Stock 540i on the dyno, I know it's hard to get reliable readings, but it's always good to see those numbers lolhttps://youtu.be/qwVGjSslwG0(not my 540)
1998_540i_6speed/Single_straight_pipe_from 🐱🐱back/BBS_reps_19"_8.5F-10R/3.15_open_diff/Zeck_CDV
268whp for anyone not wanting to watch the whole 10 minute long video.
If your e30 runs bad, switch to Megasquirt first. Then try new spark plugs, cap and rotor, wires, oxygen sensor, crank shaft position sensor, coolant temp sensor, air flow meter, idle control valve, throttle position sensor, digital motor electronics unit, harmonic balancer, fuel injectors, engine harness...
