Page 3 of 9 FirstFirst 123456789 LastLast
Results 51 to 75 of 208
Thread: Turbo LS with TH400 and Ford 8.8
  1. #51
    Nov 2016
    Charleston SC
    2002 353I
    well here is the rear finished. I probably have about 100 hours into this part of the project but it was worth it. I have tons of adjustment and I feel it will be plenty strong.
  2. #52
    Aug 2008
    Houston, Tx.
    '10 X5, '98 M3 - 302
    Right click, save as......
    Awesome work good sir
  3. #53
    Nov 2016
    Charleston SC
    2002 353I
  4. #54
    Feb 2012
    Bottom of a Bottle
    96 740il, XJS & CBR1000F
    What a thing of beauty!
    The World is ruled by Kings and Queens that blind your eyes and steal your dreams.
    When answering my questions please use a qualifier if you are not sure.
    The more I work on this car the less I respect German engineering.
    When you speak in Absolutes you are always wrong!
    Semper Fi
  5. #55
    Nov 2016
    Charleston SC
    2002 353I
    moving to the front i decided to suspend the turbo to get an idea where i could mount it. i think i am going to follow suit with Unatral and mount it on the drivers side up high. seemed out work out pretty well.
  6. #56
    Jun 2010
    Greenville, SC
    e46 325i, c5 vette, R1
    Dude... this is so badass!
  7. #57
    Royalest of Oaks
    Mazda 3
    Just curious, did you take much of a look at the stock rear end (or still have it)? I'm looking for some insight on how easy it would be to fab in a Ford 8.8 IRS carrier....
  8. #58
    Nov 2016
    Charleston SC
    2002 353I
    I still have it sitting in the garage.
  9. #59
    South Lyon, MI
    1997 BMW 540i 6spd
    so awesome, cant wait to see more!
    -Jeff
    1997 BMW 540i6 - Night Blue w/tan int - M5 front bumper, M5 Wheels, Halo projectors, muffler delete
  10. #60
    Mar 2004
    Tyler, Tx
    '01 740i Sp, '07 335i
    I built a 2000 Miata serveral years ago using a Ford 302 and a T'Bird IRS. They used two different in that model - a 7.5 and a 8.8, there were LDS units in both sizes. I used the 7.5 figuring it was enough for my needs. Several others did use the 8.8 but that required moving shock perches, etc for clearances.
    here is an 8.8 in another Miata but he has a rear mounted turbo with LSx over 700 rwh...
    here is my application with 7.5...
    http://i293.photobucket.com/albums/mm71/krallopian/darthSigTest2_zpsn6zkw5id.jpg[/URL][URL="http://www.facebook.com/pages/DFW7-Dallas-Fort-Worth-BMW-7-Series-Club/300942239566"]DFW7 on Facebook/URL]
    "The Last Great e38" 2001 i Sport - Born'd on date 1/01 Cosmos/Grey - 32.8K miles - 2 1/2 " Custom Exhaust, Center “X”over , Modified OEM rear bumper, M5 style trunk spoiler, M6 OEM wheels, M3 Steering wheel with working paddle shift & CF trim, Bi-Xenon upgrade, 13mm Rear sway bar added, SS brake lines and bronze bushings, Cross drilled rotors and painted calipers, Akebono pads, Zionsville aluminum radiator & exp. tank with electric fan, Sprint Booster, BluTooth conversion, MKIV Nav., Custom wood cupholder, DUDMD Tune, Orien V2.5 LED Angel Eyes, Evans waterless. Recently added grey faced //M5 Cluster - all gauges functioning. Changed the grey carpet to black and topped off with GG Bailey front/rear mats[/SIZE]
  11. #61
    Nov 2016
    Charleston SC
    2002 353I
    mocking up the brackets and headers. I'm gonna have to move the heater ports with these headers.
  12. #62
    Aug 2015
    houston
    e46
    Great work!!! Can't wait to see it moving
    Sent from my SM-G900T using Tapatalk
  13. #63
    Nov 2016
    Charleston SC
    2002 353I
    Thanks, Hopefully I'll get the motor dropped in for the final time this weekend. I pulled the ABS module out last night and had to trim some of the metal around the brake booster. I'm gonna roll with no ABS. just bypass it and put in a proportioning valve and should be good to go.
  14. #64
    Nov 2016
    Charleston SC
    2002 353I
    some parts came in
    test fitting the radiator and AC condenser and inter cooler.
    gotta trim the frame rail to move the turbo away from the waterpump.
  15. #65
    Feb 2012
    Bottom of a Bottle
    Quote Originally Posted by FoxBodyRacing View Post
    Should be interesting.
    Semper Fi
  16. #66
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    The wheels look so unsuspecting. Neat build.
  17. #67
    Nov 2016
    Charleston SC
    2002 353I
    Quote Originally Posted by Hueristic View Post
    the area I cut out I will add in 1/8" plate.
  18. #68
    Royalest of Oaks
    Mazda 3
    I'm going to assume that he's like me and just thinks the whole build is damn impressive and can't wait to see the finished results.
  19. #69
    Feb 2012
    Bottom of a Bottle
    Quote Originally Posted by LSxDreamer View Post
    Correctamundo.
    Also, I'm sure he knows that the shape is designed specifically for the stress and will design appropriately.
    Semper Fi
  20. #70
    Nov 2016
    Charleston SC
    2002 353I
    had to go with a stock header.
    a hose clamp works good for marking a tube to cut a straight line
  21. #71
    Oct 2005
    Northern California
    95 M3, 15 Golf TDI wagon
    Awesome job!
    -WTB: OEM Class 2 LTW GT wing with risers- Mazak
  22. #72
    Oct 2008
    West coast
    '00 540 6.0/4L80e/S480
    I assumed there would be a lot more sheet metal work necessary! How much modification are you going to have to do to the rear seats?
  23. #73
    Nov 2016
    Charleston SC
    2002 353I
    Quote Originally Posted by unnatrl View Post
    i started messing with it. There will deffenitly be some modification to the seats. Not sure the extent yet.
  24. #74
    Apr 2006
    Minnesota eh?
    86 325es
  25. #75
    Nov 2016
    Charleston SC
    2002 353I
    [QUOTE=someguy2800;29557503]Cool project! Here is my e30 with a 9 inch and 4 link if you haven't seen. I have a turbo m52 in it and had a t56 magnum but am building a transbrake th400 for it now. Should go 8's pretty easy
    I did go through your build when i was searching to see if anyone had put a stright axle in one before. i did not want to do a complete backhalf because i want to retain the back seats or at least make it look like they are functional. seeing your build boosted me confidence that i could do an 8.8.
    i was able to mess with it a little tonight. i finished getting the hot side mocked and tacked up.
    i got the front bumper in today so i can try and get the intercooler and radiator fit in there.
  1. E36 Parting out entire turbo kit with exhaust, fuel system, oil cooler and gauges
    By LukeG in forum Forced & Chemical Induction Parts
    Last Post: 12-29-2011, 11:30 PM
  2. FS: (AB,Can) e30 oil cooler with adapter and lines - for turbo?
    By gamman in forum Race Cars & Track Parts
    Last Post: 11-21-2009, 01:56 PM
  3. Porsche 997 Turbo manual vs BMW M5 E60 with chip and exhaust
    By trev0006 in forum 2006 - 2010 M5 & M6 (E60, E61, E63, E64)
    Last Post: 01-18-2009, 09:57 PM
  4. Turbo Headers with gaskets and everything you new NIB 155 Shipped
    By Chistakoff in forum Race Cars & Track Parts
    Last Post: 09-29-2008, 06:08 PM
  5. Turboing a 2002: How and with what?
    By BlackMagyk2002 in forum 2002
    Last Post: 09-17-2005, 09:05 AM
