not a whole lot to update. waiting on bumper brackets to arrive so I can finish fitting the radiator and intercooler then I can final fit the turbo pping and get it all finish welded.
I ordered injectors, fuel pump, regulator, wastegates, blow off valve, intercooler piping, front tires, and more.
I built the fuel cell but I'm waiting on the filler neck to come in so I can cut the hole for that and weld it on.
I built a fan shroud for the radiator today. (if you like it I can build them to your exact needs)
I got another new toy for the shop too
some of the others I bought recently
not bad for a beginner (not all of them looked as nice but this one I thought was picture worthy.
Garage (and shop-tool) envy!
Tipsy
Nice shear/break and welds. Won't that tank go boom in a rear end collision with that placement though?
The World is ruled by Kings and Queens that blind your eyes and steal your dreams.
When answering my questions please use a qualifier if you are not sure.
The more I work on this car the less I respect German engineering.
When you speak in Absolutes you are always wrong!
Semper Fi
It's nestled between two frame rails so it should be fine. It's not as safe as the factory location but there was no way I could retain the factory tank and do the rearend.
Semper Fi
it is definitely not the most ideal place especially because the battery is back there too. the battery will be in its factory location but I'm going to build a better cover for it.
Semper Fi
Something like this may add a bit of safety...
http://i43.photobucket.com/albums/e3...pscp5flzmq.jpg
Shea Burns
I am not sure what the regulations are in the States, but here in Canada if the fuel source is in the cabin or trunk it needs to have its own air tight cover and vented to atmosphere outside the car. I would plan on doing it anyways, less fuel fumes in the car and also hides the fuel lines.
I made a cover in my old car, used some weatherstripping for underbody truck tool boxes and some latches to hold mine down.
I will have an air tight seal and be vented outside. Deffenitly don't want to vent a fuel cell inside the car.
Now that's a good looking front end.
Sent from my SM-G900T using Tapatalk
Sweet lineup.
Semper Fi
I was able to get the belt routed to avoid hitting the turbo. I added in 2 idler pulleys and I think it turned out okay.
black grill came in and looks pretty good on there.
finally received the downpipe flange that I only used 1/2" of and immediately coned it down to what will be 4". my new bandsaw is already pulling its weight around here.
also welded the filler neck on. I'm still not great at aluminum welding but it should hold.
Looking good!
LS, turbo, solid rear axle, tubs.... what more could you ask for? haha this thing is wild, love seeing these types of builds, subscribed!
A/C as well
so I had to cut out a good size chunk of the frame rail. lucky all it does is holds the bumper. I boxed the inside on both sides and then boxed the frame rail in with some 16 gauge steel and welded everything back up its about as good as its going to get...
got the crossover pipe done. took a while because I had to get a purge tank setup to tig the stainless. I started wrapping everything.
I still need to plumb the wastegates into the downpipe as well as the O2 bung. I got a little ahead of myself when I started wrapping pipes. no big deal.
waiting on the weld on bungs to come in for the waterpump. should be here Friday.
new headlights came in. a light smoke to them but very clear.
I approve of this cutting! Did you make sure your bumper still lines up? Don't ask me how I know this can be a problem after modifying that frame rail. :-)
Looking really nice. I'm digging the turbo placement. Do you feel the stock radiator would live in its original spot setup like this?
WHAT BUMPER, INTERCOOLER, RADIATOR ARE THOSE? sorry for yelling...
ebay specials on all three I believe. I got the intercooler with the turbo I bought from a friend.
Such attention to detail! That my friend is a work of art.
Semper Fi
