Is this the correct Fuel Pump for my BMW E32 750iL:
http://www.ebay.co.uk/itm/BMW-Fuel-P...kAAOSwPCVX2U7R
Is this the correct part number for the Fuel Sender for my BMW E32 750iL:
16141180893
or is it
1180019
Seems as though the part numbers keep changing, so just wanted to 100% sure before I buy 2x Pumps and 1x Fuel Sender.
Give our BMW parts specialists a call at 888-280-7799 and they'll be happy to help you out sort the correct part #. Best of luck!
-Dmitry
888.280.7799 | 6am - 5pm PST
http://www.realoem.com/bmw/enUS/select?
For my 1992 750iL, both pumps are part number:
16146768653
The pump you have linked will require wiring.
I bought two pump from TRE. After some research, they seemed to be a reputable company. In fact, I had an issue with one pump where a stud broke and on a Sunday they took care of it with a new one shipped out right away. They have now been installed for many months and no issues. These pumps as just a bit better rated than stock and require no re-wiring, modification, etc. Direct fit and they will fit the pre-filter.
http://www.ebay.com/itm/TRE-432-BMW-...-/321796527356
And that reminds me, dont forget to get the pre-filter. I think there is no cheap option here, most run about $40US. You may be able to clean your original one if its not too bad. The pre-filter or pick-up filter sits at the bottom of both pumps.
______________________________
1992 750iL
BMW 7er Website www.7er.com
1989 BMW 735i Schwarz (sadly, sold) // 1989 BMW 750iL Cirrusblau Metallic // 1998 BMW 740iL Oxfordgrün Metallic // 2000 M5 Carbon Schwarz ///
Yup - direct fit. I tried to find the thread I had on my install, but I did not find it. Its why I really like them, factory wiring and no weird inlet size for the filter. I think the only issue is they seemed a tad thinner. But just a tiny bit. Once in the basket there was no issue at all.
1992 750iL
Fuel Sender was stuck, free'd it up, now the Fuel Guage works.
However the Trip Computer still says 0.0 MPG for Consumption. The range is working correctly though.
So, is there a reset feature for the OBC?
The Battery was disconnected when I was working on the Fuel Sender, so the Magic Reset has already been done.
OK so fuel sender is still stuck. Just that its stuck at half way now, rather than at the bottom..lol
So I will need a new fuel Sender.
Is there a way to test to see if both Fuel Pumps are working correctly?
You could probably clean it. Two methods. One is a fuel cleaning additive. Others have reported this can help. If not, the other is to take it apart and very carefully clean the wires.
http://www.upshiftblog.net/2011/01/d...n-e32-bmw.html
1992 750iL
Cheers, I will try to clean it first then. As I cannot find the fuel sender (Part No. 16141180893) anywhere in the UK apart from direct from BMW at £205.
Just dont break the wires, very fragile!
1992 750iL
Yeah just use a 12 volt source you can connect the cable back to the sender and reconnect the battery then switch the cars accessories on and see if they're alive.
I just did 😳
I just did. Im sad
