Originally Posted by
gdking32
I have a troubling rattling noise coming from the intake side of the engine at idle on my E83 with 106,000 miles. I have rebuilt the DISA valve (it was not the problem), replaced the water pump (it was not the problem), the idler on Alternator (it was not the problem), the mechanical tensioner (it was not the problem) and finally the alternator itself (it was not the problem).I also checked the tightness of all six spark plugs and ran the car with the AC compressor belt removed. The noise is definitely coming from the top of the engine from either the valve train or somewhere close by. To make matters more complicated I am not getting a single DTC when I scan the car with the Bavarian Technic Scan Tool. The sound goes away when you press on the accelerator and the car runs great, except for the bloody noise. Any advice would be appreciated.
What your describe sounds like a vanos rattle. Do a search for "m54 vanos rattle" and maybe you will find your answer. There's several videos of the rattle as well as how to fix it. It's a common issue with M54's.
Current Garage:
91 e34 M5 - spoiled & demanding 27 y/o -glanzshwarz
91 850i/6 -another spoiled & demanding 27 y/o- schwarz-gone but never forgotten
06 325i - undeserving, spoiled & demanding 27 y/o daughter's DD-hellrot
03 MINI Cooper S JCW -spoiled & demanding, yet deserving wife's DD - Chili/Panther
05 X3 3.0i -family workhorse - diamond schwarz
12 X5 3.5d - torque monster - space gray metallic
86 GMC Cabellero - Old Faithful 32 y/o DD BMW Support Vehicle
08 Cub Cadet 19HP 46" hydrostatic- yard vehicle
88 Schwinn Sierra - 1WD Off Road Vehicle
e31 & OHC BMW CCA #385540
