I just sold a suburban that I used as storage for some of my BMW parts. My garage was already full of parts but now it's out of control. I need to sell allot of it. If you see something you want let me know. I'll try to take more pics in the daylight. mostly interior stock parts
Sent from my 831C using Tapatalk
I'm looking for a drivers coupe door panel, or at least the pocket pieces and the pieces that mount the door panel on. Where the white clips go
Sent from my iPhone using Tapatalk Pro
what color are you needing?
Black
okie dokie i'll get pictures of what I have. are you needing one with or without the airbag?
Got any fresh looking fan clutches with plastic fan itself? For 6 cyl.
Don't need pics, I trust you - just inspect fan blades for cracks near the base. Email me price shipped to 01801 pls - you have my email - hungry4bigair... What else was refreshed during the cooling system overhaul?
Would you happened to have tan seats from a coupe that have know good heating elements? I'd take the cushions.
Could also use a heater valve from obdII car (though I think they are all the same).
Thinking what else I could use for the beater...
Thanks.
I think without, it's for a 94
Everything was refreshed during the system overhaul, but I used most of it on another car. I still have the expansion tank and i'll be replacing the radiator with a Mishimoto one once I have time to install it. I do have a heater valve from an obd2 car and thankfully it's still in there otherwise I probably wouldn't be able to distinguish it from all the other ones I have lol
I have tan seats from a coupe at the shop and I can't remember if they are heated or not. I can check when I go sown there this weekend and get back with you
awesome, I have several of those. I'll check pics and send you
any air intakes aftermarket or OEM?
Get any pics of door panel?
I need a heater valve for e36 obd 2 if it matters and possible coupe drivers side door handle in good condition if. This other option keeps whining about shipping it. Yeah I know.and possible s52 oil pan or any upgradable option for the pan and the pump while I'm already in there. Definitely need the good valve asap and door handle. I'm still checking about what to do on the pan but if you have it I'll probably just. Tell you go ahead and ship it for a good price. Thanks.pm me
I didn't get a chance to pull them out of the parts car they are in. It was rainy all weekend and had allot going on. Should be able to pull them all out and get some pics tonight. I apologize for the delay.
I have a cheap generic cold air intake on my 98 M3 I would sell and I also have a brand new Dinan cold air intake I would sell that I planned on putting on my 98. I believe I have a stock intake but the clips are broke where it attaches to the maf, so I'm not sure how you would connect the two securely, but if you're interested in that I can get some pics and you can be the judge of how bad it is and just cover shipping
I'll compare the obd1 and obd2 heater valve and verify they are the same. Someone has already claimed the obd2 one that I have. I should have another one, just have to locate it but if obd1 is the same we are in luck because I have allot of those. Are you needing the outside or inside door handle? I have an S50 and M52 oil pan and oil pump. I believe they are all the same. I'm not sure what you're plans are for the car, but it would be a good upgrade to put a baffle in there. That's what I was going to do for one of my builds, but I think I'm going to wait and try to get an S54 setup eventually once the build gets going
[QUOTE=lbennyboobool;29507012]
awesome. Ill take any and all pics of any intakes you have. ill pm you.
I'm looking for black sedan A pillars and front HK speakers, let me know if you have either!
Bump
I spy an aux fan... do you have any way of testing it? I need one for my e36 328.
Thanks.
PM me price one one pls. Also could use stock amber front corner lights for a coupe with good side pins.
Thanks.
Bump
if you need something let me know
Any speakers?
