Results 1 to 2 of 2
Thread: Check engine code/mycarly code error. Is it throttle fault or wiring harness
    Dec 2015
    Philippines
    E87
    So I have this intermittent check engine light error on my 2005 e87 A/T 80k KM that comes up every now and then after driving for a few miles.
    The acceleration of my car becomes erratic making it slow or makikg it fast and sometimes when it's on the engine gives a clucking sound that might be the piston head(this is what gets me worried).
    So I set up my carly diagnostic and it shows the code on the attached picture. I searched around the internet and found out that if it's a TPS error a full throttle body should be replaced and tha's alright but what scares me is that it might be the wiring harness(found out that a throttle code may be a cause of bad wiring harness) in which they say is pretty costly. So are these codes specific or usually it might be the harness that's causing the problem.
    I don't want to replace a throttle body which is normally functioning and most of all I don't want to replace the whole wiring harness if it is really the problem.
    Dec 2015
    Philippines
    E87
    Up
  1. Check engine code/mycarly code error. Is it throttle fault or wiring harness
    By jrnozid in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-08-2016, 11:30 PM
  2. Need Help. "Check Engine" light: 1215 Code
    By phillyB///M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 11-23-2004, 07:21 PM
  3. Need Help. "Check Engine" light: 1215 Code
    By phillyB///M3 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-22-2004, 01:54 AM
  4. 2001 bmw 330i auto check engine light HELP!! codes P0786 PO128
    By overmind22 in forum 1999 - 2006 (E46)
    Last Post: 11-03-2004, 09:13 PM
  5. Check Engine Light...ODB2 code (P0420)???
    By ///M3Turbo in forum 1992 - 1999 M3 (E36)
    Last Post: 04-05-2004, 10:43 AM
