Which cars are good donors for LSDs? I am looking for a 315 for my 97. Are there several that will work?
No, there is only one real "donor" and that is the early E32 750iL 3.15 limited-slip.
I found mine on Craigslist for around $200 and I have seen these in the pick-your-part self serve junkyards. Knowing how the market has gone with these, I wish I had taken the time to pull some.
I saw Olin's post on the install and I copied him. I didn't do the installation myself but it was well worth the expense. Really good bang for the buck.
Working on creating 3.64 LSD for e31.
Will post something when I'm done.
http://www.bimmerforums.com/forum/sh...LSD-into-840Ci
What happened to the DIY section? All the threads are gone!
I swear, my cars are like a girlfriend.
Sometimes its a rough ride, sometimes its smooth motorin'.
Sometimes she doesnt like how i treat her and sometimes i dont like how she behaves.
BUT at the end of the day, she loves it when I am inside her.
Here in Europe e34 535 has typ 210, that's a fact. Also most e32 has typ 210
Don't know american cars but sure feels weird if they are eguipped with something else.
Euro market cars for the most part have different ratios also US based 525, 535i have medium case 188mm diffs..
I put a 3.64 LSD from an E32 750Li in my 97 840. I'm very happy with it. A 3.15 might be a better choice for Interstate cruising, but I'm mostly on city and country roads where the 3.64 is ideal.
So a 188mm medium case 3.64 differential from an E32 or E34 will fit my 97 840?
If it does, You'll soon break it.
3.64 is pretty nuts in an 840. You will forget that the car is over 4k lbs.
What "thumbs up" really means
Is the 3.64 that much better than the open diff that's current installed even if it's not a limited slip? What changes as you go from a 3.15 to a 3.64? I suck at gear ratios. Have no clue honestly. I don't even know what's currently installed in mine... All I know is that it is not an LSD. At least it's not pulling up in the options list.
Make sure it is in fact an LSD. I made that mistake recently, just assumed it was an LSD because it was a 3.64. YMMV, I'm a moron.
Jeremy Smith
94 840Ci
98 Porsche 986
02 Mini Cooper
13 Ford F150 Platinum
It will make the car feel alot lighter and 0-60 acceleration will be much improved. Basically it will put a big grin on your face
3.64 LSD are close to impossible to find and they are expensive compared to 3.64 open so I suggest looking for a 3.64 open.
I have a very low mileage one 48k miles, but not letting it go cheap, $900 plus shipping.
What does the 840 come with from the factory? 2.81?
US 1997 840Ci M62 came with a 2.81 OPEN. Euro 2.93. Source: http://www.e31.net/technical.html All you ever wanted to know about E31s.
