Results 1 to 6 of 6
Thread: Real cause of E46 318i oil leak problems?
    Feb 2013
    Brisbane, Queensland, AUS
    '89 535i, '00 735i sport
    Hi all. My daughter's 2003 318i has had a long history of recurring oil leaks and I believe there is some sort of breather buried under the inlet manifold that if blocked with crud, leads to an overpressure situation in the engine and subsequent oil leak issues. Can anyone out there confirm that this is the case and identify the breather part that I need to clean or replace?
    John
    Dec 2013
    Chicagoland area
    EXOTICS
    For a proper diagnosis & confirmation, you really should have a diagnostic scan performed, with a scan tool/computer with BMW software.
    I believe you are referring to the crankcase ventilation system, and symptom you describe is possibly due to a failed CCV, number#1 pictured here: https://www.realoem.com/bmw/enUS/showparts?id=CA08-ZA-06-1996-E36-BMW-318i&diagId=11_
    I am not sure of your engine, you can verify at the top of my link-Select another car, and entering the last 7digits of your VIN#
    Feb 2013
    Thanks heaps, I'll check it when I get home tonight
    Dec 2016
    Ireland
    E36 mtech
    Guys I know this isn't related but I've had my e46 a week and I'm pretty young and I bent my dad's lug wrench tryna take the wheel off. Do I need a specific bmw one or are they just super tight..?
    Dec 2013
    Chicagoland area
    EXOTICS
    Your dad shouldn't blame you for that hopefully, as it probably was installed (incorrectly) by someone using an airtool , instead of a socket and wrench (torque). Hopefully not an airhammer, then really, super tight! Next time, attempt to loosen with the correct size socket along with a long handled, breaker bar.
    Lug wrenches, lol, they just don't make them like they used to. Cheap Chinese crap probably would have bent anyways.
    Dec 2016
    Ireland
    E36 mtech
    @mikyzz4 Thanks. A mate up the road got them off with a breaker bar.
  1. Real cause of leaking vapor barrier
    By packrat555 in forum 1996 - 2003 (E39)
    Last Post: 04-08-2024, 04:41 PM
  2. E46 318i starter motor problem. Then coolant and oil lights.
    By Xexxa in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-15-2015, 06:08 PM
  3. 1991 e30 318i oil leak and other problems.
    By crap60148 in forum 1983 - 1991 (E30)
    Last Post: 06-13-2013, 03:54 PM
  4. Hood wont open ... what's the real cause of the problem?
    By supermanwithheat in forum 1991 - 1999 (E36)
    Last Post: 05-01-2013, 04:26 PM
  5. E46 318i 2000 rpm problem
    By xhilerate in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-08-2002, 03:11 PM
