Hello MIAC-US,
I recently bought a 94 325is that is very clean apart from the rear end which was hit at one point. It seems like the back right rear is slightly buckled. The trunk closes with modification to the latch but not enough to sit flush and seal the trunk from water
. There is surface rust beginning to build and I would like to see if there is anyone in the area who is good at body work and wouldn't mind, somewhat cheaply, banging the buckle out so the trunk will close flush and seal. I know the buckle is causing the issue because last night I put the latch back in the original spot and hoped in the trunk as a friend tried shutting it. It gets within about an inch of the latch, probably less, then hits the buckled lower right trunk bit and stops. Its very close and doesn't look like it'd be all that hard to do, I am just not a body work person, no patience
Anyways if you all could point me in the right direction that'd be great!! Thank you.
