will be repair, it's got big holes for fresh air.
    Everything is ok in my "crankcase" !
    1 and 2
    3 4
    5 6
  18. #68
    montreal
    2001 M Coupe, 2006 M3
    ohhh nice find on the hood...
  19. #69
    Dec 2016
    We continued the roll cage (French rules)
    Black stickers on macrolon's windows look like OEM and will hide the eggly black glue.
  20. #70
    oskaloosa,ia
    '01 3.0 ZCoupe
    I seriously cannot wait to see some video from the track with this car. It is going to be a beautiful racecar.
  21. #71
    Dec 2016
    Thank you !
    Dashbord is stil messy, but work is in progress
    Doors :
  22. #72
    Awesome build, keep up the progress
    That coupe with Hartge hood... What engine does that car have?
    PRICE CUT on ALL FABRICS
  23. #73
    Dec 2016
    Thanks, it's a 2,8 liter one 192 hp
    In Europe coupe were available with 4 motors
    2,8 liter 192 hp
    3.0 liter 231 hp
    M S50B32 321 hp '98 ---->'01
    M S54B32 325 hp '01----->'02
  24. #74
    Jul 2004
    Houston, TX
    36 Cylinders
    Hahah, you were hoping real hard huh.
    Ya, it would have been funny if it was the 5.0, and not noticed. Or the 3.5...
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  25. #75
    Dec 2016
    Cleaning before Windscreen and rear windows, it's easier before !
    To prevent dust and insects, when I will make mistake on track and go to the grass area...
    I will change two hoses for steering.
  1. Help Need Z3M coupe for Test Fit in Long Island: Please me want these wheelsssss
    By redphu72 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 04-22-2013, 06:07 PM
  2. FS/FT: NC Z3M Coupe for E39 M5 + cash
    By EBM3WSNC in forum 5 series & 6 series
    Last Post: 02-07-2012, 09:11 AM
  3. Leads on a white Z3M Coupe for sale?
    By stefanot in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-16-2011, 07:42 PM
  4. Z3M Coupe for sale in Philly, anyone's on here?
    By Car54 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 01-13-2008, 01:39 PM
  5. Race Z3M Coupé for sale
    By joakim in forum Professional Motorsports sponsored by Bimmerworld
    Last Post: 03-25-2002, 08:51 PM
