Page 8 of 9 FirstFirst 123456789 LastLast
Results 176 to 200 of 208
Thread: Turbo LS with TH400 and Ford 8.8
  1. #176
    Nov 2016
    Charleston SC
    2002 353I
    Quote Originally Posted by screamin88 View Post
    I did not see that coming. Would you be interested in selling your previous kit?
    I sold the piping but I do still have the turbo and intercooler.
  2. #177
    Nov 2016
    Charleston SC
    2002 353I
    heads came in today! got them built and was able to put one of them on the motor. I am waiting for one more headgasket to come in. hopefully tomorrow. I also ordered all of my stainless tubing to build my headers and turbo kit.
    just some as cast heads.
    these are some bad ass headgaskets
  3. #178
    Royalest of Oaks
    Mazda 3
    *drool* I pretty much know nothing about what makes one head great over another, but man that's purdy. Keep the updates coming!
  4. #179
    Feb 2014
    Mankato, MN
    88 Mazda RX-7 LS Swapped
    Quote Originally Posted by FoxBodyRacing View Post
    Well, that does me no good! LOL
    Looks great BTW. I did hear about the valves coming with certain Trick Flow heads being weak and collapsing up into the runners. Not certain but I'd check into it.
  5. #180
    Jul 2013
    FL Gulf Coast
    E36 - 1998 328iS - LS2
    Not knowing much about boost, is there an objective/conclusive way to determine that head lift has occurred?
    Or is it a conclusion arrived at (a guess) based on the supporting symptoms?
  6. #181
    Nov 2016
    Charleston SC
    2002 353I
    Quote Originally Posted by TipsyMcStagger View Post
    under high load the head lifts due to not having enough clamping force. in this case it is because the heads themselves were weak. when it lifts it pushed water into the cylinder. in my case it blew the head gasket.
    the new turbos will allow the exhaust gasses to pass with less restriction and the new heads not only flow better but they have a thicker base to them and a stronger aluminum which will prevent the head from lifting (hopefully).
    these are prepped by Brian Tooley. They come to him as a bare casting. He sent them to TEA to have the chambers and bowls CNC'd then put in powdered valve guides (which is the problem you are referring to) and his own stainless valves,
  7. #182
    Nov 2016
    Charleston SC
    2002 353I
    well I got the motor about 95% back together. shitty part is the trick flow heads do not allow for use of the factory rocker stands. I'm not even sure if I can use the factory rockers. I found that some people used the factory rockers shimming the base up a little.
  8. #183
    Feb 2012
    Bottom of a Bottle
    96 740il, XJS & CBR1000F
    Quote Originally Posted by LSxDreamer View Post
    Flow,weight and strength I believe.
    The World is ruled by Kings and Queens that blind your eyes and steal your dreams.
    When answering my questions please use a qualifier if you are not sure.
    The more I work on this car the less I respect German engineering.
    When you speak in Absolutes you are always wrong!
    Semper Fi
  9. #184
    Nov 2016
    Charleston SC
    2002 353I
    few more updates.
    I built new motor mounts, switched to a corvette balancer and waterpump for more room
    I built the turbo downpipe and began attempting to fit the turbos in place.
    also built my first double slip merge collector. I still need to finish off the inside. more to come
  10. #185
    Feb 2014
    Mankato, MN
    I'm jealous of the extra room you have made with the custom radiator and such. I am contemplating completely cutting out the drivers frame rail to get the turbo further away from the balancer and belt. Then I can hopefully put a 90 on the down pipe to route it under my Taurus fan.
    Anywhoo, this is coming along nicely! I'm happy about updates!
  11. #186
    Sep 2016
    Yulee, FL
    2000 Z3
    This is positively ludicrous and it makes my ambitions seem so much simpler. I really needed that inspiration and I am excited to see some video of this monster when done. Thank you for this journey so far outside of the box.
    Stubbornness is a virtue....
  12. #187
    Nov 2016
    Charleston SC
    2002 353I
    updates. headers built, started test fit/final welding tonight. I had to make hard lines for the drains due to the tight space. I have to adjust one of the feed pipes for the turbo cause it is touching the sway bar. the exhaust is going to be a tight fit but that's never stopped me before ill spit on it and get it in there.
    I also have shifted my business more to fabricating so I have also changed up my shop name a little and created a new logo with the help of my brother.
    new shop name is Fox Fabrications and here is my new logo. you can follow me on Instagram Fox_Fab I tend to update that more often than I do here.
  13. #188
    Oct 2008
    West coast
    '00 540 6.0/4L80e/S480
    Looks great!!!
  14. #189
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Nice work! Clean, high skill level, detail oriented custom fabrication.
  15. #190
    Nov 2016
    Charleston SC
    2002 353I
    thank you for the complements.
  16. #191
    Feb 2014
    Mankato, MN
    Looks awesome! Top notch stuff! Your engine must be set back a bit further than mine. I just don't seem to have the room you do.
  17. #192
    Nov 2016
    Charleston SC
    2002 353I
    possibly. I did set it back about another 1.25" when I built the custom mounts and had 1.25" taken off the driveshaft. makes it impossible to remove the trans without pulling the motor.
  18. #193
    Nov 2016
    Charleston SC
    2002 353I
    hot side is finished.
  19. #194
    Oct 2008
    West coast
    Wow. That’s absolutely beautiful. Saying I’m impressed is a gross understatement.
  20. #195
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    Is that photoshopped? It looks too perfect!
    Impressive...looks like you are using the new Holley FEAD too - cool.
  21. #196
    Feb 2014
    Mankato, MN
    Now this is just getting silly! Looks great!
  22. #197
    Royalest of Oaks
    Mazda 3
    Just... whoa...
  23. #198
    Nov 2016
    Charleston SC
    2002 353I
    not too much to update. I built the intercooler and started on the charge pipe. I am doing a 5" oval charge pipe to be able to sneak over the radiator but still be able to close the hood with minimal cutting. only problem is there is no such thing as 5" oval aluminum tubing so I have to make it out of sheet metal. the only issue is going to be ensuring I can still clamp a coupler onto it. worst case senerio is I make it a one piece to the intercooler. but I believe if I brace the inside of the ends to keep them from distorting from the clamp and boost I should be fine. I may make them bulge out a little to ensure the clamp has some positive engagement of the tubing.
  24. #199
    Oct 2008
    West coast
    Looks awesome!!!
  25. #200
    Absolutely stunning. You just gained an Instagram follower.
  1. E36 Parting out entire turbo kit with exhaust, fuel system, oil cooler and gauges
    By LukeG in forum Forced & Chemical Induction Parts
    Last Post: 12-29-2011, 11:30 PM
  2. FS: (AB,Can) e30 oil cooler with adapter and lines - for turbo?
    By gamman in forum Race Cars & Track Parts
    Last Post: 11-21-2009, 01:56 PM
  3. Porsche 997 Turbo manual vs BMW M5 E60 with chip and exhaust
    By trev0006 in forum 2006 - 2010 M5 & M6 (E60, E61, E63, E64)
    Last Post: 01-18-2009, 09:57 PM
  4. Turbo Headers with gaskets and everything you new NIB 155 Shipped
    By Chistakoff in forum Race Cars & Track Parts
    Last Post: 09-29-2008, 06:08 PM
  5. Turboing a 2002: How and with what?
    By BlackMagyk2002 in forum 2002
    Last Post: 09-17-2005, 09:05 AM
