Results 1 to 16 of 16
Thread: Door handle gaskets
    Oct 2016
    New York
    1994 BMW 740i
    Door handle gaskets
    I bought some door handle gaskets on Ebay for my 1994 740i and found them to be junk. I did a search and found an old post where Shogun sold them a while back. Are they still available from him or anybody else. Thank youDSC08127.JPG
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    You are not the first one which first buys the cheap ebay junk and buys from me then later. Have stock, just sent one set to Canada see my offer here http://www.bimmerforums.com/forum/sh...E32-E34-E36-Z3
    Jul 2013
    SoCal
    '89 735iL +
    Ah, I saw those, from Thailand, I believe. Once sorry I didn't get a set, I am no longer. Working bigger 'fish' ATM, tho. THX, Shogun for all you do for us.
    Jan 2005
    Japan
    Comment by paul 4332 on 06-12-2016 in a DIY on the E36 forum: I just did this repair on my M Coupe and would not have been successful if it hadn't been for all the good folks who contributed to this thread. I read virtually every post, watched a few YouTube videos, read Shogun's DIY and more. It took some time but eventually I was able to remove the covers and old gaskets and attach the new gaskets to the handle covers. The gaskets were sourced from Shogun- they fit perfectly BTW. They are rubber, not like the ill-fitting junk I got from Thailand.
    http://www.bimmerforums.com/forum/sh...dle-Trim/page4
    Richmond, Virginia
    '88 735i, '06 RSX
    I can attest, shogun's gaskets are quality pieces. do it right once and save your locking mechanism!
    Oct 2016
    New York
    1994 BMW 740i
    After receiving these gasket I can attest to their quality and thank you very much Shogun
    Jan 2005
    Japan
    Thanks for the comments.
    @Whiteghost1: 1 set is on the way to Canada.
    Nov 2015
    Pgh, Pennsylvania
    1990 735i 3.5/automatic
    I need to do mine eventually. But I don't want to have to remove all my door panels and handles...ugh!!
    May 2012
    Boynton Beach, Florida
    1990 735I (E32) M30
    You don't need to Tony. Just the little rubber plug inside the door frame. It's an easy fix once you get the gaskets. If your door handle frames are good you only need new gaskets. A little screwdriver with a hook on the end and you'll be surprised how fast you can replace all four gaskets. If you get them, shogun can send you his link, or I'll tell you how I did them. If yours are bad, they'll give your four door handles a completely new look. Also no more water dripping down into the mechanism.
    Jeff
    1990 735I (Auto) E32 Feb 1990 to Present
    1996 Z3 Roadster (5 Speed) E36/7 Jan 1999 to Dec 1999
    1983 733I (5 Speed) E23 April 1983 to Feb 1990
    https://www.youtube.com/watch?v=2d4tHoHGaJo
    https://1drv.ms/v/s!Av20xCMMocSsyEpl...h_oOk?e=ekIcAT
    Jan 2005
    Japan
    No need to remove door panels and handles, only the outer doorhandle trim, there is a slider. See here
    http://twrite.org/shogunnew/fixes/do..._handle_gasket
    http://www.bimmerboard.com/forums/posts/304688
    You only need one tool: Go to your local hardware or paint store and pick up a paint can opener, or a small ring spanner
    http://lh4.ggpht.com/_7RlBKL_aYh8/Sm...6/IMG_6204.JPG
    You might need a new rubber cap/plug, as they are very brittle. http://www.realoem.com/bmw/enUS/show...diagId=41_0697
    Should be probably # 11 Blind plug 12X24MM 51711863869 (check the dimensions)
    Nov 2015
    Pgh, Pennsylvania
    Ohhhhh crap!! I have been watching these nice new ones you sale. And I have avoided doing it. Another link boomarked. I need to order these while mine is down for the winter.
    Oct 2014
    fort walton beach, FL
    '83 320i / '87 325is
    Door handle gaskets came in today!
    Jan 2005
    Japan
    @Incae21: doorhandle gaskets for your E32 shipped to Woodbridge, VA
    @Benjamin: 1 x 4-door set for your E32 730i straight six shipped to Schaufling, Germany
    @masbury: 1 set for your 750 is on the way to Kuna, Idaho
    @Malte: 1 set for your E32 shipped to Essen, Germany
    Jul 2016
    Austin, TX
    2 e9's, 320is, 996 Turbo
    Just wanted to send out a quick shout to thank Shogun and whoever did this little tutorial:
    as I replaced my handle gaskets in less than half an hour for all four doors. Gasket/seals fit perfect and the instructions were foolproof!
    Cheers!
    Mar 2004
    Silverton, Oregon
    E31-E36, E70, E46
    Just PM'd Shogun..lol the night I got my E32 I scrubbed her down but-good..especially around the door handles. I thought they were all mildew and moss, but a lot of what I was scrubbing off (it was in a violent rainstorm and it was getting dark) was the actual gaskets around each handle!
    EDIT--For the heck of it, I actually finally got the stopper off the hole on one door last night and thought I'd give this procedure a try. It is amazingly simple. And yeah, the Ebay gaskets are COMPLETE crapp. I mean the little tabs don't fit anywhere near where the holes are, and if you crammed it on it'd be a wrinkled up mess. The shape was awful and not close to correct.
    But the door handles do look better without a gasket than with a poor/cracked one. And the procedure is not as daunting as I thought just 48 hours ago lol. The toughest part will be the cleaning of the old dirt and stains from the body where the gasket edge was. A little bit of medium/coarse cut cleaner and a microfiber cloth does the trick with a little elbow grease..
    The car will really look complete in a couple of weeks, I trust
    Thanks,
    B
    Brian A Silverton, OR
    '85 Euro 635CSi 5 speed conversion
    '87 L7
    '93 Euro M5 3.8
    '93 740i
    '94 850CSi #31
    '95 540i Msport 6 speed
    '96 M3/4/6 Euro 3.2l
    '03 M3 Cab
    '12 X5 3.5D Tuned
    Unofficial 1995 BMW 540i MSport registrar (please see Facebook BMW 1995 BMW540i Msport registry group to join or report a sale)
    Jan 2005
    Japan
    @Joachim: 1 set doorhandle gaskets for your E32 740i shipped to Duisburg, Germany
  1. Door Handle Gaskets For Sale on Ebay
    By roberthunter in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 09-13-2007, 09:03 AM
  2. Anyone know a good source for door handle gaskets?
    By jeffc in forum 1988 - 1996 (E34)
    Last Post: 05-29-2007, 08:17 PM
  3. Door handle gasket help wtf !!!!
    By zx7rhitch in forum 1991 - 1999 (E36)
    Last Post: 05-22-2007, 10:48 PM
  4. wtb: oem clear, door handle gaskets
    By Clbsprt ti in forum BMW Parts Wanted
    Last Post: 06-13-2005, 10:12 PM
  5. Need Part # Door handle gaskets
    By hal9000 in forum 1992 - 1999 M3 (E36)
    Last Post: 08-06-2004, 09:34 AM
